Old 07-21-2003, 03:47 AM   #1
5spd Alcyone
Member#: 34383
1992 SVX-T3/T04E
Dark Teal Metallic
Default ej20TT into svx conversion
5spd Alcyone is offline   Reply With Quote
Old 07-21-2003, 03:58 AM   #2
US2JDM
Member#: 5893
1997 Black GC4
1995 White BK6
I know this place stocks 'em and they're not bad on prices:
http://www.nippon-motors.com/
My friend got an older EJ20 turbo motor for his GC from them and said the service was great.
My guess would be that custom exhaust plumbing for the second turbo would be necessary to clear the steering hardware in a LHD car. That's pretty much the case in GCs and Legacies to get the motor to fit.
Good luck, it sounds like a fun project!
-Milan
US2JDM is offline   Reply With Quote
Old 07-21-2003, 10:49 AM   #3
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
hmm is the engine cross member in a svx the same as whats in a inpreza/legacy/forester
might seriously consider a usdm motor. more wireing head aches less custom metal fabrication
Old 07-21-2003, 11:51 AM   #4
5spd Alcyone
Member#: 34383
1992 SVX-T3/T04E
Dark Teal Metallic
http://www.nippon-motors.com/subaru.htm
for the price of a b4 engine and fabrication probably will still be under what it would cost me for a lowe milage SVX engine, look at hte price list. My mechanic is exclellent, but i could do alot of the wiring myslef. Like you said its not all that hard its just a matter of patience and alot of time.
phil
Old 07-21-2003, 01:56 PM   #5
5spd Alcyone
Member#: 34383
1992 SVX-T3/T04E
Dark Teal Metallic
engine crossmemeber is not the same, let me take some pics and then maybe you can help me out?
thanks jaxx
I was really looking forward to putting the ej20tt into my SVX, when you say alot of the piping has to be rerouted becuase of the steering column im assuiming your talking about a WRX or 2.5 engine bay?
Old 07-21-2003, 02:50 PM   #6
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
He is talking about the fact that the B4 engine is designed for a RHD only car and makes no considerations for the component locations in a LHD car.
-Jon
Old 07-22-2003, 01:49 AM   #7
XT6Wagon
Member#: 524
04 STi
Things you can do...
freshen up the EG33, get the heads cleaned up and gasket matched, etc.
Take the EG33 and get the crank welded and offset ground for a EJ25 stroke, then do the EJ25 bore on the block. Run aftermarket EJ25 rods and pistons. EG37 ownz you
After that it gets to be a real mess of custom work.
I guess I'd wait till the STi type-US and 2.5XT motors and stuff are availble in the junkyards. Good starting place. Avoid the TT motors.
Then do a custom turbo setup with a garret GT placed ahead of the motor between the radiator and the motor. The shorter length of the 4cyl should make it not too difficult to find the room. The header will be interesting to do, but not hard for someone with the tools. The run a narrower than normal aftermarket radiator so you have 2.5" or so to run IC pipes past one side of the radiator to massively cut down on pipe length and bends.
XT6Wagon is offline   Reply With Quote
Old 07-22-2003, 12:13 PM   #8
svxtrem
Member#: 1008
2006 STI
Steel Grey Metallic
Actually, the EG33 is a much better engine than most realize. I run the SVX FAQ, and am aware of several people who have modified them. For instance, one in particular was built for a dune buggy. This gentleman is using a stock EG33. The only mods are a TEC II EFI system, custom headers, and two K&N filters (SVX has dual throttle bodies). This was tuned on an engine dyno and produces 330hp (crank) at 6800. That's without touching anything inside the motor. Stock cams, block, pistons, everything. The SVX has always suffered from a very restrictive exhaust which greatly limits the horsepower. Peak VE is at a very high 4400 RPM with 228 lb/ft, so you know it has plenty of cam and port capacity.
svxtrem is offline   Reply With Quote
Old 07-22-2003, 12:17 PM   #9
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
Wow, I had no idea.
