Old 07-21-2003, 11:29 PM   #1
The_Triton
Member#: 18647
Default Best way to get the car off the ground???
I will be doing my 30,000 mile tune up here shortly. I'm wondering what would be the best way to get the car up on 4 jackstands? I'm not sue where to put the points at. I want to be able to work on all 4 rotors at the same time. It will prolly be up on stands for a couple of days.
Any info would be appreciated.
The_Triton is offline   Reply With Quote
Old 07-22-2003, 01:17 PM   #2
kenchan
Member#: 15106
the rear is real easy, just use the rear diff to jack up and use jack stands on the factory stand points. u're using a hydraulic jack, right? not the factory one?
the front i usually just jack up one side at a time (since my jack is a piece of crap) under the main frame beam parallel to the factory
jack points and put a jack stand on the factory stand points.
kenchan is offline   Reply With Quote
Old 07-22-2003, 01:36 PM   #3
ITWRX4ME
Member#: 24472
2001 Miata
I've been told that it's safe to jack up the front with the jack under the crossmember(or whatever it's called). It's that hunk o' metal under the oil pan.
Make sure that you're jack can roll because, once one end of the car is on stands, it's possible to pull it off if the jack doesn't roll as it's raising the car.
ITWRX4ME is offline   Reply With Quote
Old 07-22-2003, 01:42 PM   #4
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
As mentioned, jack up the rear under the rear diff.
Jack up the front under the longitudinal brace/link of cross member. The piece is not under the oil pan, it is behind the oil pan.
Legacy777 is offline   Reply With Quote
Old 07-22-2003, 01:45 PM   #5
Safir
Member#: 3873
. Paradise is
like Disney with hookers
I've heard the piece behind the oil pan called the "jack plate" and is a good place to jack the front end - i just suggest the use of a piece of wood unless your jack has rubber to keep this piece from becoming mangled, as mine is dented pretty badly
Safir is offline   Reply With Quote
Old 07-22-2003, 03:57 PM   #6
Valhakar
Member#: 39514
2003 WRX 2.5L Hybrid
Mostly Blue
Rear Differential to get the back end up.
I use the subframe just forward and inside of the standad jack point for the 3 ton jack. The jackstand goes under the standard jack point.
-Valhakar
Valhakar is offline   Reply With Quote
Old 07-22-2003, 05:22 PM   #7
Ti-REX
Member#: 21741
LGT Limited Wagon +
WRB Wagon STI V7/8
What he said ^^^^^
Mine is all mangled as well. Just make sure it doesn't slip off if sitting on a piece of wood.
I've done it a thousand times, works perfect.
Ti-REX is offline   Reply With Quote
Old 07-22-2003, 10:26 PM   #8
ChrisW
Member#: 4181
2003 Lancer Evo 8
It's Blue, ok?
The jacking points are clearly labeled in your manual located in the glove box.
Use the rear diff for the back, the jacking plate for the front.
ChrisW is offline   Reply With Quote
Old 07-22-2003, 10:39 PM   #9
The_Triton
Member#: 18647
Cool. I'll be using a hydralic jack and 4 jack stands.
Cheers <insert smilie downing a pint>
Old 07-23-2003, 01:51 PM   #10
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
I though ramps where the best way
Old 07-23-2003, 02:08 PM   #11
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
2000 2.5 RS, '14 For
92 5MT SVX
Magnetic force levitation is the best way to get it off the ground . You can't use ramps when you need to put the car on stands in order to take the wheels off, and you'd be insane to try it .
Brian
Old 07-23-2003, 03:19 PM   #12
Austin
Member#: 7089
2016 STi
I jack the front using the stock jack points, then put stands under the subframe.
Jack the rear with the diff, stands @ the jack points.
Austin is offline   Reply With Quote
Old 07-23-2003, 05:20 PM   #13
ciper
Member#: 15543
90BJ Legacy LS ABS
"in order to take the wheels off"
He is doing the 30k service, I didnt think wheel removal was necessary.
