Go Back   NASIOC > NASIOC Archives > NASIOC Archives > STi Forum Archive
Old 07-20-2003, 10:53 PM   #1
drewzter
Member#: 39879
2008 Infiniti G37S
Graphite # 73 FS
Unhappy Clicking or Rattling behind dash/instruments
Does anyone else have a rattle or clicking noise around 4000 rpm in the dash area? I have read the posts on the fix for the clips under the defrost strip but I did not want to take that apart without confirmation for this on the '04 STi. It is very slight and noticable most at about 4000 rpm. It is not coming from the engine compartment. I opened the hood and revved it up and did not hear it there. It is in synch with the revs though so I am thinking vibration, not wind.
drewzter is offline
Old 07-20-2003, 11:12 PM   #2
TurboPhoon
Member#: 5946
I sometimes hear a rattling from up front, similar to what you described. It sounds like it is behind the dash and impossible to get to. I also have a bad rattle coming from the headliner in the rear. I just open the windows for now.
TurboPhoon is offline
Old 07-20-2003, 11:36 PM   #3
JDMTEG98
Member#: 38671
2004 WRX STi
World Rally Blue w/ Gold
I have not had any problems with sound or rattling, maybe I should drive with windows up and radio off, If I hear anything I will let ya know. Might just be something lose. Good Luck
JDMTEG98 is offline
Old 07-21-2003, 10:12 AM   #4
Fido
Member#: 1867
Try the ashtray. I couldn't figure out where this rattling was coming from while I drove. I finally traced it to the ashtray. Take it out and put it back in securely. Sometimes the metal bracket inside that holds it in rattles a bit. It's real annoying and hard to pinpoint because it comes from inside the middle of the dash.
Fido is offline
Old 07-21-2003, 12:00 PM   #5
CANAILLE
Member#: 35310
2004 sti
TBA
I have the rattle coming from behind the instrument panel. If I press on the front of it the rattle stops. I am going to try dynamat behind some of the plastic trim to see if it helps.
CANAILLE is offline
Old 07-21-2003, 03:04 PM   #6
ch692115
Member#: 11229
2007 WRX STI LTD
satin white pearl
i also get the ashtray rattle. if i have it pushed all the way in the problem still persists but if i pull out the ashtray just slightly the rattle goes away.
ch692115 is offline
Old 07-21-2003, 06:10 PM   #7
CoreyRED02
Member#: 19588
The rattle you are referring to in the front of the dash is common on both the WRX and STi. It is caused by the white clips Subaru uses to hold the front most section of the dash. This has been referred to as "VIN Plate rattle". Do a search under that and you can see the fix. Basically you just need to hold the white clips in place, they are what is actually making the noise in most cases. FYI, be careful when pulling that piece up in the STi, the sunlight sensor for the Climate control is attached to it and you could damage it.
Happy Hunting...
CoreySTi04
CoreyRED02 is offline
Old 07-21-2003, 07:28 PM   #8
Zoso
Member#: 37962
2006 CGM STI
2000 Outback & 05 BMW M3
I have some rattles too, when I do the stereo install I hope I discover where they are coming from.
1) Around the driver's side round air vent area
2) Around the passenger's side round air vent area
3) Around the center console area
It's hard to pinpoint where they are coming from. I looked under the dash and found some loose wire connectors, but I didn't turn out to be that. I can only hear them when all the window are up, and only when the road surface causes a certain vibration. But I wish I could just see right through the dash and fix them!
Zoso is offline
Rattle behind pass side airbag cover? Mr. Sadface General Community 3 11-20-2005 08:08 PM
Adding another power point behind dash? Cardiff Giant Car Audio, Video & Security 2 02-01-2004 03:16 PM
Rattling behind dash after Sti GrpN Mounts Installed. Brian Broz Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 12-10-2003 05:37 AM
dash/instrument lights ^jynx^ Technical Forum Archive 8 11-09-2000 10:25 AM