-Jon
Old 07-22-2003, 03:40 PM   #10
5spd Alcyone
Member#: 34383
1992 SVX-T3/T04E
Dark Teal Metallic
are you aware of the prie an eg33 buildup would cost? I am, have looked into it, For meit is out of the question. Go for it if your so sure about it,.
phil
Old 07-22-2003, 03:44 PM   #11
5spd Alcyone
Member#: 34383
1992 SVX-T3/T04E
Dark Teal Metallic
i NEVER saidanything about it being a bad engine its a glorious engine which has served me well. And about the 330 crank hp your full of it. This engine isnt capable of flowing enough air without forced induction to create anywere newar that power, the ehxuast resictrion isnt good for more then 5hp, i am "phast svx" on the network, and i hold the fastest 1/4 time of any NA SVX on the registry and on the network.
phil
Old 07-22-2003, 03:47 PM   #12
5spd Alcyone
Member#: 34383
1992 SVX-T3/T04E
Dark Teal Metallic
The heads have no steps in them at all, porting and polishing will yield extremely small gains, the eg33 was built from the factory and produces impressive power for its size and weight(especially for its time) and runs strong for many years. You cant ask for more.
Old 07-22-2003, 04:15 PM   #13
svxtrem
Member#: 1008
2006 STI
Steel Grey Metallic
Umm...Ok. It seems your knowledge far surpasses that of other people who have used these engines for dune buggies, dragsters, and homebuilt aircraft. Even those with dyno sheets to prove it! Don't know why a simple post should get you all upset. Peace!
Old 07-23-2003, 12:57 AM   #14
5spd Alcyone
Member#: 34383
1992 SVX-T3/T04E
Dark Teal Metallic
Then get me the dyno sheet, and i will shut up! And if your reffering to frank aragona jr he has far from a stock eg33.
I have spoke with him on two occassions about hes buildup at rt 66 when he has competed here(supercharged and sprayed, 9:1 compression custom built nitrous pistons) And he was the one that reccamended i NOT attempt and EG buildup, if i was concerend about power i should go for an ej swap. I would LOVE to build an EG and maybe with my stock motor which i will still have i can begging to do it slowly and right. but its deifntly out of my equation for now.
P.S. heres franks dragster
http://www.subaru-svx.net/photos/fil...t_SVX/7195.jpg
phil
Old 08-03-2003, 02:04 PM   #15
motorswapsleeper
Member#: 38946
199? 6 diff ones
bag o' skittles
Just to add, nippon motors is run by a bunch of great guys!
I got my motor quick, it was in perfect working, with even more extras than I had had hoped.
-TIm
motorswapsleeper is offline   Reply With Quote
Old 08-04-2003, 02:02 AM   #16
5spd Alcyone
Member#: 34383
1992 SVX-T3/T04E
Dark Teal Metallic
yea its defintly getting close to being time to give them a call. I ran a 14.7 on the bottle(50 shot), but on returning home my car is hesitating.
Old 08-07-2003, 02:34 AM   #17
nomadtw
Member#: 8037
1998 2.5RS - black
2iggpoints
congrats on 14.7 i don't think i said that over there
nomadtw is offline   Reply With Quote
Old 09-22-2003, 07:34 PM   #18
SVX Twin Turbo
Member#: 43975
1992 Subaru SVX
PPG Black Metallic Custom
Talking EJ20TT In an LSL
Okay, I see you guys arguing about the fact. I have got an EJ20TT in the process of going into my 1992 SVX LSL. There are a few problems I have encountered. The exhaust manifolds bump the crossmember and have to be modified to not be constantly rubbing the sides, the mounts are close enough to the same where it can be bolted in with some time and work. Wiring wise, just get an EMS (Link Management System ran me about $1200) and there are a few other clitches to work out.
SVX Twin Turbo is offline   Reply With Quote
ej20tt into 93 legacy?? 92b4man Subaru Conversions 4 06-28-2008 03:12 AM
EJ20TT into a MY01 2.5RS ex25rs Subaru Conversions 9 07-17-2007 12:29 PM
WTB Sti 6mt for SVX conversion TomsSVX5mt Private 'Wanted' Classifieds 0 10-27-2005 12:33 PM
JDM 97 legacy EJ20TT into 03 USDM WRX marksWRX03 Subaru Conversions 9 09-01-2004 05:34 PM
EJ20TT Into a 98' Rx Liberty/Leagcy i want an ubru Pre-2002 Factory Turbo Powertrain 2 11-15-2003 10:55 PM
