07-17-2003, 08:03 PM | #1 |
Member#: 4074
Vehicle:1998 Impreza RS RBP (one of the first!) |
need to splice in new map sensor
Ok so I gota an old map sensor from a justy and have both ends of the connectors because they don't match up to the map connectors on my car. so I need to splice the new one in. the old map has a yellow with green striped wire and a yellow with a red striped wire. and the justy map has a blue and a green wire out of one end of the connector and a black and a white wire out of the other end. just incase you are confused this crude drawing below should help. probably not though...
|justy|--black wire--[ plug]--blue wire |map |-white wire--[____]--green wire |rs- |--yellow\green stripe wire--|plug| |map|--yellow\red stripe wire----|___| Thanks in advance. Courtney
07-17-2003, 11:05 PM | #2 |
Member#: 4074
so no one knows huh? I guess I should just try it one way and if doesn't work try it the other?
Need to splice radiator fan plugs!!! | speedymaker | Electrical & Lighting | 2 | 08-31-2009 06:45 PM |
Need to find 04' STi ECU pin diagram to splice in AVC-R | SolidSnake | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 2 | 03-28-2006 06:46 AM |
Where to splice in boost gauge? Intake? | DrD | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 6 | 10-06-2002 11:21 PM |
How to splice in WRX factory sub | nixima | Car Audio, Video & Security | 1 | 07-20-2002 12:16 PM |
How to splice in GReddy Turbo Timer? | SFsube | Technical Forum Archive | 0 | 09-13-2000 01:02 AM |
