Go Back   NASIOC > NASIOC Archives > NASIOC Archives > STi Forum Archive
Old 07-20-2003, 03:14 PM   #1
hatchy
Member#: 36852
2004 STI
Default Flash cruise control light (NO CEL!)
I installed some Borla headers last night on the STI and about 1/2 mile of driving, I noticed that the Cruise Control Light started flashing, but NO CEL, so no codes to pull.
I also noticed that my car is running much leaner after the CCL started flashing. My SCES reports a lambda at 1.38, which converts to something like 19.x:1 AFR!
When I shut the car down, and restart it, the flashing CCL goes away, but comes back shortly after. Car seems to drive fine, but I am freaked out by the Lambda readings.
I'll check the vacuum hoses and zip tie them because the CEL + flashing CCL seems to point to that, but I am having a different problem because I am not getting a CEL.
Maybe I damaged the O2 sensor when I removed it? Wouldn't that throw a CEL? Any suggestions?
Does the STI use the same FRONT O2 sensor as the WRX?
hatchy is offline
Old 07-20-2003, 03:23 PM   #2
Qbushido
Member#: 17120
2004 04WRX STi 99 RS
sold and MBP, SQC# 33
the head tech at my dealer is having the same problem after putting in a downpipe. Subaru techs are working on a fix is all I know.
Qbushido is offline
Old 07-20-2003, 03:25 PM   #3
hatchy
Member#: 36852
2004 STI
Really? Just flashing cruise control light and NO check engine light? Usually, it is just CEL (not flashing) with the downpipe.
hatchy is offline
Old 07-20-2003, 03:31 PM   #4
Qbushido
Member#: 17120
exactly the same issue that you are having.
Qbushido is offline
Old 07-20-2003, 03:32 PM   #5
Qbushido
Member#: 17120
how did the sound change with the borla headers? Any dyno #'s?
Qbushido is offline
Old 07-20-2003, 03:38 PM   #6
hatchy
Member#: 36852
2004 STI
Dude, I've had 3 miles since the headers. And 2 miles of that is with the CCL, so no, I haven't opened it up at all
It does should different. A little louder, and a little lumpier at idle.
hatchy is offline
Old 07-20-2003, 03:38 PM   #7
hatchy
Member#: 36852
2004 STI
Can you tell me the name of the dealer? I wanna give them a call and "exchange notes".
hatchy is offline
Old 07-20-2003, 05:36 PM   #8
G-shock
Member#: 36545
I had my cruise light come on right after I added the 7x3" velocity stack to my stock air box, while there were no lights with the silencer removed by itself...I guess the velocity stack made a big enough difference to be noticed by the ECU...it was definitely noticable with the butt-dyno.
After a bit of driving...maybe 2-3 restarts and driving...the light went away and never came back. I guess the ECU learned to live with it.
G-shock is offline
Old 07-20-2003, 05:54 PM   #9
hatchy
Member#: 36852
2004 STI
Is this on a STI or RS? Did you car drive weird or anything?
hatchy is offline
Old 07-20-2003, 05:56 PM   #10
hatchy
Member#: 36852
2004 STI
As a test, I disconnected the SCES and within about 5 mins, the CEL came on along with the flashing CCL.
But when I reconnected ther SCES to read the code, SCES reports that there were no faults!
I've checked the hose and zip tied most of them, but how do you get to the ones that are way down under the alternator?
hatchy is offline
Old 07-20-2003, 06:42 PM   #11
G-shock
Member#: 36545
STi.
It was wierd...it felt faster!
G-shock is offline
Old 07-20-2003, 06:46 PM   #12
hatchy
Member#: 36852
2004 STI
Cool. How many miles did you drive before the light went away? I am concerned because it is behaving differently now.. now I get both the CEL and CCL.
hatchy is offline
Old 07-20-2003, 07:11 PM   #13
G-shock
Member#: 36545
It went away in about a day, maybe less...minimal milage...like I said, 2-3 short trips and then during one it just went out.
I tried simply restarting it at first a couple of times, but that did nothing, only driving it helped. Mind you I drive "peddle to the metal" about 90% of the time, so whatever program it tries to learn when something changes its probably the one that requiers the most air...maybe that helped.
G-shock is offline
Old 07-21-2003, 02:42 AM   #14
hatchy
Member#: 36852
2004 STI
UPDATE:
I now know why I got the CCL but not CEL. I have the SECS unit installed on my car, and apparently, it blocks the CEL. I am not sure why, I'll ask PSI3, but when I disconnected the SECS unit, I got the CEL along with the flashing CCL within 2 miles of normal driving.
I have also zip tied or hose clamped all of the hoses connected to the "problem" blue T. Didn't help.
Any other suggestions, please?
hatchy is offline
Old 07-21-2003, 11:51 AM   #15
G-shock
Member#: 36545
To all my efforts and searching through the STi service manual...I have it downloaded...I couldn't find one frikin reference of the cruise control light relating to anything else but the cruise control system!!! No airflow, no engine management, nothing!!! And I know when the light came on it was related to the velocity stack, or better yet the increased airflow in some way.at least that is the only conclusion I have at this point.
