Welcome to the North American Subaru Impreza Owners Club Wednesday June 3, 2015
Old 07-21-2003, 12:23 AM   #1
Mancini
Member#: 20726
Talking Did a compression test today...
perfect compression across all 4 cylinders after 3000 miles of boost and no signs of det on the plugs.
Only problem and here's my question. I have NGK plugs and when I put them back in they hand tightened all the way but locked up and I couldn't really even torque them down cause they wouldn't move. Almost like they were cross threaded...but I'm 99% sure they're not. It seemed like they were completely sunk...
Sorry for the n00b question, I've just never really put plugs back in, always replaced them when they were out.
Mancini is offline   Reply With Quote
Old 07-21-2003, 12:31 AM   #2
tulit
Member#: 338
09 STi
The plugs have crush washers on them. Thats why the first time you used them you could still turn them after they "bottom out" into the head.
The next time you put them in, the washer has already been crushed so you cant really turn them much after the "bottom out". You should use a torque wrench rather than a certain number of turns to tighten them up.
tulit is offline   Reply With Quote
Old 07-21-2003, 12:49 AM   #3
Mancini
Member#: 20726
Cool that's what I was thinking. And I did torque them to 15 lb ft.
Thanks, I appreciate the help!
Brian
Did a compression test.. do the numbers look good?? justchillax808 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 06-24-2009 08:47 PM
So i did a compression test on my 05 sti...... Wrbimprezasti Alaskan Impreza Club Forum -- AKIC 4 03-21-2009 10:59 PM
Did a compression test... QwikRex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 25 03-02-2005 11:20 PM
To all STI owners that did a compression test wgknestrick Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 8 03-09-2004 11:06 AM
compression test today. looks good! Black-X Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 09-16-2003 12:04 PM
