Go Back   NASIOC > NASIOC Archives > NASIOC Archives > STi Forum Archive
Old 07-21-2003, 05:21 AM   #1
d3wu
Member#: 5892
2004 Impreza WRX STi
Java Black Pearl
Default how strong is the STi clutch
i managed to burn my clutch probably 6 times by now . i didnt see smoke or anything but i distinctively know the smell of my clutch by now. i was just wondering whether anyone knew how strong the STi clutch was and when average drivers will have to change them at a certain mileage?
d3wu is offline
Old 07-21-2003, 07:44 AM   #2
STI 2 NV
Member#: 31748
'15 WRB WRX
from what i was told the clutch is incredibly strong and virtually unbreakable. i guess u can actually shift without putting in the clutch, u just have to ram the shifter into gears. this is just what i was told so no one kill the messenger.
STI 2 NV is offline
Old 07-21-2003, 08:23 AM   #3
charles s
Member#: 35935
2006 OBS 99 Forester
Steel Grey & Silver
errr. if you're trying to shift like that you're not using the clutch.... uhhh ... don't... (unless you can rev match)
charles s is offline
Old 07-21-2003, 09:21 AM   #4
STI 2 NV
Member#: 31748
'15 WRB WRX
i would never even think of it and i don't think anyone would. it was just the point that the car is built so well that u wouldn't even need to put in the clutch to shift. just what i was told, nothing i would have even thought about.
STI 2 NV is offline
Old 07-21-2003, 09:50 AM   #5
kadunkadunk
Member#: 39454
2008 EVO
You can clutchless shift any car. My clutch went out in my MG and didn't have the money to fix it for a week or so. I would start it in first gear with the starter and no clutch!!! Then shift normally.
kadunkadunk is offline
Old 07-21-2003, 10:16 AM   #6
happasaiyan
Member#: 37731
i cant even slide the shifter out of gear 9/10 times. i think maybe the tranny still needs to loosen up a bit. i used to be able to clutchless shift my miata...but i dont feel like taking the chance with the STi. i would rather buy 4 clutches than buy 1 tranny.
happasaiyan is offline
Old 07-21-2003, 10:23 AM   #7
Seraph
Member#: 12251
Same here. I dunno if its me, but it takes more effort for 1-2 and 5-4 than it does the other shifts
Seraph is offline
Old 07-21-2003, 01:20 PM   #8
HFTuRbo
Member#: 34388
04 WRX STi
Black w/gunmetal
All transmissions are stiff in the beginning, even the "jewel-like" honda. The shifter and effort will reduce in stiffness over time. On the clutch... Since there isn't much need to get a launch in the STi, the clutch shouldn't need to be abused to get power off the line.
HFTuRbo is offline
Old 07-21-2003, 06:27 PM   #9
filbert
Member#: 39661
2004 WRB WRX STi
07 OBP FXTS
test drive a ferrari and then you'll know how hard (physically) changing gears can be...
filbert is offline
Old 07-21-2003, 07:33 PM   #10
RichQY
Member#: 31948
2004 STi
or better yet.
watch those poor brits trying to shift or "weight lifting" the Lambo Diablo in TopGear.
as Jeremy said... you ll need both hands and get your passenger to help out....
RichQY is offline
Old 07-23-2003, 09:39 AM   #11
KoneKiller
Member#: 39191
2004 WRX STi WRB
Red 1990 Spec Miata
Default Re: how strong is the STi clutch
With 300 ft/lbs of torque and much of it available at low RPM's, why are you burning the clutch?
Granted, in the OLD WRX I would get a little stink now and then on autocross launches, but even that was driver error on my part. In the STi, I have not had any problem getting catapult launches without abusing the clutch.
What gives?
KoneKiller is offline
Old 07-23-2003, 10:00 AM   #12
ToddStratton
Member#: 8351
2002 WRX Wagon
Yep, the only time I smell the clutch in either my wagon or STi is when I slip it too much. A good launch and you won't smell anything.
TRS
ToddStratton is offline
Old 07-23-2003, 01:18 PM   #13
skuttledude
Member#: 738
2008 Lexus IS-F
Ducati Monster 800
How strong is the Sti clutch? That will depend on how you use/abuse it. A clutch can last for a day or for years..
I heard too that the Sti clutch is very stong. Don't abuse it, figure out how to properly launch your car and it will last a long time.
Davis
skuttledude is offline
Old 07-23-2003, 01:36 PM   #14
ha-evolution
Member#: 31556
15 STI WRB ordered
09 Accord Coupe V6 mt
Default Re: Re: how strong is the STi clutch
How are you launching? I have done this twice by accident. It felt awesome - what a holeshot. Being that this is my first AWD car and that it's not broken in yet, it was sort of accidental. Please inform us.
ha-evolution is offline
Old 07-24-2003, 03:09 PM   #15
KoneKiller
Member#: 39191
2004 WRX STi WRB
Red 1990 Spec Miata
Default Re: Re: Re: how strong is the STi clutch
Autocross is different than drag racing, of course, and my technique won't serve you well on the drag strip. In autox they say, "Go when ready!"
When I get the 'go when ready' sign, I generally put about 4k on the tach and let the clutch out until I feel it just begin to drag a bit. At that point I simultaneously floor it and let the cluth out completely and quickly. I am always prepped to push the clutch in a bit if I get a BIG bog, but with the STi, it rarely happens. The old WRX would often bog unless you were close to perfect.
I get just the slightest hint of wheelspin this way and I'm grabbing for second gear almost immediately. 1st gear feels SO short, but it's actually taller than the WRX.
It would be interesting to compare the techniques of the good drag racers in here to mine.
Teach me guys/gals!
How strong is the 6 speed sti tranny? Jeepman775 Transmission (AT/MT) & Driveline 25 03-21-2008 02:45 AM
how strong is the crawford 6puck clutch ryanpietro Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 7 02-12-2006 04:23 AM
how strong is the sti 6-speed tranny? Spazzua Transmission (AT/MT) & Driveline 9 06-15-2004 07:59 PM
How strong is the STI V6 gearset? Should I just go with a Dogbox?? Kwyjibo Transmission (AT/MT) & Driveline 6 04-08-2004 10:11 AM
So how strong is the STi 6 speed tranny supposed to be? loanshark Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 10-26-2001 01:21 PM
