Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Old 07-17-2003, 04:55 PM   #1
sedonawrx
Member#: 34504
2002 Wrx Sedan
Sedona Red
Default Changing Oil
I was just wondering what oil, and oil filter do you guys recommend? Thank You
sedonawrx is offline   Reply With Quote
Old 07-18-2003, 05:32 PM   #2
armand1
Member#: 10309
'02 OBS 2-tone!
'95 Montego Miata
5w30 oil; Subaru OEM oil filter & crush washer.
Old 07-18-2003, 05:51 PM   #3
Got Groceries?
Member#: 25323
2003 WRX Wagon
5w30, synthetic after 5000 miles unless you plan on changing it religiously every 3000 miles, Subaru OEM filter or Purolator filter. For better filtering, you can use a Forester filter, more filter surface area, same other specs. New crush washer every time.
Got Groceries? is offline   Reply With Quote
About to change oil in a turboed 2.5RS. Which grade oil should I use? Andrew Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 09-01-2011 01:42 PM
Change oil first or start than change oil carpfish Service & Maintenance 5 03-23-2010 04:32 PM
Changed oil, used Amsoil, 25k before next change? Impr3zy0u Service & Maintenance 28 01-14-2006 01:34 PM
How to change filter w/o changing oil? TimStevens Service & Maintenance 11 04-29-2003 07:49 AM
change oil filter with every oil change? BlackBeastie Service & Maintenance 1 03-15-2003 07:29 PM
