Welcome to the North American Subaru Impreza Owners Club Friday February 27, 2015
Old 07-31-2003, 06:54 PM   #151
dlowman
Member#: 22998
2004 WRX STi
GT35R 572 whp 93/meth
Guys,
One guy I know of has already had the reflash done with no worries. Mine is being done as we speak. I should have it back on tuesday if all goes well. Till then I am in my loaner car courtesy of Porter at Gwinnett Subaru's.
Dan
dlowman is offline   Reply With Quote
Old 07-31-2003, 07:22 PM   #152
hatchy
Member#: 36852
2004 STI
Can I just take out the ECU and give it to the dealer for the reflash? I don't need a loaner and my car would be perfectly happy in sitting in my garage without a brain.
hatchy is offline   Reply With Quote
Old 07-31-2003, 07:40 PM   #153
mfisch
Member#: 28591
i seriously doubt the dealer will let you pull the ECU - that would be too easy, but they may have liability/warranty issues.
i finally brought mine (2600 miles now) in for the reflash - i had been running a mix of race gas (100 octane - from a 76 station) and 91 octane from chevron (tucson) which brought the octane up to 94. things were cool for ~2 weeks but today i got det bad and stopped by the dealer. no problem w/the tech reproducing the det. they'll give me a loaner for a few days while they send it (the ECU) back to cherry hill or wherever.
the SOA dude onsite said the the ECU will relearn w/the higher octane gas and det will come back - it did. he also said the diff disable thing in the ebrake was BS...
i mentioned that some ppl on the 'net seemed to be impressed by the speed at which SOA got the fix out there - citing serious time issues with getting a map through the EPA or whoever. he said it was easy as they are decreasing timing vs. increasing. i reckon there is less of an env impact worry with decreasing their crazing timing at ~4000 rpm
heheh, this aint isht (as far as impacting my satisfaction with a product). try an s2000 out for a real disappointment - after making excuses for a POS car for almost 3 years i dumped it, ended up with my wife's '02 WRX (gee how did she end up with one of those?) and there was no turning back - the '02 turned into an '04 STi (thank you Galles-Davis) - hey i got permission first!
'dios,
-mike
mfisch is offline   Reply With Quote
Old 07-31-2003, 07:57 PM   #154
KoneKiller
Member#: 39191
2004 WRX STi WRB
Red 1990 Spec Miata
Huh? BS as in it doesn't do that? or BS in that it isn't worth doing?
Sorry this is off thread.... but I gotta know!
KoneKiller is offline   Reply With Quote
Old 07-31-2003, 08:07 PM   #155
Ringboy
Member#: 40693
2004 WRX STi
Default Re: Re: Lucky
Originally posted by wolverine
My experience shows that if I don't WOT between the 4k to 5k mark, and then WOT after 5k up to red-line, I don't get det either. It is only when I WOT at low rpms and keep it there until I hit 4K-5K range, that's when I get det.
This is exactly what I am experiencing. Wolverine, are you having your's reflashed? Can anyone make any comments yet if they have had their's done?
Ringboy is offline   Reply With Quote
Old 07-31-2003, 08:12 PM   #156
hatchy
Member#: 36852
2004 STI
Pulling the ECU is only a few 10 or 12mm bolts, but I see your point. I've pulled the ECU a few months ago and it was really easy. The dealer doesn't know about the reflash. Neither does 1800subaru3. And I guess they won't until the reflash is out of "beta".
How did you guys get on the list? What dealers?
Old 07-31-2003, 09:08 PM   #157
Burke
Member#: 38939
2004 STI
Black w/ Gold Rims
Default drag
Well, I did have to start the car and for that I reved to 4k dumped the clutch which dropped the revs to 2.5-3k then it was WOT all the way up to 7K. So I am hoping that means I have not seen the det problem yet. I am worried that someone else here was smooth as glass then at 3200 miles started getting det. Weather condition changes maybe?
Burke is offline   Reply With Quote
Old 07-31-2003, 09:38 PM   #158
markpaco
Member#: 33743
2004 Impreza WRX STi
WRB/Silver
Default Got mine back
I just got mine back and I drove it hard through the lower gears at WOT to redline with no pinging. I even tried loading the car more by running the A/C at the same time (although it cuts it out at WOT).
