Old 07-19-2003, 05:35 PM   #1
element533
Member#: 37575
2012 WRX Std 4D
Question Upgrading brake fluid to DOT 4
Does anyone know of a good brake bleed guide? All I currently have to go off is the Subaru service manual, which is far from verbose.
element533 is offline   Reply With Quote
Old 07-19-2003, 06:36 PM   #2
vile
Member#: 32371
'02 t-rex wagon
platinum
for something cheap and good, use valvoline synpower brake fluid
as for bleed order, for the wrx, it's:
RF
LR
LF
RR
vile is offline   Reply With Quote
Old 07-20-2003, 09:20 AM   #3
ImprezaVA
Member#: 32846
1998 Impreza L-SOLD
Arcadia Green
Default DOT 4 vs. DOT 3
Another Subaru enthusiast told me that DOT 4 gets dirtier quicker than DOT 3. Yes, we all know that DOT 4 has a higher boiling point, but be prepared to change it more often. Growing up, I never remembered being around many people who actually maintenance their brake fluid besides a top off. I guess Subaru owners are more meticulous with their cars than most. Good luck with your project.
-Charles-
ImprezaVA is offline   Reply With Quote
Old 07-20-2003, 10:09 AM   #4
dpmurraygt
Member#: 32928
2003 WRX Wagon
Sedona Red
DOT4 fluids generally absorb water more quickly than DOT3.
Make sure you look at wet and dry boiling points for the fluid you buy - and don't choose one based on dry boil point alone.
dpmurraygt is offline   Reply With Quote
Old 07-20-2003, 11:18 PM   #5
vile
Member#: 32371
'02 t-rex wagon
platinum
Default Re: DOT 4 vs. DOT 3
-Charles-
get yourself some speed bleeder screw, i can bleed my brakes by myself in under 30 minutes
Old 07-21-2003, 10:06 AM   #6
ImprezaVA
Member#: 32846
1998 Impreza L-SOLD
Arcadia Green
Default bleeding brakes
I was thinking about getting a one-man bleeder/vacuum pump. I'm not taking any brake lines apart so this isn't something of high priority at the moment. I've read about those speed bleeders and its good to see that they actually work pretty well.
-Charles-
which brake fluid to run? EntrustXXX Brakes, Steering & Suspension 2 05-11-2005 12:56 PM
How to change brake fluid to Motul 600 ChinkyWRX Service & Maintenance 19 03-18-2005 05:10 AM
What is the best brake fluid to get? donut Brakes, Steering & Suspension 41 03-19-2004 11:05 AM
How many ounces of brake fluid to switch fluid? Steppin Razor Brakes, Steering & Suspension 3 09-26-2002 06:36 PM
Which Brake Fluid to Use? silverSurfer Brakes, Steering & Suspension 21 02-03-2001 12:27 AM
