Go Back   NASIOC > NASIOC Archives > NASIOC Archives > STi Forum Archive
Old 07-22-2003, 09:46 AM   #1
Burke
Member#: 38939
2004 STI
Black w/ Gold Rims
Default Oil Temp Gauge
I just bought the S7 gauge package from AC and their instructions have got to be the worst ever. Does anyone know where the best spot to hook up the temp sensor is? Is there a stock bolt that I replace with the one they gave me? I don't have to tap anywhere do I?
Want to see pics?
Burke is offline
Old 07-22-2003, 05:03 PM   #2
rlavalle
Member#: 18384
2004 STi: 580 AWHP
Java Black Pearl
I understand the optional OEM oil temp sensor is plugged into the oil drain hole in the oil pan.
I'm also interested in alternative locations since I'll be adding one some day.
If you don't have or want an oil pressure sensor, you can use the port on top of the engine. There's a large allen bolt under the front/passenger side corner of the intercooler. Take off the intercooler and look down where it was. I use this for Oil Pressure.
Russ
rlavalle is offline
Old 07-22-2003, 05:32 PM   #3
Burke
Member#: 38939
2004 STI
Black w/ Gold Rims
Default sensor
I am picking up a stock drain plug and having it drilled and tapped for the sensor that came with the gauge. In effect I am creating the OEM oil temp sensor.
Burke is offline
FS: DEFI Amber 60mm boost, water temp, oil press, oil temp gauge w STi genome unit renda85 Exterior/Styling 11 08-03-2009 09:13 AM
Defi oil temp gauge..Prosport temp sensor..quick question skingfreak Electrical & Lighting 2 04-21-2008 07:33 PM
LA WTB: Oil Temp Sensor for lamco oil temp gauge Yulri Private 'Wanted' Classifieds 0 03-09-2008 09:14 PM
Can a defi oil temp gauge be used for water temp duty? hella_sti Interior & Exterior Modification 2 05-05-2007 04:56 PM
Oil Pressure vs Oil Temp Gauges GoodFinder Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 07-26-2002 02:51 PM