Old 07-24-2003, 10:42 AM   #14
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
It's easier to inspect the brakes with the wheels off.
Tim Sanderson is offline   Reply With Quote
Old 07-24-2003, 10:47 AM   #15
The_Triton
Member#: 18647
I'm going to be replacing pads and bleeding brake lines. I'll also be installing the rear diff plate while it's up. As well, I'll be replacing all the fluids and would like to have it up on jacks to be easier to get to.
thnx for the help!!!
Old 07-24-2003, 02:09 PM   #16
ciper
Member#: 15543
90BJ Legacy LS ABS
"It's easier to inspect the brakes with the wheels off."
Forgot about that part
Old 07-27-2003, 10:52 AM   #17
ImprezaVA
Member#: 32846
1998 Impreza L-SOLD
Arcadia Green
I usually check the brakes every tire rotation. It's just as easy though, to look at the outside brake pad through the caliper to check for thickness and rub your finger over the rotor to check for scoring or ripples.
-Charles-
ImprezaVA is offline   Reply With Quote
Old 07-28-2003, 01:03 PM   #18
bunot
Member#: 21641
4EAT [email protected]
Now a 6MT! beyatch!
i'd get some CMU blocks and let the car sit there if you're doing this for a couple of days. make sure the blocks are big and solid. you don't want that sucker cracking and dropping your car.
this way, you won't need 4 jackstands.
jason
bunot is offline   Reply With Quote
Old 07-30-2003, 01:46 PM   #19
handyyguy2002
Member#: 37119
2003 WRX
Question CMU Blocks???
Originally posted by bunot
i'd get some CMU blocks ....
jason
What are CMU blocks?
handyyguy2002 is offline   Reply With Quote
Old 07-31-2003, 01:29 PM   #20
The_Triton
Member#: 18647
Default Re: CMU Blocks???
Ditto
Old 07-31-2003, 02:22 PM   #21
leecea
Member#: 37359
2003 WRX
I just looked on Google - it's a concrete block (Concrete Masonary Unit).
I think they might be too brittle to trust, but I don't know much about concrete. I guess my foundation is made with them and my house hasn't collapsed yet
leecea is offline   Reply With Quote
Old 07-31-2003, 05:10 PM   #22
vrg3
Member#: 25796
1993 Legacy Turbo
Burgundy
If these are the same thing as cinderblocks, you really shouldn't use them. People do, but they are rather prone to fracture. They can crumble.
A semi-decent pair of jackstands can be bought for like $30. Your life is hardly worth saving $25.
vrg3 is offline   Reply With Quote
Old 08-01-2003, 03:04 AM   #23
ha-evolution
Member#: 31556
15 STI WRB ordered
09 Accord Coupe V6 mt
Hire ten illegal immigrants to lift your car on command.
ha-evolution is offline   Reply With Quote
Old 08-02-2003, 12:22 AM   #24
bunot
Member#: 21641
Now a 6MT! beyatch!
LOL....sorry. i forgot to explain what cmu is. it should be stable when you put it right-side up. better if you have a piece of plywood to disperse the load.
just giving a suggestion that might save you some money. personally, i'd just jack 1 side at a time. it's not like it takes 30 mins. to jack the car up.
jason
Old 08-02-2003, 05:49 PM   #25
santofontana
Member#: 26876
1994 Camaro Z28 383
Black M6
If you cant figure out how to jack your car up yourself you probably shouldnt be working on it.
santofontana is offline   Reply With Quote
Best way to get front Rotors off 5hif73r Brakes, Steering & Suspension 9 07-07-2009 01:39 AM
best way to get water stains off STI seats sc00ter Car Care & Detailing 4 11-13-2008 08:10 AM
best way to get bird crap off Hedbergsuby07 Car Care & Detailing 22 09-20-2008 01:31 AM
Best way to get tree sap off the paint? wrxsubaru Car Care & Detailing 15 12-26-2004 05:02 AM
('93-'01) Quick. Best way to get shoe polish off. the_gille Impreza Forum 11 05-29-2001 02:37 PM
