Go Back   NASIOC > NASIOC Archives > NASIOC Archives > STi Forum Archive
Old 07-21-2003, 06:04 PM   #1
pandagc8
Member#: 31102
200 Imp@Wrx @Sti
Default Oil Cooler
Does any one know if STi comes equiped with an oil cooler?
Thanks.
pandagc8 is offline
Old 07-22-2003, 12:08 AM   #2
R Diamond
Member#: 58
04 STi (blue/gold)
98 2.5RS Turbo (sold)
It does.
R Diamond is offline
Old 07-22-2003, 01:04 AM   #3
Peaty
Techno Sapien
Member#: 449
2016 BRZ Limited
Ice Silver Metallic
that thing below the filter w/ the hose coming out of it is the oil cooler:
It's the same one they use on auto foresters, Forester XT, the H6 and other turbos like the WRX.
Peaty is offline
Old 07-22-2003, 01:13 AM   #4
StiDreams
Member#: 26315
07 Outback
Silver/Silver
I read somwhere that there was a cooler so I looked it up. I saw the diagram for this in the service manual. I was a little confused about how it cools the oil. I was expecting something with hoses to a radiator and thermostat/valve control flow into the radiator. Is there a tech here with some knowlege of how well this thing works?
StiDreams is offline
Old 07-22-2003, 01:23 AM   #5
Peaty
Techno Sapien
Member#: 449
2016 BRZ Limited
Ice Silver Metallic
It uses the thermostat from the radiator. It's a fluid to fluid pancake type cooler. It uses the coolant rather than air like I think you were thinking. It alternates layers of oil and coolant. I installed on on my RS some time go. Here are some closer pics:
http://www.scoobymods.com/forums/sho...=&threadid=170
I think it does a good job. It's nice because the car warms up faster so in the winter you have heat quicker, nice bonus But in that case I suppose it's working as a coolant warmer and not an oil cooler
Peaty is offline
Old 07-22-2003, 09:36 AM   #6
ScoobyAficionado
Member#: 36575
'04 STi
Default Power Steering Fluid Cooler
That's nice to hear... I was always worried about aftermarket rad-style oil coolers over cooling my oil in winter time.
Do you know if it also has a power-steering fluid cooler? I haven't checked, nor ordered my shop manual yet.
ScoobyAficionado is offline
Old 07-22-2003, 10:17 AM   #7
Peaty
Techno Sapien
Member#: 449
2016 BRZ Limited
Ice Silver Metallic
Default Re: Power Steering Fluid Cooler
Quality oil coolers the air to fluid type have thermostats to prevent overcooling AFAIK
Not sure about the PS fluid but I don't think so.
Peaty is offline
Old 07-22-2003, 10:29 AM   #8
ha-evolution
Member#: 31556
15 STI WRB ordered
09 Accord Coupe V6 mt
I am installing an oil filter adapter for my oil temp and oil pressure sensors. As this is after the oil cooler, is this going to make my oil temp readings artificially low?
ha-evolution is offline
Old 07-22-2003, 10:59 AM   #9
ScoobyAficionado
Member#: 36575
'04 STi
Default Oil Temperature
That depends on whether you're looking for the oil temp coming from the engine, or the oil temperature going to the engine on the next pass.
Either way, you're getting a relative measurement from which you can base tuning on in the future. It should serve your purpose.
Flame Guard Sleeving for Oil Cooler/Differential Cooler Hoses vpwseah Engine/Power/Exhaust 0 09-10-2007 07:19 PM
Top mount Oil cooler/tran cooler ColesSTi Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 08-31-2006 08:10 AM
Leaking Oil from oil filter/oil cooler AustinSTi Normally Aspirated Powertrain 3 01-08-2004 12:42 AM
Where are my oil cooler and trans cooler located at? Hit Man X Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 10-28-2002 09:40 AM
spark plugs, oil coolers, transmission coolers, upgraded radiator, who has them? ChristophWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 06-04-2002 12:48 AM
