Old 07-09-2005, 02:39 PM   #51
RalliSpec
Member#: 39
98 Prodrive WRC
Please keep in mind that JDM applied model code information does not exactly match US applied model codes which doesn't match European/Australian applied model codes, etc.
In Japan "GC" is used for both 4 and 2 door models while in US they chose to designate the 2 door with a different code "GM".
Also, the 4th digit designates the series or year. For example:
GC8G4FD ... the "G" in the 4th position indicates it is a 2000 MY (Version 6). Production dates for JDM GC/GF series are:
"A" = 11/92 - 09/93 or Model year 1993
"B" = 10/93 - 08/94 or Model Year 1994
"C" = 09/94 - 08/96 or Model Years 1995 and 1996... MY 1996 was assigned Version 2 by STi
"D" = 09/96 - 08/97 or Model Year 1997 ... STi assigned this year Version 3
"E" = 09/97 - 08/98 or Model Year 1998 ... STi Version 4
"F" = 09/98 - 08/99 or Model Year 1999 ... STi Version 5
"G" = 09/99 - 07/00 or Model Year 2000 ... STi Version 6
When the GD/GG series Impreza was released in 2001 the series started over at "A" again. STi no longer applied a designation of "Version XX"...this is something that everybody else chose to continue in the interest of easy reference. In the US the series designations rarely correspond exactly to JDM designations because we often get a model a year behind Japan.
Continuing on....the 5th digit of the applied model code, as someone mentioned, indicates the number of doors. The 6th and 7th digits indicates specific equipment packages.
Regarding engine codes....these can be found on the timing cover sticker or on a sticker located on the back of the cylinder head. There are usually other numbers and such stamped into the block and head castings but these are production numbers and are not easily used for identification purposes. The engine codes used for identification should start with "EJ" for any of the later Subaru applications (Impreza, Legacy, Forester, SVX, etc.).
Digit 1 & 2...."EJ" indicates that it is one of the current boxer series motors. The EJ series started production in the mid/late eighties.
Digit 3 & 4.... displacement in liters. Example 2.0L = "20"
Digit 5.... engine series and fuel system used.
Digit 6....emissions regulations.
Digit 7....transmission type the engine was designed for. "W" = manual trans, "X" = auto trans
Digit 8,9, and 10 ...indicates minor production changes or various specification differences.
For example....ej2070w2pr-14e 917 639 gh10
This is 2.0L EJ-series motor from STi ("7" in 5th digit indicates high output version of the 2.0L MPI turbo motor used from 1999 on). I am guessing the 6th digit is a "D" and not an "O" like you indicated which would indicate a JDM spec. The "W" would indicates is out of a manual trans car. The "2" would indicate its a Version 6. The "PR" indicates that it is a standard STi (not an RA which would be "PJ"). The rest of the numbers after the dash are probably some serial number for the actual engine.
Transmission identification codes start with a "T" and an example would be:
TY856WB1AA
"T" = transmission code
"Y" = that it is a manual awd gearbox
"85" = the transmission classification...in the case of manual gearboxes this number indicates the gear shaft spacing in millimeters. 6-speed transmissions use an 85mm shaft spacing while the current generation of 5-speed transmissions use a 75mm shaft spacing.
"6" = some reference to the transmission case. "6" is used for 6-speeds, "4" is used for 8-bolt 5-speeds, "2" for 4-bolt Impreza 5-speeds, "5" for Forester 8-bolt 5-speeds, "3" for 4-bolt Forester 5-speeds, and "7" for some Legacy turbo 8-bolt 5-speeds.
"W" = transmission specification. "W" is 6-speed, "V" is 5-speed, "Z" = AT with MPT, "Y" = AT with VTD, etc.
"B1AA" = indicates various details about the equipment such as center diff. type, front LSD, etc. and also about minor production changes.
