Old 08-06-2003, 12:35 PM   #51
TBeck2000
Member#: 40753
I'm not sure how much the Auxiliary Input Cable costs but this sounds like the missing piece of the puzzle. The input capability is already built-into the LM-1 (http://www.innovatemotorsports.com/s...m#_Toc46234170), but I guess you might want the special cable to interface to the Mini-DIN 7 plug. I'm sure you could come up with your own interface by visiting a Radio Shack. You'd just need to grab an rpm signal voltage from somewhere in the car. It simply records the voltage and then you would need to convert that to an RPM in MS Excel. You could also log several other things at the same time. Intake air temp, boost pressure, fuel pressure, oil pressure, etc. (up to 5 total) and chart them at the same time note: The input voltages must be less than 5 volts to keep from damaging the controller.
On another note, I tried to order an LM-1 and the website said that they were backordered. I also inquired to Patrick about group purchase pricing and volumes, but I haven't recieved the info yet. Here's the note I received from Patrick:
Hi Tim-
Thanks for your interest. We’re currently sold out, but production is ramping up. We’ll get back to you by the end of the week regarding both questions.
Thanks,
Patrick Thompson
Innovate! Technology, Inc. / Innovate Motor Sports
I hope to try the LM-1 out pretty soon and see if it can really do everything it says it can. If so, it is much more powerful than the alternatives that I have seen.
Tim
TBeck2000 is offline   Reply With Quote
Old 08-06-2003, 12:56 PM   #52
Klaus
Member#: 40416
68 Porsche VW Bus
white
The input capability is already built-into the LM-1 (http://www.innovatemotorsports.com/...tm#_Toc46234170), but I guess you might want the special cable to interface to the Mini-DIN 7 plug. I'm sure you could come up with your own interface by visiting a Radio Shack. You'd just need to grab an rpm signal voltage from somewhere in the car. It simply records the voltage and then you would need to convert that to an RPM in MS Excel.
BTW. An 8 pin cable will work also in the 7 pin Plug of the LM-1. Get a Macintosh serial cable with all 8 pins connected and cut off one end. If you have an analog RPM signal already in your car, you do not have to convert it using Excel. The LM-1 software can do that for you. For the input used, just specify the unit (rpm) and which rpm is equivalent to 0V and which is equivalent to 5V. The produced Excel-log and graph will show the log already converted into the specified unit. We are working also on a future software release (no release date yet) that will allow you to link to sensor output curve files (excel files), so that the log download will do the linearization for you for non-linear sensor signals.
The upcoming aux-in cable with RPM allows to hook it up with an inductive pickup (included) or you can directly hook it up to a crank synchronous or cam synchronous pulsed signal (1 pulse/rotation). That signal can be anywhere from 300mV to ignition primary (not tested yet, but will be before release).
The aux-in cable has a built-in switch with which you define whether the rpm pulses are 1 pulse/crank rot. or 1 pulse/2 crank rot.
Klaus is offline   Reply With Quote
Old 08-06-2003, 01:40 PM   #53
Turbo Datsun Z Car
Member#: 41053
74TT RB26dett Datsun
This was the responce I just received concerning my pre paid order...
"Hi Joel-
We’re hoping to ship your order by the end of this week, but we’re committing to ship by the 15th of August. Thanks, and happy tuning!
Patrick Thompson
Innovate! Technology, Inc. / Innovate Motor Sports"
I'm excited....
joel
Turbo Datsun Z Car is offline   Reply With Quote
Old 08-06-2003, 04:29 PM   #54
innovate_patrick
Member#: 41318
Hi Joel-
Just a quick clarification: We bill credit cards only when units ship, so "pre-paid" isn't entirely accurate. Thanks again for your support!
-Patrick from Innovate
innovate_patrick is offline   Reply With Quote
Old 08-06-2003, 05:06 PM   #55
Turbo Datsun Z Car
Member#: 41053
Originally posted by innovate_patrick
Hi Joel-
Woops ....
I guess I didn't choose the correct wording...
I simply meant, I have eagerly sent my payment in, and can't wait to get the WB Unit and start using it....
Old 08-10-2003, 03:07 AM   #56
turboICE
Member#: 33979
2006 STi,'11 OBS
WRB & Black/Silver
Does this have an analog output to log in another data aquisition tool? i.e. will it send out a 0-5v signal indicating AFR in a linear fashion, along with calibration points?
turboICE is offline   Reply With Quote
Old 08-10-2003, 05:36 AM   #57
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Default Re: Great new WideBand O2 unit!
