Old 07-18-2003, 10:30 AM   #1
Drivinwest
Member#: 39124
2005 Saab 9-2X Aero
Satin Gray Metallic (CGM)
Default Windshield crack repair - am I nuts?
You may have read my dilemmas on the Dress-Up and Style forum. Long story short, with 195 miles on my car a rock make a 12" crack in the windshield. After a $330 replacement and 5 days, ANOTHER rock hit my windshield.
The 2nd crack did not spread and figuring my luck, I just had it filled to prevent expansion. I've opted to leave it be until it happens again.
The acrylic fix used by the glass company did a fair job. I know the repairs are not advertised as cosmetic, but it did improve te elook of the glass somewhat. The parts that are still visible are the areas of impact (two actually) where the glass has been crushed into so many little pieces that it refracts light readily. Structurally, these spots were still decent so vaccuuming or picking out this glass wasn't an option.
So here's my thought...
Chips/cracks in windsheilds can be made nearly invisible when the break is clean e.g. bulls-eyes where a scoop of glass has come out. When these are filled with acrylic they're basically invisible. You can see the impact marks on my windsheild because the glass is crushed and the acrylic can't get into all the voids. If i were to grind out the impacts points with a very fine dremel glass bit, I should be able to fill it with acrylic and it would be nearly invisible. Right?
Trying this would cost me about $25. screwing up would cost me $330.
The fact that glass repair companies DON'T do this might be quite telling, but I'm toying with giving it a shot myself. So, am I nuts?
Drivinwest is offline   Reply With Quote
Old 07-18-2003, 11:28 PM   #2
ws6fiero
Member#: 33067
1998 Legacy Wagon
Spruce Pearl
Have you considered trying it on a junk windshield? That way, if it doesn't work, you only wasted $25, and by reusing supplies if it does work it would probably be <$50 after you did the actual car. I guess if I wanted to try it, that is what I'd do.
ws6fiero is offline   Reply With Quote
Old 07-19-2003, 02:01 AM   #3
Kean
Member#: 25187
'08 Foz Prem TGM
'10 Challenger R/T Blk
Sounds risky. Even if you were successful, I'd be worried that the structural integrity of the windshield would be compromised even further. Have you talked to any windshield experts?
Kean
Kean is offline   Reply With Quote
Old 07-19-2003, 02:17 AM   #4
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
I say pay your 2$ and practice on as much glass as you want at the local pick and pull!
I think its a good idea.
Old 07-21-2003, 05:04 PM   #5
Jung918
Member#: 10969
I had a bulls eye in my old car and i got it fixed professionally. My insurence also paid for it. Call your insurence company and see if they will pay for it to get fixed.
Jung918 is offline   Reply With Quote
Old 07-21-2003, 06:47 PM   #6
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
No.
the acrylic repair is a bit more involved.
What they do is use a very high powered vacuum to pull out all the broken glass.
then fill the break with the acrylic gel, then use a special uv light to cure the acrylic.
the mark will always be there cause thats where they fill the void, through.
I got one filled recently, 50 bucks. tiny little mark on the windshield, down in the lower corner dont even notice it.
Jay
Old 07-22-2003, 03:03 PM   #7
cavymeister
Member#: 24463
2003 Chevy S10
91 Hunduh Civic BASE
I used prestone fix-a-windshield on my honduh with EXCELENT results.
cavymeister is offline   Reply With Quote
Old 07-22-2003, 06:50 PM   #8
Gargantua
Member#: 15090
2002 WRX sedan
Just to say ditto to McDade's post. I have had a couple of successful cracks fixed for $45.00
Mr Boogie Banana
Gargantua is offline   Reply With Quote
Old 07-29-2003, 12:31 PM   #9
bbrewer
Member#: 8599
2002 WRX sedan
Permatex Bullseye. Similar to the pro process it uses a syringe held on the windshield with a suction cup to draw out the air while a viscous acrylic replaces it. It will not completely eliminate the break but it does a great job cosmetically. Also, by filling the void it reduces further cracking that occurs when water gets in there and expands.
bbrewer is offline   Reply With Quote
windshield crack repair aweissenborn Mid Atlantic Impreza Club -- MAIC 17 04-27-2010 10:49 AM
Am I nuts? I am SERIOUSLY considering buying one of these Davenow Off-Topic 25 09-19-2005 10:12 AM
Anyone had their windshield crack repaired by someone reputable? BigElm Tri-State Area Forum 16 12-12-2002 11:54 AM
Windshield cracked KITTbri General Forum Archive 13 01-19-2001 12:50 AM
windshield cracked! Penphoe Vancouver Impreza Club Forum -- VIC 2 12-19-2000 11:37 PM