We have an extensive listing of transmission code information on our site at http://www.rallispec.com/Transmission%20chart.htm
--Dave
RalliSpec
RalliSpec is offline   Reply With Quote
Old 07-19-2005, 10:47 AM   #52
gusto
Member#: 58323
EJ20GDW1NY-E6
1998 jdm forester XT but whats the "1NY-E6" mean?
gusto is offline   Reply With Quote
Old 09-18-2005, 04:24 PM   #53
DiscoWagon
Member#: 84516
'12 Tony Kart EVRR
'99 E36 M3 Estoril Blue
what is the chassis code for 06 WRX and Sti?
DiscoWagon is offline   Reply With Quote
Old 10-03-2005, 04:56 PM   #54
JoshP
Member#: 94350
I dont know if this has been covered or not but '94 Legacy GT is BJ. J is for the raised roof.
JoshP is offline   Reply With Quote
Old 12-02-2005, 04:58 AM   #55
d_mcleod00
Member#: 95241
2000 GC6 2.5 RS
Sedona Red
Found out I was wrong. Car's a GC6
d_mcleod00 is offline   Reply With Quote
Old 02-22-2006, 10:25 AM   #56
sammydafish
Member#: 77523
95 Legacy Wagon
what about raised roof wagons... don't they have different chassis codes?
sammydafish is offline   Reply With Quote
Old 03-15-2006, 07:04 PM   #57
DerFahrer
Member#: 30727
2000 Legacy B4 RSK
*Formerly subyluvr2212*
On that note, the Legacies need revising.
If you want to get technical, the first generation of Legacies are BC/BJ. The BF is the raised-roof wagon, which was the 94 GT wagon, which is likely the rarest first-gen wagon in America. Just about every first-gen wagon you will come across will have BJ in the VIN.
The second-gen of Legacies is right, and it goes back to the raised-roof. The OUTBACKS were raised-roof, therefore they were BG's. The LEGACIES were not raised-roof, therefore they were BK's.
ALL 3rd-gen wagons were raised-roof, so they all received the BH designation, and all 4th (current) gen wagons are raised-roof, so they get the BP designation.
DerFahrer is offline   Reply With Quote
Old 04-26-2006, 03:52 AM   #58
wrxfactor
Member#: 49978
2002 WRX w/ JDM STi
6spd, EJ255, VF39 & EWG
EJ20XDKJCE-006 517612 3W 10
Any chance you could help me out with that?
wrxfactor is offline   Reply With Quote
Old 10-03-2006, 12:29 PM   #59
IniTiaLScooby
Member#: 116672
2004 Impreza WRX
San Remo Red / DCSOC
damn hard to follow for me. so my 04 wrx sedan would be ?
IniTiaLScooby is offline   Reply With Quote
Old 10-11-2006, 10:34 PM   #60
Subaru_555
Member#: 108199
Does someone have a tables to summarize with all these letters and numbers on it?
Subaru_555 is offline   Reply With Quote
Old 11-07-2006, 11:47 PM   #61
nastiaz04
Member#: 115043
2005 WRX
Obsidian Black Pearl
So my 2004 sti would be a gdf or a gd7? which one?
nastiaz04 is offline   Reply With Quote
Old 11-16-2006, 01:13 PM   #62
Wiscon_Mark
Member#: 94945
2012 Impreza
Sport Limited DGM
bump for a correction:
BC- 89-94 Sedan
BJ- 89-94 Wagon
BF- 89-94 Wagon w/ raised roof
And for the BK/BG difference, the 96-99 Outback is a BG because it has a raised roof as well. The BK is the wagon without a raised roof.
Wiscon_Mark is offline   Reply With Quote
Old 12-11-2006, 04:03 PM   #63
stoney98
Member#: 65888
2010 FXT
ok, just to clarify, a 2003 Impreza TS 2.5L Wagon would be GGE6?
Please don't hurt the noob....
stoney98 is offline   Reply With Quote
Old 12-15-2006, 01:47 PM   #64
5.0Ranger
Member#: 93546
08 wrx
pearl white
Hey when you listed all the motors and codes in the first post, you forgot the big bad 2.7L SOHC H-6. You know the flat 6 that can in those bad ass fliying wedges, The XT6. I dont know any codes or any of that, but i do know that it does NOT have the same bell houseing as the Wrx. I was tring to mate it up for a sand rail project, and it will not go. The 2.7 H-6 only has 4 bolts that hold the trans to the motor. The wrx trans i have has like 6 or 8 bolts the hold it to the motor.
