Old 07-21-2003, 07:35 PM   #1
dpjef
Member#: 18984
2002 Impreza 2.0
dark blue
Question lambda readings / ignition timing
Hi all,
Don't know much about these things (yet) so please enlighten me !
02 sensor :
My lambda readings are between 0.69 and 1.49 but that seems a bit odd to me. Shouldn't lambda be between 0.90 and 1.10 ? I have read that ideal lambda is 0.90.
Ignition timing :
have seen timing between 0 and 47 . Isn't that also a bit 'conservative' (knock correction is ONLY -0.5)
(ps. it's for the n/a Impreza)
dpjef is offline   Reply With Quote
Old 07-21-2003, 08:16 PM   #2
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
O2 readings should be between 0.0 & 1.0.
Timing will vary for engine load & rpm....so it's hard to say where it should be. Usually you check it at idle to verify everything is fine.
Legacy777 is offline   Reply With Quote
Idle timing/ low load ignition timing adjustment after cam install? NITROS Engine Management & Tuning 2 03-18-2009 02:32 PM
Valve timing & Ignition Timing volleykid General Community 0 09-12-2005 11:25 AM
('93-'01) Valve Timing & Ignition Timing volleykid Impreza Forum 0 09-12-2005 11:23 AM
how to read ignition timing datalog? ezatnova Engine Management & Tuning 0 02-07-2004 10:00 AM
MSD DIS 2 ignition timing control anyone out there tried it yet? MPREZYA Technical Forum Archive 1 06-07-2000 09:38 AM
