Old 07-22-2003, 10:54 AM   #1
Suba_Roo
Member#: 5691
2001 2.5 RS
Silverthorn
Default Clunking sounds on long lefts with STI struts on GC6 (attention GTGUY(
My friend just had STI Type RA struts with STI tarmac springs installed on his 2000 RS. He has the STI top hats. He is now getting a "clunking" sound on long left hand turns.
Furthermore when he had it aligned the shop claimed to only be able to get -0.5 degrees of front camber, which might be a related problem.
Suggestions?
Diagnostics?
Help?
Rufus
Suba_Roo is offline   Reply With Quote
Old 08-06-2003, 03:09 PM   #2
Suba_Roo
Member#: 5691
2001 2.5 RS
Silverthorn
24 views no replies eh?
Well we answered our own question. When the struts went in, so did a 6 piece set of the sti lateral links. Turns out the installer screwed up and installed the sti end links incorrectly. Instead of putting the end link on the knuckle, then the lateral link, the order was reversed causing the end link to bind ont he lateral link.
So if you end up with clunking after a lateral link install, double check that your installer isn't a moron.
Morning brake clunk / sounds scuffy for a few minutes normal on STi? overdose Brakes, Steering & Suspension 4 01-03-2006 01:39 PM
Front Left Version8 STi Strut Needed epoth Private 'Wanted' Classifieds 2 07-03-2004 08:22 PM
alignment with STI struts on '04 WRX charliek Brakes, Steering & Suspension 4 02-20-2004 08:43 PM
WRX Sedan STi/SPT strut/spring set fully assembled with STi strut tops. For Sale! boxerT Texas Impreza Club Forum -- TXIC 4 05-07-2003 12:13 PM
slight clunking sound when backing up with Rota tarmacs perhaps? Brakes, Steering & Suspension 2 07-29-2002 04:57 PM
Message Board Statistics All times are GMT -4. The time now is 03:55 PM.
