Old 07-18-2003, 12:01 AM   #1
boysetsfire
Member#: 6218
2001 2.5rs-t
silverthorn metallic
Default Oil leak
I seem to have a lot of oil coating the intake pipe close to the turbo and the turbo itself. I havent felt any loss in power and have not seen any smoke coming out of the exhaust. It seems a decent amount of oil also has been coming out of my bov. Anything this could be or anyone have some ideas of what i can do to see where the oil is coming from? I just drove from california to utah and this is when i noticed the oil. I have pictures but no where to host them.
thanks
-Marc
EDIT:
The kit has been on for about 2 years and about 20,000 miles. This is the first sign of oil leakage/consumption.
boysetsfire is offline   Reply With Quote
Old 07-18-2003, 06:03 PM   #2
yebokmj
Member#: 2213
1995 Impreza w/EJ255
Brilliant Red
Default Oil=bad
yebokmj is offline   Reply With Quote
Old 07-18-2003, 07:57 PM   #3
milkman
Member#: 8066
Y2K RSt
Sedona Mars Red Pearl
Default Oil catch Tank?
Do you run one is it full?
What side of the turbo is the oil on?
milkman is offline   Reply With Quote
Old 07-18-2003, 08:03 PM   #4
boysetsfire
Member#: 6218
2001 2.5rs-t
No i dont run a catch can. Its on the compressor side on the bottom half and some on the intake pipe closest to the turbo.
-Marc
Old 07-18-2003, 10:10 PM   #5
WRX 555 STi
Member#: 8042
MY00 WRS - '04 WRX
2002 Dragon slayer :)
Chances are:
1: The engine is blowing oil in from the valve cover vents to the intake (which will not make sense for it to appear on the compressor)
2:Loose oil line feed fitting nut. Make sure everything is tight man.
3:Maybe you blew a seal on the compressor side and you're leaking oil through the compressor to the intake charge.
Just my opinions.
~Anthony.
WRX 555 STi is offline   Reply With Quote
Old 07-19-2003, 12:14 AM   #6
yebokmj
Member#: 2213
Brilliant Red
Default Picture
Joshua
Old 07-19-2003, 12:36 AM   #7
Hondaslayer
Interpretively Paraphrasing
Member#: 4562
1995 Legacy LSi
1998 Declasse Moonbeam
Blow-bye,The oil is starting to get past the conector there,
get a catch can.
possible oil leak and radiator leak MachinesWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 03-18-2006 07:23 PM
weird oil leak/AC leak? NateDogg Service & Maintenance 2 05-03-2004 04:23 PM
Oil leak just above oil filter Big_Hitter Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 02-28-2003 09:57 AM
New Omori Oil temp install and oil leak mhbrown Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 01-22-2003 07:10 PM
oil leak from front of engine, oil pump? drftsub Legacy Forum 14 01-06-2003 07:44 PM
