Old 07-21-2003, 08:50 AM   #1
Porter
Member#: 486
2004 Forester XT
bug spattered
Default STi ECM Update Released! (PING FIX)
I just learned from my regional SOA rep that Subaru of America has just received their updated ECM flash from SoJ for the USDM STi to combat the detonation problem.
Customers will need to leave their car with the dealer while their ECMs are sent to Subaru for reprogramming. There is an expected 4-6 day turnaround time, this is will obviously vary depending on a number of variables. Be very patient, it may take several weeks to get the process rolling on your car.
As soon as more flash units become available from Subaru, this will be a dealership-level flash service.
Let your dealer know IF you are experiencing detonation (NOT ALL CARS EXHIBIT IT!), and they will help you resolve the issue after testing and verification. If they aren't already up to speed on the issue, have them contact their regional rep for more information.
It may take some time for information to disseminate and to arrange scheduling through your dealer. PLEASE BE PATIENT through this process, this is not a recall so you will have to go through the full dealership testing, work order, and reporting process. There is an order in which this process must happen, please give your local dealerships the benefit of the doubt on this and allow the SOA reporting and resolution (flash) process to work as it should.
Enjoy!
Porter is offline   Reply With Quote
Old 07-21-2003, 09:10 AM   #2
robmarch
Member#: 18713
06 CRV
04 STi
if this is true, it's really lame that they would require us to leave our cars at the dealer for 4-6 days, instead of just shipping out the 200 or so ECUs to dealers in advance. With so few cars affected, if they are really just reflashing, why not send out the reflashed ECU's in advance, collect the bad ones, and reflash them for use in future cars?
robmarch is offline   Reply With Quote
Old 07-21-2003, 09:11 AM   #3
happasaiyan
Member#: 37731
hmm...no det WITH mods...unless it gives more power, i think ill pass...
happasaiyan is offline   Reply With Quote
Old 07-21-2003, 09:18 AM   #4
Hummer
Member#: 31892
2004 STi
Same situation here. Mine runs great and I don't want less hp or tq. My ECU reflash will probably be done by a tuner.
Hummer is offline   Reply With Quote
Old 07-21-2003, 09:22 AM   #5
Soon2bSubbieowner
Member#: 21812
2011 Mazda2
4 - 6 Days for the techs to rape your cars on the road while "testing"
Soon2bSubbieowner is offline   Reply With Quote
Old 07-21-2003, 10:15 AM   #6
Pre-diddy
Member#: 26837
04 STi - Sold! :(
Any reason for this reflash to cause some power loss? If not, better safe than sorry.
Pre-diddy is offline   Reply With Quote
Old 07-21-2003, 10:15 AM   #7
Porter
Member#: 486
2004 Forester XT
bug spattered
If you don't have anything mature to say, please remain quiet or go elsewhere.
This thread is intended for informational purposes, it is not and will NOT be a bitch session for what you think might or might not happen.
Also, if you think an STi can be "test driven" with no ECU in the car, you might want to sit and think very hard about what that means for a while. It'll come to you eventually.
Subaru will eventually have a flash cartridge at every dealer to perform this update, currently there is only ONE (1) in the country, so the ECMs have to be sent to Subaru for programming and then sent right back. 4-6 days is an estimate based on the outside chance of shipping problems or backlog at SoA.
PLEASE DO NOT attack your local dealer over this issue. Subaru is making every effort to resolve the det issue, and there is ABSOLUTELY NO EVIDENCE that there will be a change in torque or horsepower. These are currently unknown variables and anyone who may try to tell you otherwise is speaking from a soapbox of ignorance and deception. It is HIGHLY unlikely that Subaru would cripple the performance of the vehicle in order to fix something like a small timing map glitch. These kinds of issues have been fixed many times in the past on other vehicles with no change in drivability whatsoever.
Thanks!
-Jason Porter
Old 07-21-2003, 10:23 AM   #8
ANZAC_1915
Member#: 456
2008 Forester XT
Steel Gray Metallic
This was the same situation with the WRX --- they only had one flash cartridge so ECM's had to be sent in.
ANZAC_1915 is offline   Reply With Quote
Old 07-21-2003, 10:31 AM   #9
Soon2bSubbieowner
Member#: 21812
2011 Mazda2
No ish it cant be driven without an ECU, but Im pretty sure after they replace the ECU there gonna have to test drive the car to make sure it works and 4 - 6 Days to reflash an ECU are you joking me, I dont care what anyone says it shouldnt take that long. An hour AT THE MOST. I wouldnt care about a backlog issue. I would wait for the part the stuff to come in, drop off my car and for this kind of fix pick it up the next day.
