Old 07-19-2003, 08:39 PM   #1
Crimson
Member#: 23472
2004 STi
Default WRX Oil Pan on RS??
Hey
I am planning to do a Custom turbo on my 99 RS. I just wanted to know if a WRX oil pan will work on an rs? Would make things easier then tapping mine if I could just swap it.
Crimson is offline   Reply With Quote
Old 07-19-2003, 09:14 PM   #2
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
if you thinkthe oil return for the WRX is into the pan you'd be wrong. the oil return on those is in the back of the head, the WRX pan however is a higher capacity pan. and for the 99's you'll need a different water pump.
good luck
jeremy
Old 07-19-2003, 09:52 PM   #3
Crimson
Member#: 23472
2004 STi
Why would I need to change my water pump??? Thx for the answer about hte oil pan.
Old 07-19-2003, 10:31 PM   #4
halftendril
Member#: 27802
2000 impreza 2.5rst
you can buy one from www.ludespeed.com for a 140.00 shipped, just drop tom an email its been welded for the oil line and you wont have to tap your pan. pic http://www.ludespeed.com/products/su...cs/oilpan1.jpg
halftendril is offline   Reply With Quote
Old 07-20-2003, 08:17 AM   #5
Revision
Member#: 242
MY05 PSM GGA !STOCK
MY99 RS-RIP / MY95 MX-5
Yup, you gotta tap the WRX oil pan for the RS-T oil return.
Kartboy welds on a WRX oil pan for a RS-T conversion.
As for the water pump, you may see issues with the dipstick tube clearing the housing, but a few slight bends on the dipstick tube will fix it. Most people have not had issues.
Revision is offline   Reply With Quote
Old 07-20-2003, 03:04 PM   #6
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Sure, and at first you looked at me like I was nuts trying to bend those. Heh, a little manipulation of steel later and it's a perfect fit.
Old 07-20-2003, 03:44 PM   #7
Crimson
Member#: 23472
2004 STi
So would I be better off just having a oil return put on my stock pan or getting a WRX pan and having one added to it and having to bend the dip stick?
Old 07-20-2003, 03:59 PM   #8
ChicksDigWagons
Member#: 20508
1998 Red Wagon
New Turbo Project...
If you use a bulkhead fitting the procedure really isn't that difficult. You just drill a hole to the proper dimentions and tighten down the fitting with some sealant and thread locker. Its not the ideal setup, but if you don't have access to a welder of some sort, it will work.
-brad
ChicksDigWagons is offline   Reply With Quote
Old 07-20-2003, 07:40 PM   #9
yebokmj
Member#: 2213
1995 Impreza w/EJ255
Brilliant Red
Default WRX oil pan
I would go with the WRX oil pan it's also the same as all the DOHC 2.5 engines. Not only do they hold more oil but have more baffles. Therefore you will really limit your oil worries.
Joshua
yebokmj is offline   Reply With Quote
anyone change a wrx oil pan to sti oil pan? 1WRX2NV Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 12-30-2007 09:32 PM
I can put a WRX oil pan on a STi motor, right? TROLL Built Motor Discussion 9 12-12-2006 03:55 AM
WRX oil pan on a turbo legacy? serious Subaru Conversions 7 11-14-2005 09:35 PM
WRX Oil pan on a 99rs Bobalouy Normally Aspirated with bolt-on Forced Induction Powertrain 24 04-19-2004 12:59 PM
More WRX oil pan on a RS pics /w turbo oil return Revision Normally Aspirated with bolt-on Forced Induction Powertrain 0 09-08-2002 04:40 PM
