Old 07-17-2003, 04:16 PM   #1
Noize
Member#: 18123
2013 Evolution X GSR
Default EGT temps question
I'm tapped at the top of the tube about 3" from the motor on #3. I have a TXS-4 system ran by their unichip on a Stage IV default map. I cruise in the 1380 range, but at WOT in 4th over 6000rpm, I'll pass 1550 degrees and the temps will creep just past 1600. Once I pass 1550, I shut down.
I'm pretty sure this is abnormal. The phenomenon occurs in 4th and 5th only, and starts past 6000rpm indicated. If I dial the boost down from 17psi (what I usually run) to 14psi, the same thing happens. From what I've heard, my timing correction factor might be too retarded in that range? Anyone have any similar experiences? What are your EGTs at sustained WOT?
Noize is offline   Reply With Quote
Old 07-17-2003, 05:04 PM   #2
Noize
Member#: 18123
No love?
Old 07-18-2003, 12:50 AM   #3
Bolster
Member#: 22290
2002 WRB WRX Wagon
I'm tapped at just after the spot where #1 and #3 meet. I see barely above 1380 in 5th gear at WOT (up to 120mph and then I quit). I cruise anywhere from 1150 to 1250. Am I rich? I haven't seen mine get much past 1380 in any gear.
edit: FYI I am using Perrin Fuel Rails too, which may be keeping me on the slightly rich (and hopefully safe) side.
Bolster is offline   Reply With Quote
Old 07-18-2003, 01:07 AM   #4
pityr
Member#: 31719
i have mine in the casting mark right off 1 & 3. cruising i run at 700C and under wot in any gear i max at 750C. I can easily make it go over 850C if I let do PTFB.
pityr is online now   Reply With Quote
Old 07-18-2003, 09:28 AM   #5
Wheeler Bement
Member#: 15652
2002 2.5L WRX Wag.
160K club
Default Re: EGT temps question
I'm tapped at the cast bung on the driver side. catless and no intake resinator. crusie(70-85) i see about 1350. my automoter guage is too slow to see anything higher than that when i do WOT pulls, but i don't hear any det. the most i have seen was 1450 at a track day...that involved 3rd gear and 6500RPM at times.
Wheeler Bement is offline   Reply With Quote
Old 07-18-2003, 09:35 AM   #6
cnk
Member#: 10757
2013 BRZ Limited 6MT
I'm tapped 1" from cylinder 3. The highest I've ever seen is 800C ~ 1472F. I'm running Vishnu Stage 1 with Samco hoses. Boost tops out at 1.2bar ~ 17.4psi. WOT sustained EGT's are no higher than 800C.
Calvin
cnk is offline   Reply With Quote
Old 07-18-2003, 09:45 AM   #7
modvp
Member#: 25215
I am tapped where cylinder 2/4 meets, approx 2-3 inches from exhaust flange. I see 1300F in 5 th at 65-70 mph. In 4 th at redline i see approx ~1450. I have a VF30 (with uppipe & turbo back mods) running ~14.5 psi of boost. No ECU mods!
modvp is offline   Reply With Quote
Old 07-18-2003, 10:50 AM   #8
Wheeler Bement
Member#: 15652
2002 2.5L WRX Wag.
160K club
ok, what side(driver, passanger) is #1 and #3. i did a search and found posts about bothsides....so which is it.
Old 07-18-2003, 10:53 AM   #9
modvp
Member#: 25215
Driver's side = 2/4
passenger side = 1/3
Old 07-18-2003, 02:27 PM   #10
PaulRex
Member#: 12454
10 Toyota Taco
K8 SV650SF
Greddy EGT gauge and sensor, on the passenger side 1,3 , I see 780C at WOT in the mid range rpms, and then at 6krpms I peak at 800C. Running 16.5psi peak, stock turbo and fuel system.
Unknown a/f ratio because I've been fuel tuning without an wideband
PaulRex is offline   Reply With Quote
Old 07-18-2003, 04:56 PM   #11
Noize
Member#: 18123
Unhappy
Sounds like something is definitely screwed up with my car. I was hoping it was the tapping point, but alas, it sounds like no. My probe/gauge combo is stupid fast (omori), but I think its definitely time to get this sucker diagnosed. This blows.
Thanks to those who replied.
Old 07-18-2003, 05:05 PM   #12
djerickd
Member#: 3782
02 WRX WFC#040
Clean on 19's
Mine is at the top of my M2 uppipe (probably not the best place) and the most I ever see is 700C. Thats with TXS stage 2 + injen intake map, m2 uppipe and turbo back, and one step colder plugs and samcos.
djerickd is offline   Reply With Quote
Old 07-19-2003, 12:29 PM   #13
IMPREZive 02 WRX
Member#: 11436
1999 Impreza RS
eBay racing edition!
I just installed my Autometer EGT gauge, and I was worried when I was seeing ~1300 at WOT.
FWIW, I'm using cnk's old unichip with a bit more mods - maybe it's time for a reflash.