Old 07-21-2003, 10:36 AM   #10
davidm_sh
Member#: 5994
2004 Impreza WRX STi
Java Black
It is HIGHLY unlikely that Subaru would cripple the performance of the vehicle in order to fix a small timing map glitch. These kinds of issues have been fixed many times in the past on other vehicles with no change in drivability whatsoever.
I am sorry but I don't see HOW Subuara can fix this issue without affecting the power in some way. Granted I don't see the 300hp figure changing (since that number is derived futher up in the rpms) but I think we will get a drop in torque to around 280ft lbs or so. That timing 'hump' is right at the torque peak and as such contributes to that torque peak.
Personally I think that the torque can be made up by an extra 1-2 psi of boost in the midrange while pulling about 2-3 degrees of timing to get rid of the knock, but I am not FHI so . It will definitly be interesting to see what happens with this.
davidm_sh is offline   Reply With Quote
Old 07-21-2003, 10:36 AM   #11
robmarch
Member#: 18713
06 CRV
04 STi
I just wanted to clarify, I'm not upset with the dealers, etc., I just think it would be nice for them to send out a couple of floating ECU's for the cars that are affected, since there is only one reflash location. Kind of a dealer "core" deposit. then, if a dealer had more than one to reflash, they could send the previous ECU in for reflashing for the next customer, who wouldn't have to wait. The dealer could schedule the appointments 6+ days apart to save the customer the wait time.
If the reflash is to be implemented on future STi's, which is probably the case, it would be much better to be able to order a reflashed ECU, and have your dealer send yours in for the reflash treatment for Subaru to send to someone else, or put in a new car, and save the 4-6 days of inconvenience. This might all be a horrible idea, if the ECUs are VIN marked or something like that, though.
I'm guessing Subaru might not be too excited to provide a rental car for those affected, to get them through the 4-6 days without their daily driver?
Old 07-21-2003, 10:44 AM   #12
Porter
Member#: 486
2004 Forester XT
bug spattered
Rob, there is currently only one flash cartridge in the country. This will change as more become available. This is the method by which Subaru is currently processing the claims. I have no other information to give you, unfortunately. The shipping delay is a temporary problem that will go away as soon as more flash cartridges become available. 4-6 days is a decent estimate. I hope to give my customers a 3 day turnaround, but obviously chaos is the rule rather than the exception when you are talking about shipping anything in this day and age. Appointments will have to be spaced out somewhat, obviously SOA can't flash 200 ECM modules simultaneously. You'll have to be very patient.
As far as a rental vehicle, you will have to check with your local dealer on that issue. Different dealers have different policies and they will have to work with Subaru on that. Obviously I have no information about your local dealer, you will have to query them on that.
As for the changes being made, speculation solves nothing and only serves to muddy the waters with misinformation. We will have to wait and see.
Old 07-21-2003, 10:49 AM   #13
darthdiggler
Member#: 23251
2004 STi
OMG will people ever be happy
davidm_sh : your second paragraph contradicts your first paragraph. ... there's either no solution ... or there is one ... decide.
darthdiggler is offline   Reply With Quote
Old 07-21-2003, 10:50 AM   #14
robmarch
Member#: 18713
06 CRV
04 STi
Thanks for the info, Porter, I don't want to sound like a whiney baby, or something. I have a daily driver if I choose to do the reflash. I'll stay out of the speculation, but I think reducing pinging is probably a good idea. The car will still be tons of fun with 295 lb/ft of torque, or whatever.
Have a good one.
Old 07-21-2003, 10:53 AM   #15
omahasubaru
Member#: 1594
1995 WRX
2002 Legacy
Did you see the part in his post about how they have to ship your ECU to subaru... by subaru he means SOA... so unless you take your car directly to them... you'll have some down time while shipping is being done. Yes of course they will drive it after they get the ECU back... they have to make sure it works. You guys are way too parinoid.. & skim posts way too fast & miss a lot of the important details. It's funny actually
omahasubaru is offline   Reply With Quote
Old 07-21-2003, 11:05 AM   #16
dlowman
Member#: 22998
2004 WRX STi
GT35R 572 whp 93/meth
Jason,
The fact that they are addressing this issue is great news. Hopefully we will not see any of the speculation that people are speculating Please let me know when I can bring my car in and we can start the process. This is my only daily driver though so we may need to try to work something out.