Originally posted by rob
2 Definable analog outputs
Reading is good, m'kay.
Old 08-10-2003, 11:55 AM   #58
turboICE
Member#: 33979
2006 STi,'11 OBS
WRB & Black/Silver
Good parrot (I can quote advertising too). I read that plus the entire site,
Q: Will it be possible to setup the analog output for a linear 0 to 1 volt = 10:1 to 30:1 air fuel? And what is the accuracy of the output?
A: The outputs are 10 bit A/D's with 0-5V output. The software in the LM-1 maps Lambda Values of 0.5 to 1.523 (7.35 to 22.4 AFR) into a 10 bit value (0..1023). The programming of the analog outputs then maps the programmed values to the appropriate output voltages. An output of 0 - 1V has about a 200 step resolution as this is 1/5 of the 0-5V output with 1023 step resolution.The mapping is capable of 7.35 to 22.4 AFR. A range of 10-30 AFR would require significant changes in the software of the LM-1.
but do not see any one confirming it exists on a released unit.
So you have bought one and this advertised function actually is there and works? If you have one then be helpful and confirm that the function is there and accurate. (I am sorry it is bad enough when members do it, but it really bugs me when moderators are snide to someone who is on the board for information and are not causing problems or flame wars.)
I can not think of a single electronic device hawked on these boards (other than simple analog gauges) that actually have all their advertised functions. That post was written prior to release and producers love to advertise they have everything both before and after release.
So it remains a valid question and the referred to advertising post does not answer the question.
It was 3:00 so I may not have properly qualified the question - so if either innovate_patrick (assuming they are from the company) or someone that has a production unit would confirm its functioning.
Old 08-10-2003, 03:08 PM   #59
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Actually, I just had a long conversion with Klaus on the second page of this post about the outputs for a secondary screen. He appears to be the developer, so I didn't think there'd be reason to question whether or not the function was actually there.
Old 08-10-2003, 04:18 PM   #60
turboICE
Member#: 33979
2006 STi,'11 OBS
WRB & Black/Silver
Sounds like a good deal then when it is confirmed as loggable in DD using their external inputs ability the way that it can log Motec.
Old 08-10-2003, 10:08 PM   #61
Jon [in CT]
Member#: 2992
02 WRX Sedan
I'm confident that the LM-1 can mimic the Motec's voltage output for air/fuel ratio (AF), as long as it can be described as AF = a + b*voltage and as long as you don't require an AF less than 7.35 or greater than 22.40.
Jon [in CT] is offline   Reply With Quote
Old 08-10-2003, 11:12 PM   #62
turboICE
Member#: 33979
2006 STi,'11 OBS
WRB & Black/Silver
I agree with your input now that it most likely can and will - I guess I have just been burnt by too many claims and it causes me to pause and question - like the ability to log knock events by DD.
Thank you all for the feedback on this - it has convinced me enough to buy the LabJack in preparation for purchasing this AFR tool to use with DD logging - and hopefully eventually Xede logging so I can stop macro converting my DD logs.
Old 08-11-2003, 05:32 PM   #63
Klaus
Member#: 40416
68 Porsche VW Bus
white
Hi Jehcpa,
I have right now about 50 production units in front of me and I can confirm the analog output functions are working.
Quite a few of our customers are using it. One customer has installed the sensor on an experimental race engine (at a university) directly at the exhaust header of one cylinder and they can see (on an oscilloscope) charge loss due to valve overlap because the analog outs are so fast. They therefore sample the analog outs synchronous with the exhaust stroke. New upcoming software and firmware will allow you to program analog out response speed (for each output separately) and default output during warmup or error conditions. You can also specify if during these conditions the outputs should go high impedance instead of outputting a voltage.
Software and firmware upgrades can be downloaded from our web-site for free.
Regards,
Klaus
Old 08-11-2003, 07:12 PM   #64
turboICE
Member#: 33979
2006 STi,'11 OBS
WRB & Black/Silver
Excellent thank you for the response.
Old 08-11-2003, 09:37 PM   #65
Turbo Datsun Z Car
Member#: 41053
Man this tool is going to be the iceing on the cake for my turbo'd Z with the Electramotive TEC2.
along with this device, doing the auto tune and have it dead on will be a breeze... [
Getting excited....
