Southern California Impreza Club
Go Back   NASIOC > NASIOC Chapters > Southern California Impreza Club Forum -- SCIC
Old 07-19-2003, 06:36 PM   #1
STi-Nismo Dood
Member#: 4149
MY93 Impreza 6MT
GC8.6 Aspen White
Default broke FWD tranny, what do I need to bolt on an AWD?
I think I broke my FWD tranny... quite a dissapointment too (i like my tranny, its so light and saved me some whp)... I think this problem progressively became worse ever since I got a new stronger clutch 2 months ago... now I think I might of destroyed my tranny bearing (popping out of higher gears now).
If I find an awd tranny at a wreckyard... what other parts do I need in order to convert my broken FWD into AWD besides the actual tranny?
Tranny mount, Driveshaft, Clutch, Flywheel, Crossmember, Gas Tank... anything else? Do I need four axle assemblies also? You think $1000 would be around what they are selling/looking for from a wreckyard if I can get these parts all together? Thanks.
-Vic
STi-Nismo Dood is offline   Reply With Quote
Old 07-20-2003, 03:12 AM   #2
AWJunkies
Member#: 32934
99 2.5RS JDM WRX
I have a 99 subaru impreza 2.5rs parts: tranny, flywheel, pressure plate, clutch, throwout bearing, driveshaft, rear diff, tranny mount and crossmember. Basically I have everything! Anything else you need let me know. It is all for sale!
AWJunkies is offline   Reply With Quote
Old 07-20-2003, 03:21 AM   #3
awd1320
Member#: 17563
2002 1320 dogbox
12.052 @ 111.91 stock tur
hey bro let me know if you want to get rid of your fwd trans i need it to play around with wondering if your gettin rid of it for free let me know , hopefully first fwd wrx hahahah
awd1320 is offline   Reply With Quote
Old 07-20-2003, 04:20 AM   #4
STi-Nismo Dood
Member#: 4149
MY93 Impreza 6MT
GC8.6 Aspen White
the gears are up to par, the thing is the bearings are grinding... so you need to fix that. fwd 2.0? does that mean you need my flywheel and clutch?
Hey awjunkie, are you upgrading your gearset? I am interested, as my master mechanic is looking for one at a junkyard still...
Old 07-20-2003, 02:41 PM   #5
awd1320
Member#: 17563
2002 1320 dogbox
if you dont need it that would be great , just think your helping out someone making there subaru wrx fwd ready for 26 inch slicks and skinnies in the rear let me know ok
Old 07-20-2003, 07:29 PM   #6
TMRRALLY
Member#: 13177
1993 impreza
dirt
I really hope your joking..................but if your not, it would be easier to weld up the center diff. and just pull and plug the drive shaft. Thats what I did to do the RWD conversion on my wagon. Of coarce on my car I pulled the front axles, not the driveshaft.
Sean
TMRRALLY is offline   Reply With Quote
Old 07-21-2003, 01:22 AM   #7
awd1320
Member#: 17563
2002 1320 dogbox
i would love to weld up the diff seein that i already have a dogbox and would love to stay with the one i have but im not sure how well it would work being fwd if you know someone that knows what there doing and it will hold upwards of 900flywheel hp in the future let me know im seroius about doing it
Old 07-21-2003, 01:36 AM   #8
AWJunkies
Member#: 32934
99 2.5RS JDM WRX
upgrading gear set what you mean?
I have JDM tranny closer gear ratios.
I have US 2.5RS 99 tranny and all parts.
vf39 for an 18g on STi what do i need to get it right? taco_tom Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 09-01-2009 03:26 PM
What do I need to get 18x9 wheels to fit on an 05 wagon? ever12 Newbies & FAQs 18 04-15-2009 08:14 AM
What do I need to adjust on my EM to run the GM Boost Solenoid mrtrex Engine Management & Tuning 6 11-14-2005 12:00 PM
what do I need to the last nut & bolt to go turbo? 2.5rsDOHC Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 04-30-2004 10:34 AM
('93-'01) what do i need to do to try and get an autocross/Solo2 here...HELP! SuBaRu-ImPrEzA_RS Impreza Forum 2 06-03-2001 10:11 PM
