#26 |
Member#: 5917
NESIC
Vehicle:95 Impreza Type L That blueish color |
Just wondering does anyone know if RS half shafts will fit a 96 wrx wagon diff? I was told that the wagon had 4.11 and had LSD. Can anyone confirm this?
#27 |
Member#: 11620
Vehicle:1997 GF4 -STiV3 Saab 93 TX sportcombi |
Little off topic, but I just looked up the price of 22011GA022 - 3.90 clutch-type LSD off XT-6. They want $3,108 plus shipping. Sweet.... I'll take 3!
#28 |
Member#: 26067
Vehicle:2003 WRX Open Sourced |
you can switch out LSDs without changing the gear ratio right?
#29 | |
Member#: 86715
Vehicle:2001 GM6 RS Silverthorn |
#30 |
Member#: 15918
NWIC
Vehicle:08 STI/02 PGT WRX DGM / Orange |
I haven't seen an answer to the anywhere from my searching - I was wondering if anyone knew whether/which of the viscous LSD units for the R160 from various US/JDM Subaru models are the same. No talking gear ratios here, but the slip torques and other LSD characteristics. Basically, I wondering if some are stiffer than others. I have a V2 Sti RA one laying around here for example, but unfortunately the splining / retainer clips don't match up with my axles
#31 |
Member#: 26791
NWIC
Vehicle:1990 JUSTY!! white and black |
will a 01 legacy rear lsd bolt into my 93 LS wagon? I figure it does.. just want to check before i jump on it.. thank you
-trevor |
#32 |
Member#: 177
NWIC
Vehicle:The 93 Imp W/EJ20K flat black |
you will need differnt axels
#33 |
Member#: 26791
NWIC
what axles will work? i have an LS wagon w/ ABS now. Other than the axles, I need a different bracket to hold it in right? what bracket?
#34 |
Member#: 5218
Vehicle:96L Most Over- Developed Beater |
Just the axles. Everything else will bolt up to your 93. Do you have stubs on your diff now? (you'll have rollpins just outside the diff) If so I may trade you for some 98RS axles that are believed to work with the VLSD diffs.
Jay Storm |
#35 | |
Member#: 19239
International
Anyone know if you can rebuild rear axles?? Not the universal joint at the hub but the tripod joint at the diff end?? Last edited by kingsubi; 11-17-2006 at 08:25 PM. |
#36 |
Member#: 26791
NWIC
#37 |
Member#: 91748
SWIC
Vehicle:1989 GL Touring wgn Rose Red |
-> Hi, I saw the final drive for the WRX up to 2004, do you guy know about the 2006's? Thank a lot guys!
#38 |
Member#: 66739
Vehicle:2002 WRX wagon silver |
JDM V4(98) STi has 4.444 and LSD using male axle style.
i know theres some V4's around(not sure if they got the same diff tho). |
#39 |
Member#: 74041
Vehicle:2006 SV650 Weeeee Officer Farva|Car Ramrod |
I'm with him, but I actually need to know what my center differential and rear open differential final drives are (ie if center is 1.0:1 and rear is 4.111 or w/e) I have the 2.5i 5MT non-turbo. I can't find this info in any of the stickes.
#40 |
Member#: 129970
Vehicle:1996 328is schwartzII(black) |
How would this affect handling? Im not used to the handling dynamics of awd cars, i've tracked with e36s and miatas with and w/o lsd but a rear lsd with slipping front, would that help the car rotate out of corners?
THe reason i ask is because I'm looking into buying a 2.5rs to build into a doubleduty street/trackable car and the 98 im considering doesnt have a rear lsd(i think). [/hijack] |
#41 |
Member#: 163445
Vehicle:l33t ******* 12.07@115.9mph-EJ205 |
Since I can't post a New Topic and its not covered here. I have a JDM V7 STI LSD Rear Diff New in the Box. What are the differences between this diff. and my stock 02 WRX differential? Are they similar? Could I swap the R180 V7 Differential into my 02 WRX?
The reason I ask, I have 80k on my 02 and I'm pretty sure the limited slip has seen better days, and this is a brand new unit. |
#42 |
Member#: 141189
Vehicle:2007 Impreza 2.5i Newport Blue Pearl |
Hey I have a 2007 2.5i and I was planning on putting an LSD in the rear. I had looked around and it doesn't seem like Subaru made many 3.90 r160's...looks like Subaru loves the 4.11/4.44. Is there a way to put a 2002+ WRX rear lsd on the car and just swap out the ring and pinion (the ones from my open diff and put into the wrx lsd)? or is there more work then just that?
#43 |
Member#: 33782
Vehicle:96 bastard child search FIRST, then PM!!! |
yes, you can simply swap the differential into your case or you ring and pinion into it...just be sure to set the lash properly....you'll probably want to have a tech do it if you don't have the tools.
#44 |
Member#: 177
NWIC
start asking for shops that will do before you buy it
its not a simple task .. pretty ugly actually |
#45 |
Member#: 33782
#46 |
Member#: 59080
NWIC
Vehicle:90 Legacy L+ |
Seems easier to swap the ring to the lsd and put that into the case. It avoids messing with the pinion.
#47 |
Member#: 182337
Vehicle:1997 Impreza Outback Sport -- White |
so does anyone know the final drive ratio of the 1995 Impreza L 5 speed?
#48 |
Member#: 5218
It should be 3.90:1
Jay |
#49 |
Member#: 191193
My research shows that there were 3.083 and 3.272 VA2 type LSD diffs produced for export on the Legacy and Outback with the 3.0L. Has anybody seen these, know where to get one, and know if they can be swapped into a US domestic T-Type LSD diff?
I'm building a custom rear end out of Subaru parts for a project car, and I need lower gearing than the 2002 WRX's 3.54 to match the bike engine I want to install. |
#50 |
Member#: 166898
W. Canada
Vehicle:1994 T leg SS ABM |
Male axles?
Ive got a 99RS diff sitting in my basement, it has two holes for the axles to go into i spun the front and both sides turned, does this make it a LSD? |
| Thread Tools | |
| Display Modes | |
| '02 WRX 6 spd STI Conversion with r180 rear LSD & DSS (Drive Shaft Shop) Rear CVs | nissaneng | Transmission (AT/MT) & Driveline | 16 | 03-17-2010 01:39 AM |
| Car came with intake, what AP options do I have? | ST3 | Factory 2.5L Turbo Powertrain | 1 | 04-02-2006 12:25 AM |
| 4.11 Tranny with Matching Rear LSD Diff | JoeT | Private 'For Sale' Classifieds | 17 | 02-10-2005 04:31 PM |
| Are the painted side skirts the same size as the plastic ones that my car came with? | RyanRock | Interior & Exterior Modification | 5 | 05-13-2004 06:33 PM |
| I wish my car came with a hand gun accessory | Stroke | Off-Topic | 9 | 09-05-2003 12:55 PM |