The service was pretty quick. I dropped it off on Monday afternoon and the ECU was mailed out on Tuesday. I assume they got it back today, reinstalled it, test drove it, and then I picked it up this afternoon. I didn't feel any noticable power loss but suspect that there is one.
markpaco is offline   Reply With Quote
Old 07-31-2003, 09:44 PM   #159
RichQY
Member#: 31948
2004 STi
Originally posted by STiBro
So it sounds like you did a WOT blast on the car, without a break-in? You're motor will not last. You're supposed to Grand-Ma it for the first 1K miles!
NO wot. i posted in another thread. it was 98 outside
i was going up a hill on 3rd, very moderate throttle position in 3 rd gear running just a tick over 3000 rpm.
i guess my dealer filled up w/ piss gas.. i told them not to..
those cheap bastards
RichQY is offline   Reply With Quote
Old 07-31-2003, 11:44 PM   #160
happasaiyan
Member#: 37731
please dont spew vomit all over this thread. or board for that matter.
happasaiyan is online now   Reply With Quote
Old 08-01-2003, 12:06 AM   #161
ERIC DRAVEN
Member#: 37520
does anyone know about a reflash for CA?my dealer said soa is still working on it.
ERIC DRAVEN is offline   Reply With Quote
Old 08-01-2003, 12:27 AM   #162
mfisch
Member#: 28591
if you get repeatability on the det (nail it out of the hole, and you hear that light krinkly, rattly, ppprrrrriiinkkkk comin' up on 5K) just run it down to the nearest subie dealer and tell them you are getting detonation when you nail it coming out of the hole - so to speak.
they'll want to run it for themselves (can you blame them - it's an sti). if you have repeatability this should not be an issue. the tech (and soa rep) who tested my vehicle even offered to take me along!
the soa rep assured me the det they were hearing was not going to "hurt" the car, but i stated my preference for the new map any way.
the only drag is leaving the car at the dealership - i've been very polite so i hope the car gets indoor storage.
dunno if this is beta code or not though, i've a feeling this map has been around for a while.
-mike
Old 08-01-2003, 12:02 PM   #163
wolverine
Member#: 36571
2004 WRX STi
Black & gold
Default Re: Re: Re: Lucky
I am going to have mine reflashed... as soon as I use up my full tank of 94! Because I don't have det with 94 (91 mixed w/ 100).
wolverine is offline   Reply With Quote
Old 08-01-2003, 12:17 PM   #164
horshack
Member#: 19236
Axis GT35/40R STi
Not back yet
If available, can someone please do some before and after dyno charts ?
I cannot find anyone in the Phoenix area that wants to do the reflash, including myself, without more data to support what has changed and the possible performance implications.
Need more data! Will SOA ever lets us know what the reflash does?
horshack is offline   Reply With Quote
Old 08-01-2003, 06:23 PM   #165
mfisch
Member#: 28591
you can come down to tucson next week sometime and see how the new map performs on my car if you like.
possible performance implications? they drop timing advance at ~4000... i don't think performace will go up...
i'm getting det on 94 octane also.
heheh, you can wait on cobb i guess, if you want dyno info, etc. and are willing to buy their prom burner & code
Old 08-02-2003, 05:51 PM   #166
jcnel_wrx2k3
Member#: 38268
2003 WRX
WR Blue
Default would somebody explain.
Hello All,
I'm confused. If detonation is basically the ignition of the fuel/air mixture BEFORE the correct time that the piston needs to move in order to transfer the pressure power (burning air/fuel) to rotational power, isn't detonation (aka pinging) a "power loss" already?
So many claims here is that 'fixing' a detonation problem with the STi will cause a "power loss." Is this true?
Later,
jcnel.
jcnel_wrx2k3 is offline   Reply With Quote
Old 08-02-2003, 06:21 PM   #167
markpaco
Member#: 33743
WRB/Silver
Just because the spark plug fires does not mean that peak pressure occurs instantaneously. Because there is a delay in the combustion depending on the pressure, spark intensity, fuel ratio, and turbulence in the cylinder at different rpms, the computer must compensate by adjusting the timing. Ideally, you want to have peak pressure at or near TDC so that you can utilize all the energy on the power stroke. Since the timing will not be advanced as far as Subaru originally intended with the reflash, the peak cylinder pressure may be slightly after TDC which results in a power loss compared to a slightly more advanced timing setting.
Old 08-02-2003, 06:42 PM   #168
jcnel_wrx2k3
Member#: 38268
2003 WRX
WR Blue
Default hmmm...i understand a little better.
