Old 07-19-2003, 08:55 PM   #1
lotusTT
Member#: 23359
2002 BMW M Coupe
Steel Gray
Default turbo and voltage clamp questions
question #1. For running 4-10 psi, what turbo do you recommend? I currently have a VF34 (not installed yet), but this seems like overkill. Is there something smaller that would provide better results?
question 2. Has anyone ever built their own voltage clamp for the MAP? Any leads as to where to find the voltage it needs to be clamped at? If not, where's the best place to buy one?
lotusTT is offline   Reply With Quote
Old 07-19-2003, 09:07 PM   #2
boysetsfire
Member#: 6218
2001 2.5rs-t
silverthorn metallic
I have a split second voltage clamp i can sell you. Let me know.
-Marc
boysetsfire is offline   Reply With Quote
Old 07-23-2003, 10:56 PM   #3
ImprezaRS dot com
over boosted again
Member#: 1458
2015 Forester 2.0 XT
2005 2.5 RS, 2013 Tribeca
I have had great results with VF22 kits for the RS turbos, and we got 202whp at 5.8 psi from one with air water IC and 2.5" downpipe with 2 cats. This was at 6000 feet which gives us thinner air and less power.
On my car boost started as low as 2000-2200 rpm, and was 5 psi by 2600rpm, and I got 14 psi by 3000rpm on mine, with the 3" dowpipe!
My personal VF22 kit with AWIC is actually for sale now, email if interested. I could work out a trade for your VF34 and cash, or keep the VF22 and have you use your VF34.
Also, don't bother making your own MAP voltage clamp - ProECM and I tested a zener diode clamp against their voltatge clamp, and the zener diode clamp is unstable - the longer it clamps the MAP voltage as you stay on the gas, the lower the voltage going to the ECU and the leaner you run! AFR and EGT went bad.
A ProECM powerchip comes with the voltage set to limit MAP signal to 34 inches of mercury and will allow the ECU to retard timing and raise injector duty cycle for the low boost it is seeing. So, in testing when I ran normal fuel pressures the EGT's stayed under 1500 in a WOT run to 120mph at 5-7 psi, with just a proECM, walbro fuel pump and stock FPR. This is at 6000 feet so your results may vary, but certainly with 70-75 psi of fuel pressure from a RRFPR you should be fine at sea-level for 5-6 psi with stock timing.
Larry
ImprezaRS dot com is offline   Reply With Quote
Old 07-23-2003, 11:45 PM   #4
akcel
Member#: 10268
gc8 I ride ride 24s
with the top down low.
i too have an ADJUSTABLE voltage clamp split second
akcel is offline   Reply With Quote
Old 07-24-2003, 02:27 PM   #5
cRayZee
Member#: 6271
2001 2.5RSTi
2007 Legacy Spec B
I think the voltage clamp holds somewhere ~5V. I don't recall the exact voltage. If you're a skilled Electrical engineer, you can probably figure out how to make your own voltage clamp. Having a Zener Diode alone as a clamp probably drew too much current from the signal line, thus reduced the voltage the ecu sees.
cRayZee is offline   Reply With Quote
Old 07-24-2003, 02:45 PM   #6
Wedge
Member#: 2279
2000 Slingshot
Pastelito Racing
4.75v - 4.8v is around where we had ours.
Wedge is offline   Reply With Quote
Old 07-24-2003, 09:23 PM   #7
akcel
Member#: 10268
gc8 I ride ride 24s
and it is for sale...for got to mention that part hah
Got my turbo kit, need help with voltage clamp :( qtr_wrx Normally Aspirated with bolt-on Forced Induction Powertrain 3 12-06-2009 04:11 AM
Map Sensor Voltage Clamp Question #522 Normally Aspirated with bolt-on Forced Induction Powertrain 11 09-10-2008 11:52 PM
FS: EBC, Water Injection and voltage clamp stevenh Private 'For Sale' Classifieds 3 09-19-2004 01:17 PM
Torque chip II and voltage clamp? garretwp Normally Aspirated with bolt-on Forced Induction Powertrain 3 10-09-2003 09:40 PM
SS Voltage clamp and J&S question scootr Normally Aspirated with bolt-on Forced Induction Powertrain 3 10-28-2001 04:19 AM
