Go Back   NASIOC > NASIOC Archives > NASIOC Archives > STi Forum Archive
Old 07-21-2003, 06:22 PM   #1
SloPok
Member#: 37344
04 WRB STI 04'
Default DCCD question?
When putting the DCCD into lock or the position right under it, it sounds like it's going to break something. I can park the car, back out, or even try to move 3 feet straight forward and it makes a series of real loud clunks and the cars jerks around like I hit a wall, anyone else know about this?
SloPok is offline
Old 07-21-2003, 06:34 PM   #2
Cacophony
Member#: 213
2004 Mazda RX-8
Yeah, it's because the diffs are locked . Jump into a 4wd pickup truck sometime, put in 4x4, and then try to park it.
It'll sound and feel horrible. That's why you don't use things like that unless you are in snow or mud or something similar. Really now, what posessed you to lock the diffs and try to drive around in normal conditions anyway??
Cacophony is offline
Old 07-22-2003, 09:24 AM   #3
SloPok
Member#: 37344
04 WRB STI 04'
Was trying to change the power more to the rear, even when it wasn't in the lock mode, the position right under it, it still does the same.
So why does the car act like this, but in snow or mud it would be different?
SloPok is offline
Old 07-22-2003, 09:35 AM   #4
T-WRX Racer
Member#: 21530
2004 STI--evo killer
[email protected]
When you set the diff to lock. You are locking the diff's. So All four wheels spin at the same rate with the same amount of power. And when you are turning the wheels, the inside wheel has a shorter distance to go (so it should spin less) but with the diff's locked you are forcing it to go the same distance as the outside wheel. Which puts stress on the drivetrain causing it to knock and clank around. When the Diff's are not locked the inside wheel will free spin at a slower rate to compinsate for the shorter distance it has to travel.
The farther forward the DCCD is set will cause the diff's to become more closely to a locked poistion. So instead of being 100% locked, you may be 90-85% locked.
T-WRX Racer is offline
Old 07-22-2003, 10:09 AM   #5
ANZAC_1915
Member#: 456
2008 Forester XT
Steel Gray Metallic
Perhaps you should read the owner's manual....
ANZAC_1915 is offline
USDM STi tranny into WRX; DCCD questions jesse370 Transmission (AT/MT) & Driveline 20 09-22-2004 01:01 PM
DCCD question 80884 Transmission (AT/MT) & Driveline 5 05-16-2004 11:37 AM
DCCD question MaciekSTI Newbies & FAQs 2 11-20-2003 10:15 AM
DCCD question. Pre-diddy STi Forum Archive 1 09-06-2003 05:15 PM
DCCD Question drdray STi Forum Archive 6 08-16-2003 12:25 AM
