Old 07-18-2003, 05:14 AM   #1
eddieman
Member#: 40230
2001 Forester
black
Default Forester Swap EJ20
Hi, i need some help from someone. I just swap a EJ20 engine to my 2001 forester, but i keep using my original ECU, i put a SAFC II in to hope decrease the fuel, but it dosen't help really much. is there any other way to lien the gas without changing the ECU. right now a big black cloud is coming out from my exhaust even when is idel.
eddieman is offline   Reply With Quote
Old 07-18-2003, 08:24 AM   #2
peepshow
Member#: 1777
2005 LGT
#92 FZippy
What EJ20 did you put in your Forester? A turbo EJ20? Going from a naturally aspirated EJ25 to a turbo EJ20 should require MORE not less fuel. Usually this can be handled by simply installing an uprated fuel pump.
We need more info from you. What engine did you put in your Forester (year/model your EJ20 came from). You have no location in your profile, so I'm assuming you're talking about a USDM Forester which would mean EJ25, but that could be different if you're overseas.
- Trent
peepshow is offline   Reply With Quote
Old 07-18-2003, 10:46 AM   #3
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
your going to have REAL issues using the stock ecu as it has a 1 bar map sensor .. so when ever you go above 3 psi it has no idea whats going on .. unless you used the ej205 map sensor .. then it ... who knows... this was a bad idea
i am suprised it works at all
i can't express how much better it will run with the right ecu
Old 07-18-2003, 12:59 PM   #4
eddieman
Member#: 40230
2001 Forester
black
Hi, it is a EJ25 forester that swap to a EJ20T engine, everything seems okee, but the tech told me that the fuel get to rich, so the somke come out from the exhuast and also after turn off my engine, turn it back on about 15min, the engine will start but the engine rpm won't go up even i step on gas, it need to wait for arrround 5 min. the tech told me that is because the fuel is tooooo rich, so the spark plug got wet and the rpm won't go up until the spark plug got a bit dry. we try to unplug the MAF sensor the car seem run unstable, but no somke coming out.
Old 07-18-2003, 01:13 PM   #5
peepshow
Member#: 1777
2005 LGT
#92 FZippy
You definitely need some sort of engine management. I didn't catch the part about running the stock EJ25 ECU the first time I read your post. I'm with Jaxx, I can't believe it's running at all.
At any rate, the UTEC sounds like it would be a fantastic option for you, but I'm not sure if it works with the EJ25 ECU.
- Trent
Old 07-18-2003, 06:46 PM   #6
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
it won't (utec)
Old 07-18-2003, 06:55 PM   #7
eddieman
Member#: 40230
2001 Forester
black
So what kind of ECU will fit ~~
Hoping to swap EJ20 into 97 Outback, what do I need to know? zoo mob Subaru Conversions 6 03-28-2010 09:22 PM
1.8 GC8 to 2.5 forester swap subaru932001 Normally Aspirated Powertrain 1 02-25-2006 12:15 PM
Help with choices 98-01 Legacy/Forester swap to EJ20/EJ25T Legacy Subaru Conversions 3 03-15-2005 04:55 PM
Swapping ej20 for ej257 wrx02racer Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 01-23-2005 12:24 PM
f/s full jdm engine swap ej20 turbo omar14 Private 'For Sale' Classifieds 0 08-20-2004 03:02 PM