Dan
dlowman is offline   Reply With Quote
Old 07-21-2003, 11:23 AM   #17
Wombat North
Member#: 21267
STI, EWG 8cm Green
UTEC/ECUtek/WI & SD tune
Great News
Now I hope SOC follows SOA in this for us Canadians
Off to my dealer to let him know of this
Wombat North is offline   Reply With Quote
Old 07-21-2003, 11:37 AM   #18
Jon [in CT]
Member#: 2992
02 WRX Sedan
Whenever WRX ECUs had to be sent to NJ for a reflash, the owner was always offered a loaner or rental, regardless of dealership policy, under the Subaru Owner Assistance Alternate Transportation Program. I would expect the same to be true for the STi.
Jon [in CT] is offline   Reply With Quote
Old 07-21-2003, 11:40 AM   #19
SUV-ETR
Member#: 1310
2000 Impreza 2.5RS
BRP
Agreed.
I remember reading a post from a tuner with a dyno and a data logger that the problem is actually related to the ECU insisting to push timing even after det on some occasions. It only happened on about 25% of the dyno runs, and didn't match the ECU behavior on the other runs, where it behaved fine. Anybody know if that has been verified by other parties?
If that's true, it sounds like a plain ol' bug in the ECU, so a proper fix for the problem should NOT affect power or torque. If Subaru's solution is to simply back off timing everywhere, it would affect power/torque. I'm hoping for the "bug" story to be true...I've gotten addicted to the power!
Neal
SUV-ETR is offline   Reply With Quote
Old 07-21-2003, 11:44 AM   #20
dlowman
Member#: 22998
2004 WRX STi
Makes more since that this is some sort of a bug. Wonder if the car may actually end up with a little more power since the timing is not going to be pulled as crazily.
Old 07-21-2003, 12:01 PM   #21
SkirtBoy
Member#: 11056
2012 MB C250 CPO
Black on Tan
I wonder if those of us in the tri-state can just go to SOA and get it done?
SkirtBoy is offline   Reply With Quote
Old 07-21-2003, 12:12 PM   #22
RichQY
Member#: 31948
2004 STi
thx a lot Porter!!
great news
i d take a lil torque loss over constant det on anyday, plus we haven't seen any evidence this will actually affect hp/torque.
RichQY is offline   Reply With Quote
Old 07-21-2003, 12:34 PM   #23
wolverine
Member#: 36571
2004 WRX STi
Black & gold
Default ECU problem?
Porter,
If it is an ECU software issue, then should the problem be inherent in all STis as they all share the same software? Or is it that there are different revisions? If it is a software issue, then I think it should affect all cars (if they run on 91). In that case, should there be a recall then?
I am still in break-in, so I don't know. But, if I have det (and I'm on 91), I sure would not want to demonstrate it to the dealer if I don't have to; but rather just get an ECU reflash.
Thanks in advance for any info you can provide...
wolverine is offline   Reply With Quote
Old 07-21-2003, 12:45 PM   #24
spool1536
Member#: 39724
04 WRX STI
Been watching this thread a long time.....I just broke my car in this past weekend and found mine to be afflicted also. I called SOA and got no formal admission that the problem exists. I made an appointment with the service manager at my dealership who says he has heard nothing of this problem. Although, mine is only the 3rd STi they have sold. I think this is very good news....I just hope it actually fixes the problem.
spool1536 is offline   Reply With Quote
Old 07-21-2003, 12:53 PM   #25
zacek
Member#: 19467
04 WRX STi
WR Blue - original owner
is there any official SOA tech. paper about this? I would like to know some technical and background info. on this issue by SOA.
Will someone with access to the on-line subaru tech. site check on this?
zacek is offline   Reply With Quote
AccessPort v2.0 Update Released mike91401 South West Impreza Club Forum -- SWIC 10 02-08-2007 04:30 PM
04 STi ECU reflash confirmed (ping fix)??? stealitall Engine Management & Tuning 10 12-12-2006 05:04 PM
WTB 02-03 STi I/C splitter and STi Aspen white hood scoop.Also need 04 STi ecm Hondaslayer Private 'Wanted' Classifieds 8 07-30-2005 09:58 PM
Anyone local have an STi ecm lying around? Hondaslayer Mid West Subaru Owners Club Forum -- MWSOC 3 04-01-2005 09:14 PM
Question for USDM STI ECM experts NMLegacy Subaru Conversions 3 11-16-2004 07:57 PM
