Old 07-19-2003, 04:31 PM   #1
SubaFastR
Member#: 5786
Default fuel and pollish
Pulled off my manifold and polished it. Cleaned up the ports inside too. I really can feel a difference from the porting. Not a lot, just feels like an exhaust or new plugs have been added. Also did the dual feed fuel lines while I was in there. Anybody have a Legacy turbo crossmember out there? My STi Ver 8 vf37 with manifold should be in very soon.... can't wait for boost baby!!!
Kevin
SubaFastR is offline   Reply With Quote
Old 07-20-2003, 12:52 PM   #2
Surb00
Member#: 27132
1999 2.5 RS-T
Rally Blue
What did you use to polish the manifold?
Surb00 is offline   Reply With Quote
Old 07-20-2003, 02:59 PM   #3
SubaFastR
Member#: 5786
Die grinder with 50 grit sanding rolls, 80 and 120 grit flapper sanders used with an electric drill.(my compressor isn't big enough) lots of sand paper including 120, 220,320,440,600, 1000,1500 and 2000. I then buffed it with the buffing wheel. Don't bother unless you have A LOT of time and patience.
wtb: ++ DEFI Gauges Amber BF - Fuel and Oil Pressure and A-pillar pod ProdriveRex Private 'Wanted' Classifieds 6 03-26-2008 12:28 AM
FS: Apexi S-AFC and AVC-R Fuel and Boost Controllers: TheWRXMan South West Impreza Club Forum -- SWIC 1 02-11-2004 01:27 PM
Link master fuel and fuel flow% question paulw Engine Management & Tuning 2 07-17-2002 06:14 PM
PCIII and Split Second ... Adjust fuel and timing Black 2002 WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 05-06-2002 09:09 AM
Which fuels and oils do you use? DrunkMonkey Normally Aspirated Powertrain 13 07-28-2001 11:48 AM
