Go Back   NASIOC > NASIOC Subaru Models > Forester Forum
Old 03-30-2001, 10:46 AM   #1
Crashton
Member#: 3808
2005 Forester XT!!!
Crystal Gray Metallic
Question Next question ?
One more question. Where is a good place to get a 18mm rear swaybar. How will this change the handling? Is the 20mm bar too much. I want a little less push, but not tail happy.
Thanks
Chuck
Crashton is offline   Reply With Quote
Old 03-30-2001, 11:01 AM   #2
lakepop
Member#: 3851
2007 Outback Ltd.
Champagne Gold
Post
There is a ton of info in the archived forums. Probably more than you will ever need.
Try "search"- sway bar- archieved forums(tecnical for starters)
Hope this helps ..it is much discussed.
lakepop is offline   Reply With Quote
Old 03-30-2001, 03:12 PM   #3
Ken S
Member#: 1895
05 Leg GT Ltd. W
Talking
In my opinion, an 18mm should have been offered as stock. You still have a good amount of understeer and it is quite controllable.
You can probably order the 18mm bar from any Subaru dealer. It's the same part used for the Impreza.
You can also try some of the below places:
http://www.spdusa.com/prod01.htm http://www.autocaresubaru.com/suspension.html http://home.att.net/~teaguesauto/parts1.htm
Ken
Ken S is offline   Reply With Quote
Before posing you next question to Janq, consider.... Mumbles Off-Topic 21 05-19-2006 04:24 PM
My next question for OT. Recommend me a GOOD digital camera. Christoff Off-Topic 26 08-01-2005 10:46 AM
Next question about my computer build: WHich case anad power supply Eric SS Off-Topic 28 08-07-2003 06:49 PM
The computer project continues: next question.. Bahumut Off-Topic 17 03-18-2003 02:17 PM
Shortblock dilemma solved- next question BADWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 24 10-18-2002 02:55 PM
