Welcome to the North American Subaru Impreza Owners Club Tuesday June 2, 2015
Old 07-21-2003, 10:56 PM   #1
yebokmj
Member#: 2213
1995 Impreza w/EJ255
Brilliant Red
Default Help! Please tell me what this noise is.
I just did the head gasket on my DOHC 2.5 and I had some problems with the valves, when I got the heads back from the machine shop all the buckets and shims were just in a box. I have everything adjusted to tollarance now, except for one which is to the looser side. it's supposed to be .25 and it's .30. Anyways here is how my engine sounds CLICK HERE
Any help would be greatly apprecited.
Joshua
yebokmj is offline   Reply With Quote
Old 07-21-2003, 11:00 PM   #2
Hondaslayer
think you
Member#: 4562
1995 Legacy LSi
1998 Forester, lifted.
The buckets and shims are out of order,they are not marked either,when they are disassembled you must mark which goes where.Go back to the shop and bitch slap the idiot that did that.
Old 07-21-2003, 11:06 PM   #3
yebokmj
Member#: 2213
Brilliant Red
Default Okay what now
So your saying it's that my vavles are still to much out of adjustment? Or are you saying that you just can't put random buckets in even if it has the proper shim? What do I do? And what is the noise exactly?
Joshua
Old 07-21-2003, 11:12 PM   #4
Hondaslayer
think you
Member#: 4562
1995 Legacy LSi
All the buckets go into a certain slot,if they are put out of order the valve train will be very noisy,I will check with my techs tommorow and see what you can do aside from trial and error.
Old 07-22-2003, 10:28 AM   #5
Wedge
Member#: 2279
2000 Slingshot
Pastelito Racing
VERY interested in this.....
BUMP!
Wedge is offline   Reply With Quote
Old 07-22-2003, 11:24 AM   #6
Hondaslayer
think you
Member#: 4562
1995 Legacy LSi
You need to re-assemble the head and using a feeler gauge measure the distance between the top of the bucket and the camshaft lobe,I will find the measurement for ya when I go to lunch.but plan on pulling the cams and buckets out several times.
Ben,
Good luck.
Old 07-22-2003, 12:06 PM   #7
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
Ben,
Good luck.
the buckets shouldn't matter
be prepared to replace all the shims and set new tolerances. there is also a tool you will need so that you do not need to remove the camshaft to do so.
you are going to need a good set of feeler guages, a calculator and a service manual for your car because they list the buckets in there, also pick up a metric micrometer, it will make measuring the bucket thickness(if the numbers have worn off).
Jeremy
Old 07-22-2003, 12:43 PM   #8
Wedge
Member#: 2279
2000 Slingshot
Pastelito Racing
Will the SOHC head experience this same problem?
Old 07-22-2003, 01:01 PM   #9
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
no, the SOHC is a rocker/tappet system which uses an adjustable tappet to control valve lash.
Jeremy
Old 07-22-2003, 01:02 PM   #10
HOK
Member#: 447
1999 EJ22T222B&EVO
Are we racing yet?
sounds normal to me hahahaha just a litttle loud
HOK is offline   Reply With Quote
Old 07-22-2003, 02:21 PM   #11
The Professor
Member#: 23183
2002 Cobb StageIIWRX
WR Blue
Thumbs down
That does NOT sound normal to me. Good luck man I wish I knew exactly how to fix it but it sounds like you have some help from your friendly neighborhood Naisoc-ers.
PS I'm sure HOK was joking
The Professor is offline   Reply With Quote
Old 07-22-2003, 06:31 PM   #12
yebokmj
Member#: 2213
Brilliant Red
Default Input
Thanks for the input guys,
I looked into tracking down that special tool that allows for you to change shims without removing the cams and it's $250. I understand how to adjust the shims and I have used a feeler gauge to adjust all the valves to tollance. Only one exhuast valve is off and it's .30mm instead of the .25 or the max tollarance of .27 Is it possible that small differance is the cause for the noise?
Just to be clear, it doesn't matter which bucket goes where as long as it's accompanied by the correct shim?
Also one person mentioned timing belt, if that was off by say one tooth could that cause it? What if I was given the wrong headgasket? If I was given a SOHC gasket could this cause the noise?
Joshua
Could someone please tell me what this piece is called? Coconut24 Interior & Exterior Modification 5 04-16-2010 04:34 PM
Can someone tell me that this noise is? 02WRX djart Service & Maintenance 13 04-20-2008 04:42 PM
Cross Post: Help! Please tell me what this noise is. yebokmj New England Impreza Club Forum -- NESIC 5 07-22-2003 06:53 PM
Cross Post: Help! Please tell me what this noise is. yebokmj Legacy Forum 1 07-22-2003 10:57 AM
Cross Post: Help! Please tell me what this noise is. yebokmj Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 07-22-2003 07:36 AM