Old 08-13-2003, 08:28 AM   #66
d00f
Member#: 6000
2000 GC8 STi V4 swap
BRP
I have the Techedge 1.5 and compared it to an expensive motronic unit on a dyno. Well within 0.01 AFR all the way through the scale. Has RPM and 2 ADC inputs. I haven't found a way to hook it up to the Tec2 but the version 2.0 is supposed to work...
-Michael
d00f is offline   Reply With Quote
Old 08-13-2003, 08:33 AM   #67
d00f
Member#: 6000
BRP
I do have a question for us cannucks. Will the unit operate at low temps? I know wide temp rangs LCD displays are difficult to source. Would suck if it doesn't work in -20C weather.
-Michael
Old 08-13-2003, 10:38 AM   #68
misterblu
Member#: 39054
-Michael
You need to e-mail Jason C. He talks about a simple circuit that will allow you to use the Techedge with the TEC.
http://www.miataforum.com/ubb/ultima...=020292#000011
HTH,
Jon
misterblu is offline   Reply With Quote
Old 08-14-2003, 10:47 AM   #69
craig429
Member#: 41767
Is a GP getting set up. I am interested in purchasing one.
Craig
craig429 is offline   Reply With Quote
Old 08-14-2003, 10:49 AM   #70
turboICE
Member#: 33979
2006 STi,'11 OBS
WRB & Black/Silver
I could go with a GB as well.
Old 08-14-2003, 11:04 AM   #71
TBeck2000
Member#: 40753
I have a GB going for us MR2 owners (but others are welcome). Here's the direct link to the thread: http://board.mr2faq.com/showthread.p...hreadid=160174 , but you have to register at http://board.mr2faq.com to read it.
Essentially, the price structure is like this:
5+ Units
$334.00 (Savings of $15.00)
Free UPS Ground Shipping Included (Savings of $10.00)
Total Savings of $25.00!
10+ Units
$324.00 (Savings of $25.00)
Total Savings of $35.00!
I am currently planning on closing the GB on August 30th unless there is a good reason to extend it. Innovate will need the following information:
-Name
-Credit Card Number & Expiration Date
-Billing Address for the credit card you are using
-Shipping Address
-Phone number you can be reached at
Innovate will not ship a single unit until all of the payments are received. I will be responsible for giving them the list of buyers and then you are will make the payment to Cort ([email protected] and (949) 388-4442 ext. 122). He's the Director of Sales for Innovate. If you want me to add you to my GB list, send me an email. We currently have 5 potential buyers on the MR2 board.
Tim
Old 08-15-2003, 01:53 PM   #72
amelnikov
Member#: 9827
2002 WRX Wgn 292whp
Alex Performance
Sent you an email. Basically I want in on the GB.
Thanks,
Alex...
amelnikov is offline   Reply With Quote
Old 08-15-2003, 03:07 PM   #73
crash
Member#: 1440
05 LGT Wgn; 04 FXT
BDSM -- Birmingham, AL
Does anyone have any specifics about the to be released LM1-x?
Specifically what the EXACT differences will be (teh website is a bit vague) and what the display unit will look like?
Thanks,
Nathan
crash is offline   Reply With Quote
Old 08-16-2003, 09:48 AM   #74
misterblu
Member#: 39054
Thanks,
Nathan
I believe the LM-1x is supposed to be better suited to permanent installation in a vehicle (different grounding scheme, etc.) as opposed to the portability of the LM-1.
There is an illustration of the proposed display unit in the online manual at http://www.innovatemotorsports.com
HTH,
Jon
Old 08-17-2003, 08:42 AM   #75
EMS
Member#: 14116
Klaus,
Nice product!
Is it possible to setup one analog output to show a signal that a 1V O2 sensor would produce?
I ask this because I want to replace the standard 1V sensor and have the possibility to "feed" the cars ECU, so the lambda control is still working.
Mark.
EMS is offline   Reply With Quote
[FS]Brand New - Wideband O2 Sensor/Hood Scoop/Gasket kit. Pumpastic Engine/Power/Exhaust 1 08-04-2007 06:30 PM
Brand New Zeitronix Wideband O2 w/ LCD MajorAgee Private 'For Sale' Classifieds 7 10-13-2004 11:28 PM
New TechEdge Wideband O2 kit STFUTuning Private 'For Sale' Classifieds 7 11-19-2003 12:47 AM
1-New TechEdge Wideband O2 kit MauroMotorsports Vendor 'For Sale' Classifieds 7 09-11-2003 04:17 PM
New AEM wideband o2 sensor ThuotRDX Engine Management & Tuning 1 07-23-2003 12:06 PM
