Go Back   NASIOC > NASIOC Subaru Models > Forester Forum
Old 05-22-2001, 02:21 PM   #1
clee01
Member#: 6279
Question Strut Tower Brace
Finally, I received my parts today. Weather permitting, I plan to install these parts either tomorrow or the day after.
However, I had a question. I read the instructions on how to install it and it says the nuts are supposed be tightened to the listed torque. Is there similar requirement for the rear sway bar? If so, what's the required torque?
Thanks for your comments in advance. I'm very excited to install these already.
[This message has been edited by clee01 (edited May 22, 2001).]
clee01 is offline   Reply With Quote
Old 05-22-2001, 10:23 PM   #2
ferretboy
Member#: 4782
well SF9, AE92
SF9-Brack and AE92-faded
Post
Hey there Clee01,
Here are some links to check out... info and this strutbar info . I'm sitting here staring at my Rallispec 2.25 Forester exhaust!! itching to install it tomorrow in the morn if I have time before work. woohooo! <doing snoopydance> Man it sure is purty! Hope that helps ya out! btw you can actually just roll under the car to do the sway bar mod. it's very simple.
~ferretboy signing out.
[This message has been edited by ferretboy (edited May 22, 2001).]
ferretboy is offline   Reply With Quote
Old 05-23-2001, 09:14 AM   #3
juice
Member#: 1424
1998 Forester
Acadia Green Metallic
Post
The 18mm rear sway I got from SPT (Subaru OE, basically) had the torque specs printed with the instructions, IIRC.
It was not that high, though I don't remember exactly what they called for.
-juice
juice is offline   Reply With Quote
Old 05-23-2001, 10:48 AM   #4
clee01
Member#: 6279
Post
Ok, I picked up the torque wrench this morning and installed it according to the specified torque setting. Now I gotta find a place to test-drive to see the effect of front strut tower brace.
Juice, do you happen to remember the range of the torque specification? The one for the front strut tower brace was 14.4 ft-lbs, if that's any relevant.
Thanks for all your help/comments!
Old 05-24-2001, 06:14 PM   #5
clee01
Member#: 6279
Post
All right. Finished installing rear sway bar. I had some trouble taking out the old one and putting in the new one around the muffler but I got it.
Here's the pic. Does this look installed right? I mean, I don't see how it could not be since it's a simple replace but just want a confirmation.
<IMG SRC="http://www.cyberdyne-system.com/~clee01/forester/rear_sway_bar.jpg" border=0>
Thanks for your comments.
Old 05-24-2001, 11:34 PM   #6
ferretboy
Member#: 4782
well SF9, AE92
Have a Nice Day?
Hey what did you do with the other screws?? and that endlink? you're supposed to use the yellow ones!... just kidding, looks right to me. told ya it was a cinch. welcome to the junior mechanic club!
Old 05-25-2001, 12:25 AM   #7
juice
Member#: 1424
1998 Forester
Post
I think it was a little higher than that, but I don't remember the exact number. 20-25 rings a bell, but I'd look it up to make sure.
Actually, I was shocked by how little torque the front tower brace required. Then again the tendency is to over-tighten.
It may be in the shop manual - anyone have a set of those?
-juice
Old 05-25-2001, 09:07 AM   #8
Ken S
Member#: 1895
05 Leg GT Ltd. W
Post
Yep, looks like it's installed right to me -- nice and fat bar! Did your remember to put a bit of lithium grease between the bushings and bar?
Go out and try some turns -- you'll be smiling!
Ken
Ken S is offline   Reply With Quote
Old 05-25-2001, 09:37 AM   #9
clee01
Member#: 6279
Post
Ooops, the lower two pics were of the original sway bar. I just updated the picture.
Ken, yes, I did remember to put the lithium grease between the bushings and the bar.
I tried some turns today and it does feel better. It makes me feel even better because I was able to do the install.
Thanks for all of you for giving me comments and help. I love this forum!!!
GD Carbing Strut Tower Brace with Brake MC Brace ~ Rare! slowscooby Suspension/Brakes/Handling 20 02-22-2010 10:53 PM
Cusco Type OS V-Braces and Strut Tower Braces iLoveCookies Suspension/Brakes/Handling 11 10-28-2007 02:28 PM
Fender Brace better than strut tower brace dntouch Brakes, Steering & Suspension 34 03-22-2007 05:48 PM
Cusco rear strut tower brace, with V Brace. $225 Shipped!!! kccobra Suspension/Brakes/Handling 1 08-31-2006 11:42 AM
Strut tower braces and factory strut bolts. ringe Brakes, Steering & Suspension 4 06-13-2005 09:13 PM
