07-20-2003, 02:56 AM | #1 |
Member#: 14841
Vehicle:2002 Impreza WRX WRB, VF22, Cusco, Unichip |
Firewall passage for A-pillar mount
Where do you go from the bottom of the a pillar with the senders for mechanical guages? Also, is anyone running the Autometer a-pillar that goes over the factory a-pillar? It seems to me that the factory piece must be hacked for the wires to pass through to inside the dash. Am I correct?
Any input appreciated. Thanks, B-Kerr
07-20-2003, 09:39 AM | #2 |
Member#: 33424
NESIC
Vehicle:2004 STI Blue/Gold |
You can get the wiring it without hacking the factory pilar. The wiring can just rin down to the bottom and sneak under from there. You do have to drill holes in it to attack the pod though, so your hacking it no matter what.
07-20-2003, 01:23 PM | #3 |
Member#: 15106
im using those $15 autometer cups and mounted 2 on the
a-pillar. i did need to drill several holes into it. when im ready to sell the car, im just going to buy new/used a-pillars and replace them. not sure if this is valid for mechanical guages, but im running a thermocoupe through the grommet above the clutch to the intake to run my electronic guages. |
07-22-2003, 02:54 PM | #4 |
Member#: 27624
W. Canada
Vehicle:2014 WRX White |
Same grommet for the mechanical ones. Just make sure that you zip tie any wires/hoses out of the way of your pedals as this can cause your pedals not to go all the way down and/or a pinched hose.
07-23-2003, 03:26 AM | #5 |
Member#: 14841
Thanks!
Thanks for the help guys!
B-Kerr |
Camber adjustable pillar mounts for stock KYB struts | Patu | Brakes, Steering & Suspension | 9 | 05-30-2007 05:45 PM |
Pillar Mount Gauge Pods for Us! | Al_Smokemcrack | Legacy Forum | 13 | 01-21-2005 01:04 PM |
WRX Pillar Mount For 3 Gauges For Sale | Ravenous | Private 'For Sale' Classifieds | 1 | 05-14-2004 01:52 PM |
pillar mount battery voltage meter.. | bratmantlz | Normally Aspirated Powertrain | 3 | 06-11-2001 09:16 AM |
Gauge Pods...Pillar mounts | Remy E. LeBeau | Interior & Exterior Modification | 1 | 03-16-2001 03:24 AM |
