Welcome to the North American Subaru Impreza Owners Club Monday February 8, 2016
Old 08-28-2003, 01:51 PM   #126
gadget951
Member#: 18419
WR Blue
Just talked to Cort and I am number 9 so after the next person he will be able to ship on Tuesday.
So 8Complex call soon and you can get yours out too.
Scott
gadget951 is offline   Reply With Quote
Old 08-28-2003, 04:48 PM   #127
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Damn, I went to call in and Cort was out of the office. Well, I hope that he stays a little later in the office tomaro... I don't wake up until 1pm or so. :-/
Old 08-28-2003, 06:39 PM   #128
TBeck2000
Member#: 40753
Sorry 8, but the #10 slot has apparently been filled by someone on the MR2 board (at least he posted at 1:52 pm EDT that he was). Hopefully group 2 will pay quickly.
Tim
TBeck2000 is offline   Reply With Quote
Old 08-28-2003, 08:54 PM   #129
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Damn... well did anyone have an idea as to the ETA of the second batch? I think I read that the first batch was going on Tuesday...
Old 08-28-2003, 10:00 PM   #130
gadget951
Member#: 18419
WR Blue
Call him tomorrow and see if he can add yours to this batch. There should be no reason why he can't.
Scott
Old 08-28-2003, 10:37 PM   #131
turboICE
Member#: 33979
2006 STi,'11 OBS
WRB & Black/Silver
I think it would be a very reasonable request that all payments by tomorrow noon go out Tuesday. Shouldn't be a big deal to send out 12 or 13 instead of 10.
turboICE is offline   Reply With Quote
Old 08-29-2003, 03:38 AM   #132
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Yeah, hope so.
I was thinking about it tonite, a well... I'm just going to try it just past my turbo in the downpipe since there is already a bung there with just a plug in it and if I get errors, then I'll move it when I get the chance. *shrug* The things I do to get this thing running right.
Old 08-29-2003, 05:45 AM   #133
I am mattjk
Member#: 36411
I can be PM'd at
"mattjk"
OK, i read the posts but I hope I didn't miss the answer... can the Bosch sensor be installed to run all the time?
My buddy has the Motec meter, with a Bosch sensor (similar sensor I'm assuming) and the manual recommends not to use 100% of the time.
Matt
I am mattjk is offline   Reply With Quote
Old 08-29-2003, 06:06 AM   #134
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
I'm not sure why most of the wideband companies recommend not using the sensors all the time... after all, they ARE all OEM sensors that are out there on existing cars. The NTK sensors are stock on 95 Honda Civic HX (lean-burn) models, and the Bosch sensors are stock Volkswagon components. Personally, I'm going to install mine permanently... even if it does burn out, they're only $30!
Old 08-29-2003, 01:27 PM   #135
Drac9
Member#: 9861
1999 2.35 RS-T w/NOS
Hybrid Rally Blue Pearl
I put my sensor in the bung in my uppipe- before the turbo. No sensor errors so far. Seems very accurate
Drac9 is offline   Reply With Quote
Old 08-29-2003, 01:29 PM   #136
I am mattjk
Member#: 36411
I can be PM'd at
"mattjk"
hmmm, I need to get the part number off the Motec unit, because that particular sensor is around $300.
http://www.motec.com/products/plm/plm.htm
They charge around $1050 for the Motec with the Bosch LSU sensor, and $1350 for the Motec with the NTK UEGO sensor.
Old 08-29-2003, 03:00 PM   #137
TBeck2000
Member#: 40753
If you read here: http://www.motec.com/products/plm/sensors.htm, Motec says that these sensors only have a life of 500 hours on unleaded fuels!! How would OEMs (VW and Honda) use these sensors if they foul after such a short duration? My old FJO had the same warning, and it used the NTK L1H1 that I believe is used in some Hondas. I never experienced any problems, but I only used it for a total of 20 hours.
I, personally, intend to install the Bosch sensor permanently and replace them when the need arises.
Tim
Old 08-29-2003, 03:14 PM   #138
turboICE
Member#: 33979
2006 STi,'11 OBS
WRB & Black/Silver
I think those hours quoted by tuning WBO2 kits are for within original spec performance - but am not sure. Both O2 units adverise much longer MTBF on their manufacturer websites. I suspect their accuracy may fall out of original spec before the point where manufacturers consider there to be an error. Lab grade and lab spec performance is less tolerant than the specs required for OEM usage. And the advice on usage of the aftermarket sensors is for those who are using their tuning kits for competition or to make a living - most dynos certainly don't use them much past 500 hours even if they use for only unleaded.
I also can't get my hands around the OEM vs. aftermarket sensors - the OEM are so much less expensive I have to imagine there is some difference other than the manufacturer part number. Certainly tech-edges has tenatively determined some differences.
