Welcome to the North American Subaru Impreza Owners Club Tuesday March 19, 2024
Old 07-20-2003, 07:28 AM   #1
squeeks
Member#: 22899
01 GM6 i think
BRP
Default GC8 power window problem
so my driver's side window will not go up. it is stuck down and i can't figure out what the problem is! its not the switch, I've figured that out. it sounds like something is loose in the door when i shut it as i hear a bad rattle. But, I've taken the door panel off and the window seems to still be on track. anyone have any idea???
thanks
-greg
oh yeah its an 01 RS
squeeks is offline   Reply With Quote
Old 07-20-2003, 11:25 AM   #2
TaiChih
Member#: 3467
1998 Dinan3
Bleck
are you hearing the motor running? if so, the screw to the window and the track has come off and maybe fell in the door. just my thought.
TaiChih is offline   Reply With Quote
Old 07-20-2003, 02:01 PM   #3
squeeks
Member#: 22899
01 GM6 i think
BRP
all the bolts are in just fine as far as i could see a week ago, but i'll check again tonight. thanks for the sugggestion.
keep 'em coming!
-greg
Old 07-21-2003, 10:56 AM   #4
ATX25RS
Member#: 4597
2011 Mitsu Outlander
Sport (Ex-Suby owner X3)
this happened to my grand am a few time....the solenoid may be out...basically your window motor may be fooked...
ATX25RS is offline   Reply With Quote
Old 07-21-2003, 06:40 PM   #5
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
why do say its not the switch?
try this turn the key on, dont start the car.
turn the map lights on, operate the switch up and watch the map lights, if the lights dim...most likely the motor or regulator is seized.
if the lights do nothing, its probably the switch.
Jay
Power window problem soxx Interior & Exterior Modification 4 09-08-2004 01:25 AM
Power window problem jimbo1972 Electrical & Lighting 1 03-01-2004 01:06 AM
Power window problem ilmaestro Service & Maintenance 2 03-29-2002 12:35 PM
power window problem funkadellic69 Service & Maintenance 2 03-24-2002 12:44 PM
Power Windows Problem funkadellic69 General Community 4 03-18-2002 09:31 AM