All of the evidence I've seen about pinging, detonation and such is that the energy to actually make the 'ping' is "lost" in stressing out engine internals. One really good detonation will actually blow the tops off of the motor, melt pistons, or cause extra and eventually dibilitating stress on crank bearings.
Therefore, isn't pinging 'still' a power loss, because the power in the fuel/air mixture is ending up someplace else, rather than turning your crankshaft?
So...if Subaru has this fix, could there be a chance of a better power result at the rpm range in question?
Cheers,
jcnel.
Old 08-02-2003, 08:46 PM   #169
horshack
Member#: 19236
Axis GT35/40R STi
Not back yet
Have you already dropped off your car for the ECU shipment?
If not, and your willing, let me know I would like to set up some Dyno time (before and after reflash) to gauge the results.
I Would be willing to foot half the bill for Dyno time.
Old 08-04-2003, 12:34 PM   #170
dlowman
Member#: 22998
2004 WRX STi
Well I got my ECU reflshed and my car back today. I do not notice any horsepower loss. I haven't driven the car since thursday. It does feel slightly different but I can't put my finger on it. The butt dyno is making me think there may be a little more power on the top end. I certainly do not think it has lost any power. The car should be more consistant now anyway. I would say its definately a thing you should do.
Old 08-04-2003, 04:40 PM   #171
RichQY
Member#: 31948
2004 STi
thx man.
i ll get on it once my car has finished break in.
this det problem is actually helping me keeping the rev limited
Old 08-04-2003, 07:03 PM   #172
orthojoe
Member#: 37237
hey, does anybody with insider info know exactly what the reflash does? sparks? I turned in my STi today to get the reflash, hopefully it'll fix the problem, but I'd like to know what it does.
orthojoe
orthojoe is offline   Reply With Quote
Old 08-05-2003, 09:46 AM   #173
Porter
Member#: 486
2004 Forester XT
bug spattered
We've now had 2 vehicles flashed and back on the road. The first one was a 4 business day turnaround, the second was a 2 business day turnaround. The customer (dlowman) dropped the vehicle off on Thursday and we had him back up and running on Monday.
I'll defer to the owners for reports on performance and presence of ping.
The key to all of this is that the cars were already listed in Subaru's system because we had filed the paperwork properly with Subaru in order to start the process. This is not going to be a situation where you go into the dealer for the first time and they flash it and give it back to you. Here are the steps:
1) If you have ping, make an appointment when you can spend about an hour at the dealership.
2) You must get a Subaru Certified technician to ride along with you and they *must* be able to hear the ping. Therefore, your problem *has* to be reproducible.
3) Once the ping is 100% verified, then the service department can take action, typically by filing a QMR so you have a case number that is actionable. The service department will probably have to have input and approval from their regional rep before they can proceed.
4) Assuming everything else has been done and Subaru has approved the reflash, you will need to make an appointment to drop your vehicle off with the dealer while the ECM is sent for reflash. It's highly unlikely that this will happen the same day as the ping verification, so don't expect an immediate fix.
5) Drop your vehicle off, get your loaner, and come back when the dealer notifies you that everything has been completed and the vehicle checks out OK.
Porter is offline   Reply With Quote
Old 08-05-2003, 02:14 PM   #174
Corkfish
Member#: 39503
I have a Forester XT and have noticed that there is an occasional pinging when I accelerate very hard. Since the engine is similar to the STI, I wonder if you'll see this problem occuring with the XT as well.
Corkfish is offline   Reply With Quote
Old 08-05-2003, 02:45 PM   #175
wolverine
Member#: 36571
2004 WRX STi
Black & gold
Is it quite audible? How long does it last? On the STi, it is 1-2 secs. Also, what gas are you using? Is there an rpm range this occurs in? Without more info, we can't really tell...
AccessPort v2.0 Update Released mike91401 South West Impreza Club Forum -- SWIC 10 02-08-2007 05:30 PM
04 STi ECU reflash confirmed (ping fix)??? stealitall Engine Management & Tuning 10 12-12-2006 06:04 PM
WTB 02-03 STi I/C splitter and STi Aspen white hood scoop.Also need 04 STi ecm Hondaslayer Private 'Wanted' Classifieds 8 07-30-2005 10:58 PM
Anyone local have an STi ecm lying around? Hondaslayer Mid West Subaru Owners Club Forum -- MWSOC 3 04-01-2005 10:14 PM
Question for USDM STI ECM experts NMLegacy Subaru Conversions 3 11-16-2004 08:57 PM
