07-17-2003, 10:49 PM | #1 |
Member#: 33376
Vehicle:2003 WRX Sedan Black |
Main Fuse Keeps Blowing???
Whats up guys...
The 15A fuse that controls my horn keeps blowing and I do not know why. I replaced it three times and keeps blowing almost immediately. I am sure there is a short somewhere, but I just wanted to know if someone had encountered a problem like this. Incidentally, the cruise control does not work while this fuse is blown-are they on the same line? I also have a blown bulb on the side of the passenger-side headlight. I wonder if its this causing the short. Any help would be appreciated. Thanks, Chris
07-18-2003, 12:04 AM | #2 |
Member#: 8023
Vehicle:2019 Crosstrek white |
Sometimes it helps to mention in a fuse blowing post as to whether the car is completely stock or if you have done any modifications. Stereo? anything?
If it is completely stock then a short may be very difficult to find and probabaly is best handeled by a dealer. Sometimes a short will cause a blown fuse in a totally unrelated area. |
07-20-2003, 11:03 PM | #3 |
Member#: 33376
I think I got it narrowed to the DSBC that was installed...cant remeber it happening before this installation...
thanks |
07-20-2003, 11:36 PM | #4 |
Member#: 8023
Well the easy way to tell is to disconnect the wiring any aftermarket eletronics and see what happens. If you can anyway.
Also inspect the wiring as you take it off. In my short i had pulled apart two wires and did not notice that it had pulled away some of the insulation from one. |
parking light fuse keeps blowing | SCOOBIEdoo | Electrical & Lighting | 0 | 02-08-2007 11:41 PM |
Illumination fuse keeps blowing | DLUX WRX | Electrical & Lighting | 5 | 11-08-2006 12:21 AM |
Speedometer/Window fuse keeps blowing | Geoff | Electrical & Lighting | 0 | 05-31-2005 02:36 PM |
*Urgent* Wiring some lights and fuse keeps blowing | Subwoofer87 | Electrical & Lighting | 6 | 09-20-2004 11:23 AM |
Radio Fuse Keeps Blowing | Stilletto | Electrical & Lighting | 7 | 09-18-2003 12:12 AM |
