Old 07-17-2003, 11:19 AM   #1
jin88
Member#: 29784
Default need some help what should I do???
Have a stage 3 ludespeed kit coming and going to upgrade my clutch, I see the pick is ACT street clutch, should I get a lighten flyheel with it since everything will be apart or should I just run the turbo without a lighten flywheel???
I heard it's not good to run a turbo with a flywheel weighting nothing???
What do you guys think!
jin88 is offline   Reply With Quote
Old 07-17-2003, 12:08 PM   #2
rhdude
Member#: 6637
2009 Acura MDX Sport
well, the motor will rev quicker, so you should spool quicker...
If you have the money, get one, there is no reason not to...
rhdude is offline   Reply With Quote
Need some advice on what should i do now... this has been a nightmare... ScubyMedic Newbies & FAQs 67 12-08-2007 09:14 PM
NEED HELP! What should i do? 05STI!!! Factory 2.5L Turbo Powertrain 8 01-16-2006 06:25 AM
NEED HELP!! what should I do now???? borla header??????? Stiboyz Normally Aspirated Powertrain 3 12-27-2001 06:13 PM
help what should i do? blu rex Newbies & FAQs 6 08-23-2001 07:27 AM
Help!...What should I do now??...... AndresRS01 Brakes, Steering & Suspension 2 04-02-2001 04:10 AM
Message Board Statistics All times are GMT -4. The time now is 01:18 AM.
