Old 03-18-2003, 04:54 PM   #1
Zephyr
Member#: 3362
2001 I've wired a
Few cars in my day
Default Fuel Pump Controller Issue on WRX Swap
Like the title of the thread says.
Has anyone else who has done a swap run into this issue. On the WRX you have a fuel pump controller that routes power from the fuel pump really to the fuel pump. On the RS the fuel pump get's it's power directly from the fuel pump relay. There are two wires that come off the ECM that power the fuel pump controller that I'm not sure what to do with.
Bottem line is do I need to use a Fuel Pump Controller to make the car run.
Many thanks to the kind soul who can shead some light on this issue.
If you have any solutions please IM/PM/e-mail me with any input.
Zephyr
Zephyr is offline   Reply With Quote
Old 03-18-2003, 05:17 PM   #2
BOY
Member#: 232
99 RS-T RIP
02 Forster-S
WRX fuel pump drops right in and uses the same connector. At least it did on my 99.
BOY is offline   Reply With Quote
Old 03-18-2003, 06:10 PM   #3
Aspen
Member#: 145
Banned to
Housework for Summer
IIRC the engine will run without the fuel pump controller but it will be slightly rich down below.
Aspen is offline   Reply With Quote
Old 03-18-2003, 06:39 PM   #4
Zephyr
Member#: 3362
2001 I've wired a
Few cars in my day
Thanks for the help guys.
Z
Old 03-18-2003, 08:29 PM   #5
Hondaslayer
Interpretively Paraphrasing
Member#: 4562
1995 Legacy LSi
1998 Declasse Moonbeam
Yamarocket630 Did the swap with the controller,Perhaps he can shed some light on this.
John?
Ben,
Old 03-18-2003, 09:16 PM   #6
Crawford/I-Speed
Vendor
Member#: 12347
ECU ReProgramming
Dynapack AWD Dyno
Do you have the harness for the controller?
If so then:
Unplug the white two prong plug underneath the seat.
Plug in the new one, which is connected to the controller.
The other two wires that go to the ecu (light green and violet wires) connect to the controller.
Intercept the power wire that goes to the old rs pump (black & red) to the new wrx controller (Black &Yellow). The black wire on the controller is ground.
This can all be done by the passenger side kick panel.
Adam
i-speedusa.com
Crawford/I-Speed is offline   Reply With Quote
Old 03-18-2003, 11:21 PM   #7
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
Default Thanks for asking the question
I will be starting on my swap soon and this will surely help.
Old 03-19-2003, 09:06 AM   #8
BOY
Member#: 232
99 RS-T RIP
02 Forster-S
what's this talk of the controller? The pump itself drops right in and plugs right in. No complaints or problems thus far other than 420cc injectors being way too big for my needs right now
Old 03-19-2003, 10:06 AM   #9
Zephyr
Member#: 3362
2001 I've wired a
Few cars in my day
Yes I am well aware that the pump just drops into the tank and you plug it in but the issue is not the pump, it is the pump controller. On the WRX it has a fuel pump controler that opperates the fuel pump rather than just taking power directly from the Fuel Pump Relay as on the RS. The fuel pump controller is operated by the ECM.
After speaking to a few people I have learned that either you run the FPC or you have to run the fuel pump all the time by bypassing the fuel pump relay altogether.
Z
Old 03-19-2003, 10:37 AM   #10
BOY
Member#: 232
99 RS-T RIP
02 Forster-S
hmmm, I just plugged in the pump and have had no problems thus far.
Old 03-19-2003, 10:59 AM   #11
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
yes but you are running a RS ecu
wrx ecu needs the fuel pump controller
Old 03-19-2003, 11:02 AM   #12
BOY
Member#: 232
99 RS-T RIP
02 Forster-S
doh, now I see what's going on. I wasn't making the connection between this was WRX ECU going in on me
Old 07-23-2003, 10:21 AM   #13
Boost4U
Member#: 16459
1998 2.5RS
So lets see if I can get this straight...... You need to run the WRX pump controller, but do you need the WRX relay?? And also, do you need any of the wiring from the WRX to make the controller work??
- Chris
Boost4U is offline   Reply With Quote
Is the Fuel pump controller necessary for WRX swap? Homemade WRX Subaru Conversions 41 07-05-2011 11:12 AM
USDM STI Fuel Pump Controller vs USDM WRX Fuel Pump Controller Boeleni Subaru Conversions 8 11-06-2009 10:33 AM
Full 07 STI Swap in 05 WRX. Fuel Pump Controller Issue. mrtrex Subaru Conversions 2 04-05-2008 08:16 PM
Fuel pump controller for 02 wrx cornerbuddy28 Private 'Wanted' Classifieds 2 08-24-2006 12:48 AM
need help with the fuel pump controler on my swap simprezl25 Subaru Conversions 1 09-01-2005 01:29 PM