5.0Ranger is offline   Reply With Quote
Old 12-27-2006, 10:09 PM   #65
Chi_San
Member#: 53558
2002 WRX Wagon
And the Baja is??? Or does the Baja just use a Legacy code?
Chi_San is offline   Reply With Quote
Old 12-30-2006, 11:56 PM   #66
Dokturseuss
Member#: 102009
1999 impreza
man i have been calling my car a gc this whole time but its a gm Darnit
gm4 to be correct
Dokturseuss is offline   Reply With Quote
Old 02-01-2007, 01:10 PM   #67
IllNastyImpreza
Member#: 36333
98 2.5RS
tuning student...
good to know...I guess I really am a GM6
IllNastyImpreza is offline   Reply With Quote
Old 03-06-2007, 03:06 PM   #68
rallifan
Member#: 132786
2001 Impreza TS
Artic Silver Metallic
rallifan is offline   Reply With Quote
Old 03-10-2007, 06:43 PM   #69
left footed whooten
Member#: 44652
06 WRX
16 Colorado Duramax comin
^^^still not A) 100% accurate B) updated C) easy to understand. My 06 WRX wagon is a GG7, nothing lines up with an Impreza WRX wagon with 2.5Turbo and 5MT.....looks like everything needs a big updating.
left footed whooten is offline   Reply With Quote
Old 03-11-2007, 07:05 PM   #70
rvanbran
Member#: 6687
So what if you don't have the VIN tag ?
I have a DOHC EJ25 in my beetle, but I don't know exactly what year it's from.
There is a casting # near the transmission: "026 149"
Any ideas ?
Rob.
rvanbran is offline   Reply With Quote
Old 04-22-2007, 09:03 AM   #71
dja_rs
Member#: 146538
Top info, helped me id some gear. CHeers
dja_rs is offline   Reply With Quote
Old 06-21-2007, 07:15 PM   #72
Bugeye02rex
Member#: 150626
this might be a little off topic but what are the S202-S204? are they special modles or just the j-spec?
Bugeye02rex is offline   Reply With Quote
Old 06-22-2007, 01:36 AM   #73
IllNastyImpreza
Member#: 36333
98 2.5RS
tuning student...
Originally Posted by rallifan View Post
crazzy that an encyclopedia would get that detailed into something like a Subaru VIN
Old 08-18-2007, 01:55 PM   #74
mgfe
Member#: 58425
whats this then??
vin- gc8-018657
applied model- gc8b48d
option code- bj
engine code- ej20gdw2he
transmission code- ty752vb3ca
turbo- tdo5h
bonnet- alloy
control arms- alloy
final drive- 4.444
mgfe is offline   Reply With Quote
Old 11-16-2007, 09:15 AM   #75
schrott
Member#: 164010
97 gfc sport
blue n' grey
ok, so my plan is to make my GF into a GFF. did i say that right ? and would it work ? im new to subi's and havn't gotten it all figured out yet. could i drop in the 2.5l turbo engine from the STI of a newer model year, or do i have to get something within my age bracket ? (the object is to avoid doing the motormount shuffle)
thanks
schrott is offline   Reply With Quote
2009 Legacy/Outback Model Codes and Colors Jon [in CT] News & Rumors 86 05-14-2008 09:56 PM
piston slap: and what does it mean to you? WRXwannbe Normally Aspirated Powertrain 16 02-02-2006 05:48 PM
p1086 cel will it cause this (read)? and what does it mean suprasingle Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 11-09-2002 02:31 PM
H-R-W-XYZ....ratings..what do they REALLY mean? GooseMan Brakes, Steering & Suspension 9 02-08-2002 02:25 PM
whats the different types of computer controled air/fuel devices and what they do? v6scoobie Technical Forum Archive 1 09-09-2000 05:38 PM