IMPREZive 02 WRX is offline   Reply With Quote
Old 07-19-2003, 12:32 PM   #14
Judah
Member#: 9320
2002 Subaru WRX
Do any of you guys have pictures of this? Was it hard to install?
Judah is offline   Reply With Quote
Old 08-12-2003, 10:40 PM   #15
Wheeler Bement
Member#: 15652
2002 2.5L WRX Wag.
160K club
brought back to life to see why you guys do #1 and #3 on the passenger side when most stg 4 cars go bad on the #4 driver side?
Old 08-12-2003, 10:55 PM   #16
Bolster
Member#: 22290
2002 WRB WRX Wagon
BTW- I'm runnng a VDO EGT. I talked to Mark at TurboXS a few weeks ago and he said my temps were like 100-200 degrees (F) lower than what they typically see (1400-1550). I never had the EGT in when the car was stock, so I don't have lots to go on for a comparison.
Old 08-13-2003, 12:06 AM   #17
big_adventure
Member#: 40501
2005 Decathalon 21sp
One WheelSeanPower
My car is TXS stage 2.
I'm tapped 3" down #4, with a Greddy electronic EGT. I see ~820C at WOT with the "stock" map, but I've seen it as high as 850C. With the TXS stage2new map, I've never seen over 810, and it's typically around 790-790 at WOT. Unfortunately, my car or map are messed up, since I get dets in mid revs at or close to WOT. It's being tuned this weekend, and I'll update this post if it's still alive.
EDIT: Ooops, I guess that I'd never looked at the EGT right at the det time. It went over 860 and was still climbing when I had det and ended the run.
big_adventure is offline   Reply With Quote
Old 08-13-2003, 08:03 AM   #18
CTKAG
Member#: 15001
STi V8 Spec C Power
NESIC TrackH0z # 10
I have an Omori guage tapped near the casting bung on the drivers side. I can hit 1600 at WOT on full boost during track events.
-Keith-
CTKAG is offline   Reply With Quote
Old 08-13-2003, 09:55 AM   #19
bluescoobywagon
Member#: 14911
Not A Wagon!
2011 WRX - 285s on 18x9.5
I seem to recall that it took a few hours to install my EGT gauge. My probe is on the driver's side where the cylinders meet and it clears all heat shields. It's Autometer, by the way.
Mike Robinson
2002 WRX Wagon
bluescoobywagon is offline   Reply With Quote
Old 08-13-2003, 10:16 AM   #20
jetskizero
Member#: 13833
2002 Impreza WRX
Silver - Sold :(
Default uh-oh
I haven't heard this - I've been watching the 1/3 cyl (passenger side). I thought that's where people were running the most lean?
Are there some threads that point to Stage 4 major lean problems?
J
jetskizero is offline   Reply With Quote
Old 08-13-2003, 10:37 AM   #21
wcbjr
Member#: 4001
2006 Legacy GT
Obsidian black
I haven't studied the fuel line layout yet. What is the first cylinder to get fuel, what is the last? Also, there has been talk about the cyclinder next to the turbo tends to go because all of the heat generated.
wcbjr is offline   Reply With Quote
Old 08-13-2003, 10:51 AM   #22
fastlane
Member#: 17470
2002 WRX Wagon 5 Spd
^^Nomo - 04 GT Stang now
I am running and AutoMeter EGT tapped at the casting bung on the driver's side manifold and I see 1450-1475 while cruising at 3500 RPM in 5th. I usually hit 1550-1600 while winding out 4th or 5th, upwards of 5500 RPM. I never stay in the gas long enough to see how high it will get. I am currrently running a Turbo XS Stage 2 Unichip with gutted uppipe and full Turbo XS turbo back, stock turbo, stock fuel, and mbc set at 15.5 psi.
fastlane is offline   Reply With Quote
Old 08-13-2003, 11:55 AM   #23
modvp
Member#: 25215
I have VF30 with walbro hp fuel pump with Stock ECT, boost controller gutted uppipe and turbo back. At the top of 3rd (14-14.5 psi at 7000rpm up an incline) I see ~1425-1450 Max.
Old 08-13-2003, 02:45 PM   #24
dazz1
Member#: 10363
5.9 Turbo Cummins
A few pics...
dazz1 is offline   Reply With Quote
Old 08-13-2003, 07:07 PM   #25
IMPREZive 02 WRX
Member#: 11436
1999 Impreza RS
My probe is installed almost exactly where Dazz's is. I just centered mine in the port.
poll: raw fuel smell and where your car is parked Darryl Warranty Issues & SOA Problems 16 01-23-2009 07:47 PM
Dear UPS, What the F*** is a "DESTINATION SCAN" and where the crap is my package Sausage Off-Topic 29 05-12-2007 09:48 AM
BBQ at Gonz's house: post here if your coming and what your bringing!! wrxty Rocky Mountains Impreza Club Forum -- RMIC 25 04-04-2007 12:34 PM
What is your EGT and Oit temp read? ChAi Normally Aspirated with bolt-on Forced Induction Powertrain 15 06-17-2004 12:15 AM
