Old 07-21-2003, 08:41 PM   #1
lotusTT
Member#: 23359
2002 BMW M Coupe
Steel Gray
Default wrx injectors/fuel rails
I just bought a used turbo kit and it came with a set of WRX fuel rails. I was planning on using these to do the parallel fuel rail mod. If i go with the WRX rails, do I have to use WRX injectors? Will the WRX injectors even work with a 2000 RS?
here's some pics of what i have
lotusTT is offline   Reply With Quote
Old 07-21-2003, 09:25 PM   #2
STi-Nismo Dood
Member#: 4149
MY93 Impreza 6MT
GC8.6 Aspen White
yeah, new age wrx side-feed injectors are the same type as any 99+ impreza which is also side-feed. The O-rings should fit correctly since they are both made by FHI.
STi-Nismo Dood is offline   Reply With Quote
Old 07-21-2003, 10:17 PM   #3
markus
Member#: 438
2004 STi
White on Gold
I've heard of a number of "fitment" issues when trying to put WRX injectors into an RS manifold. Apparently if you use two o-rings instead of one, it solves the problem, but it's not bullet proof.
I believe Rev-Lab makes an adapter that will allow perfect fitment of WRX injectors into an RS manifold. It's not on there website, but apparently they do exist based on a Turbo Legacy thread I recently saw.
Link is here ==> Rev-Lab
Hope this helps.
Cheers,
MB
markus is offline   Reply With Quote
Old 07-21-2003, 10:21 PM   #4
lotusTT
Member#: 23359
2002 BMW M Coupe
Steel Gray
ahh ok, its the manifold that has trouble with the WRX injectors. So if I switch to WRX fuel rails, I can still use RS injectors?
Old 07-21-2003, 11:47 PM   #5
EJ25
Member#: 10768
uhhh don't u mean top feed? The older STI's are side feed.
the WRX injectors will fit a 99 manifold. The 2000 manifold can just be drilled out a bit or u can use the rev-labs adapters too.. but that air-assist **** is a pain in the A$$...
EJ25 is offline   Reply With Quote
Old 07-22-2003, 12:38 AM   #6
STi-Nismo Dood
Member#: 4149
MY93 Impreza 6MT
GC8.6 Aspen White
sorry, I got it very twisted, its anything my98 and older that uses side-feed and my99 and newer uses top-feed...
Old 07-22-2003, 06:16 PM   #7
smacksube
Member#: 4067
01 2.5 rs
so a 99-01 RS would use low impedance top feed injectors..
smacksube is offline   Reply With Quote
Old 07-22-2003, 06:25 PM   #8
inpreza kid
Member#: 3334
no. they use high impedance.
i also have a set of wrx injectors/fuel rails.. the fuel rails use different mounting points so i don't think they fit. the manifold on the 00+RS has air assist holes.. so not sure if the injectors fit either. also have a set of rev lab injector adaptors which didn't fit at all.. not sure if they corrected the problem since..
inpreza kid is offline   Reply With Quote
OEM WRX blue injectors, fuel rails and injector wire harness SedonaRed03WrX Engine/Power/Exhaust 5 01-08-2009 12:26 PM
04 Stock WRX TGVs, fuel rails, fuel injectors, chrome intake manifold smokeone954 Engine/Power/Exhaust 1 01-01-2008 09:39 PM
Will STi injectors/fuel rails fit in 06 WRX? scorcher2005 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 10 11-26-2007 07:34 PM
SoCal 909 WTB ASAP: 02 WRX stock fuel rail and injectors onefasazn Private 'Wanted' Classifieds 6 06-28-2007 04:40 PM
WTB: Broken/Inexpensive TGV, Injectors, Fuel Rails WRX, STI, & EVO 03GLHWRX Private 'Wanted' Classifieds 7 02-17-2006 04:59 PM