Old 08-29-2003, 03:26 PM   #139
TBeck2000
Member#: 40753
We interrupt your regularly scheduled discussion for the following announcement:
TBeck2000's Innovate LM-1 GB is CLOSED
Just moments ago, I sent the final list of participants to Innovate. We ended up with 36 participants and 38 units purchased Sorry if you didn't get in, but I'm sure Innovate is still willing to sell you an LM-1
Sorry for the interruption.
Tim
Old 08-29-2003, 03:30 PM   #140
turboICE
Member#: 33979
2006 STi,'11 OBS
WRB & Black/Silver
Can't wait for that CA vote count.
Old 08-29-2003, 04:39 PM   #141
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Sweet, just got off the phone with Cort and I'm in for delivery next week.
Tim - Forget to tally up an entire board worth of buyers before?
Old 08-29-2003, 05:05 PM   #142
turboICE
Member#: 33979
2006 STi,'11 OBS
WRB & Black/Silver
Great to hear 8, hopefully in time to tune for your event.
Old 08-29-2003, 05:35 PM   #143
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Yeah... I had about a week to tune before the East Coast Shootout. It's a shame there isn't a stock-block RS-T catagory there... I really think I'd take it. I may not run though since there is no reason and breaking the car 800 miles from home would suck.
At least it'll be a great test for the new wideband setup, though. I'm hoping to pull mid-high 20's for mpg... which'll be a feat since the best I've gotten since putting the Haltech in was 19.7mpg.
Old 08-29-2003, 10:12 PM   #144
Jon [in CT]
Member#: 2992
02 WRX Sedan
I just noticed that Innovate has established a message board for discussion of the LM-1:
http://autos.groups.yahoo.com/group/InnovateLM1/
I suggest that questions/discussion about the group-buy continue here and that technical questions about the LM-1 or its sensor(s) be directed to that message board.
Jon [in CT] is offline   Reply With Quote
Old 08-31-2003, 10:04 PM   #145
gadget951
Member#: 18419
WR Blue
I have been thinking of getting the Ecutek Delta Dash. Could you hook up the aux out of the LM-1 to the rear O2 sensor input on the ECU and be able to data log it that way? It may throw a CEL but it should work if that sensor can be recorded right?
Scott
Old 08-31-2003, 10:47 PM   #146
turboICE
Member#: 33979
2006 STi,'11 OBS
WRB & Black/Silver
Theorectically yes and possibly just maybe without a CEL.
But the input would need to be scaled to 1 v, calibrated to the stoich the ECU expects and would only report the voltage I don't think the AFR conversion would be accurate. LabJack and a dedicated bung would be a better way with DD.
Old 09-03-2003, 12:53 PM   #147
wrxdaddy
Member#: 14164
02 Impreza Wgn
95 L Project in progress
Anyone know the shipping status for the 1st group?
wrxdaddy is offline   Reply With Quote
Old 09-03-2003, 02:31 PM   #148
wop138
Member#: 7796
So I had found an article somewhere explaining Subaru's o2 sensor... (I wish i remembered the pdf link, it may have even been on this thread) but the ecu expects a certain voltage when it should be reading rich, and it can't go any higher than that, the same goes for the lean reading of the factory wideband... I don't know if you can tell this bad boy to do that, but if you can... then you could probably log through delta dash?
PS: I claim to be an idiot for all of your safety. I'll look some more for that article so you can read it for yourselves...
wop138 is offline   Reply With Quote
Old 09-03-2003, 02:37 PM   #149
turboICE
Member#: 33979
2006 STi,'11 OBS
WRB & Black/Silver
The articles were posted by Jon in this thread. They are regarding the front O2. This particular question was geared towards use a rear O2 bung - like in a cat-delete and fake the 1v NB signal to the ECU. The ECU is less picky about the rear it just wants to see stoich when under certain parameters and could care less what it reads other times.
Old 09-03-2003, 08:11 PM   #150
wop138
Member#: 7796
Hehe that's what I get for not rereading the thread... It was the thing that popped to mind when I read the question... Hopefully i didn't mislead anyone!
--fed
[FS]Brand New - Wideband O2 Sensor/Hood Scoop/Gasket kit. Pumpastic Engine/Power/Exhaust 1 08-04-2007 07:30 PM
Brand New Zeitronix Wideband O2 w/ LCD MajorAgee Private 'For Sale' Classifieds 7 10-14-2004 12:28 AM
New TechEdge Wideband O2 kit STFUTuning Private 'For Sale' Classifieds 7 11-19-2003 01:47 AM
1-New TechEdge Wideband O2 kit MauroMotorsports Vendor 'For Sale' Classifieds 7 09-11-2003 05:17 PM
New AEM wideband o2 sensor ThuotRDX Engine Management & Tuning 1 07-23-2003 01:06 PM