G-shock is offline
Old 07-21-2003, 01:25 PM   #16
zacek
Member#: 19467
04 WRX STi
WR Blue - original owner
I ran out of gas during a canyon run and I got:
- CEL (P0230)
- Flashing Cruise Control Light (CCL)
- Flashing Low Fuel Light (LFL)
What is a P0230, never seen that!
zacek is offline
Old 07-21-2003, 01:53 PM   #17
G-shock
Member#: 36545
Originally posted by zacek
...What is a P0230, never seen that!...
According to the STi service manual...
DTC P0230 "Fuel Pump Primary Circuit"
The diagnostic proceedure section says that if it was out of gas...
"DTC may be recorded
due to the
idle running of fuel
pump at out of gas."
...so I guess your OK! Reset the ECU to clear all DTC codes.
G-shock is offline
Old 07-21-2003, 02:03 PM   #18
SubaruPilot
Member#: 10461
UPDATE:
Disconnect the SECS unit and get the code pulled/read with an ODB scanner at an Autozone or similar parts store...they usually do it for free.
SubaruPilot is offline
Old 07-21-2003, 02:25 PM   #19
zacek
Member#: 19467
04 WRX STi
ok, so it seems that the flashing CCL is triggered by some types of CEL's, we still do not know what class/types though, but definitely some conditions will trigger that.
Maybe severe Trouble Codes that could affect emissions will trigger the CCL. The downside to this is that while the CCL is on that blinking mode the actual cruise control does not work.
zacek is offline
Old 07-21-2003, 02:36 PM   #20
SloPok
Member#: 37344
04 WRB STI 04'
I put in a downpipe and exhaust, cel and ccl came on. CCL does flash, been like this for a month now, got it scanned when it first happened, it was from the o2 not getting a good ground. I have been told that grounding this better will eliminate it, no power loss however. Just an irritation....
SloPok is offline
Old 07-21-2003, 02:46 PM   #21
hatchy
Member#: 36852
2004 STI
More info.
I can't get an appt with the dealer, so I am going to try a few shops, including autozone/pepboys and see if they can pull the code.
It is possible that when I removed the O2 sensor, I may have screwed up a wire or two. There are no obvious breaks, and visually, the wire is flawless. The reason I suspect this is because I am noticing a weird pattern with the Lambda reading on my SCES unit. Basically, it measures the air fuel ratio. Normally, it is 0.80 (WOT) to 1.10 (snap the throttle shut), but normally, it is around 1.0.
Anyway, what I have noticed is that if I cruise at the same speed for a little while (~1-2 minutes) the Lambda starts to climb from around 1.0 to 1.38. 1.38 Lambda converts to slightly less than 20:1 AFR!!! That is extremely lean. The climb is very linear, it doesn't jump to 1.38, it climbs at a steady rate and there is no noticable performance at all. Since I don't have a EGT, I am not actually sure if the car is actually running leaner, or if the sensor is just wrong. Once I let off the throttle, it starts to drop back down to ~1.0 almost instantly, and if I get back on the throttle right away, it will go back up to 1.38. This cycles repeats once every 3-5 minutes. Car drives fine.
Question 1:
I am going to get the code pulled, but would love you hear what you think if this?
Question 2:
(Will ask this in the FFI forum, too)
The O2 sensor is a 4 wire unit. Power, Ground, Signal account for 3 of the 4 wires. What is the 4th wire? Heater? If a wire is broken and the ECU stops seeing a valid signal from the O2 sensor, what happens? Does the ECU see it as all lean (1.38 lambda) or does it readit as full rich (0.75 lambda)?
Thanks..
PS: Borla headers == a$$.
hatchy is offline
Old 07-21-2003, 02:54 PM   #22
hatchy
Member#: 36852
2004 STI
The Autozones around here won't pull the code, and Pep Boys wants $90 to do it.
hatchy is offline
Old 07-21-2003, 04:07 PM   #23
LESLIEx317537
Member#: 35350
2004 Impreza WRX STi
Java Black Pearl/Gunmetal
Wow, I'm starting to think this car is more like my computer than my current car I'm selling.
LESLIEx317537 is offline
Old 07-21-2003, 04:13 PM   #24
happasaiyan
Member#: 37731
headers = LEAN.
you NEED engine management with headers.
happasaiyan is offline
Old 07-21-2003, 04:36 PM   #25
dlowman
Member#: 22998
2004 WRX STi
GT35R 572 whp 93/meth
Yeah at this time I would try a reboot
dlowman is offline
06 WRX CEL and flashing cruise control light. Mehdik Service & Maintenance 13 12-06-2011 08:49 AM
Check Engine Light and Flashing Cruise Control Light moose00015 Newbies & FAQs 17 05-29-2011 09:16 PM
check engine light + flashing cruise control light ericmwas Newbies & FAQs 6 08-24-2009 11:21 PM
flashing cruise control with no chip ecasirhc Engine Management & Tuning 0 03-05-2007 05:01 PM
My friend's STI got a CEL and flash cruise control light. Cary Lam Vancouver Impreza Club Forum -- VIC 5 07-04-2006 01:22 PM
