Welcome to the North American Subaru Impreza Owners Club Friday February 5, 2016
Old 07-21-2003, 10:50 AM   #1
viodea
Member#: 7497
WR Blue
Default Need help: engine stalls (non-subaru)
My car is not a subaru but a 93 Nissan Sentra SE-R automatic.
My friend helped me to install the motor and tranny mounts. During installation, my friend accidently cracked the air box. So, he put some silicone sealant on it to seal it.
Then, I drove the car back. I felt the car lost some power. After more driving, the car toally lost power. The oil light went on a few times. Also, stalled a few times, usually on stop or slow corner. Then, the water temp. raise.
I checked the oil level and looked good. That was my guess because I can't really tell by looking at the dip stick. It looked like way more than the max but I wasn't sure that was the really oil level or just the oil on the side of the tube mark it.
I also heard some weird noise. Sounds like some grinding noise a few times.
Was it my air box?
Was it the mounts?
Was it my oil level? (I'm going to do a oil change in the next few days and see if it helps)
thanks in advance.
viodea is offline   Reply With Quote
Old 07-21-2003, 11:38 AM   #2
tmat3
Member#: 2817
2001 Impreza 2.5RS
BRP
It sounds like you have no oil circulating the engine. The reason why I say that is because you wrote:
Oil pressure light came on because the engine lost oil pressure. Water temp rose because the oil wasn't circulating enough. You heard grinding noise because most likely main bearings started to wear out.
When you installed the engine and transmission mounts, how did you support your engine? Did you support it with an engine hoist from top, or did you support it with a floor jack at the oil pan? If at the oil pan, did you use a block of wood to help distribute the weight? If not, the oil pan may have warped to a point where oil pickup tube is now blocked.
If the oil pan is in a good shape, then your engine may have developed an oil circulation problem, not really related to engine mounts installation.
tmat3 is offline   Reply With Quote
Old 07-21-2003, 11:43 AM   #3
viodea
Member#: 7497
WR Blue
I support it using a floor jack and a block of wood.
I didn't notice anything wrong with the oil pan but I'll check again tonite when I do the oil change.
Old 07-21-2003, 11:53 AM   #4
viodea
Member#: 7497
WR Blue
Also, the grinding noise and oil light doesn't last long. The oil light came on a few times. Only a few seconds at a time. I think most of the time the engine just died soon after I see the light. Then I can start the engine again and the light is gone.
I heard the grinding noise twice and last for a few seconds. I hope there is no big damage here
Do you have any sugguestion on where to check first for the oil circulation thing?
thanks
Old 07-21-2003, 11:04 PM   #5
tmat3
Member#: 2817
2001 Impreza 2.5RS
BRP
I think the surest method to see if the engine has oil circulation is to hook up an oil pressure gauge.
When you change the oil, look for any metal shavings in the old oil. That's one of the indications that something has happened internally.
Need Help: Engine cranks but won't start evoeater02[wrx] Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 08-31-2007 03:20 PM
Need Help: Engine cranks but won't start evoeater02[wrx] Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 08-30-2007 02:41 AM
Need help- Engine stall, cooling fan issue chibearz Newbies & FAQs 1 07-30-2006 09:05 PM
Need help-engine stall and cooling fan issue chibearz Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 07-30-2006 07:26 PM
need engine advice (non-subaru) CalcVictim Off-Topic 13 07-17-2006 01:34 AM
