Old 07-22-2003, 11:37 AM   #1
Force[FED]
Member#: 292
2011 BMW 535i
Havana Metallic
Default Clutch/flywheel options for Stage 4+ WRX?
My Stage4+TMIC setup car is finally overtaking the stock clutch at 53k miles :P I am looking into getting a clutch/flywheel replacement, but wonder what setups people are using with Stage 4+ cars? (and yes...I did searches...)
I was leaning towards ACT at first because I used them in my modded DSMs and they worked well. But a few people said the Exedy clutches are the way to go.
I do NOT want a puck clutch, or a super race clutch...nothing that will completely lunch the tranny.
Right now the Exedy sport clutch and Exedy lightweight flywheel are top on my list, and seems like a safe way to go. Any Stage 4 guys have this clutch? Experience is very welcome :P
Thanks,
Kev
Force[FED] is offline   Reply With Quote
Old 07-22-2003, 10:56 PM   #2
Z1 Performance
Member#: 9327
Done it many times...works very well (heck, my RS ran 11's with this combo!)
Z1 Performance is offline   Reply With Quote
Old 07-23-2003, 02:45 AM   #3
dookiebob
Member#: 21767
2002 STi wannabe
Midnight Blue Swirl
I'm just curious, what problem do you have with the stock clutch? If it held up for 53K miles on your stage 4+, I think that's pretty damn good.
Jim (PlatinumWRX) from Clubwrx.net blew up his tranny when he put an ACT clutch kit in his car. More clamping force = more drivetrain shock.
For your power level, the stock clutch is more than adequate, IMO and in the opinion of Sport Compact Car.
-Bob (stage 4+ with stock clutch)
dookiebob is offline   Reply With Quote
Old 07-23-2003, 10:22 AM   #4
Z1 Performance
Member#: 9327
The ACT abslutely will not blow the tranny up as suggested above. When it comes to clutches with sprung hubs and full radius disks, the driver blows the trann, not the clutch.
Old 07-23-2003, 02:25 PM   #5
dookiebob
Member#: 21767
2002 STi wannabe
Midnight Blue Swirl
That's very true... but a grabbier clutch will make it easier to transmit the shock to the drivetrain.
If you don't have a problem with the stock clutch, there is no reason to change it.
-Bob
Old 07-23-2003, 03:28 PM   #6
Z1 Performance
Member#: 9327
While I agree, I would not consider the ACT grabbier at all......its as easy to drive smoothly as a stock clutch is, just has harder pedal pressure. But I do certainly hear what you are saying, which is the very reason not to do a solid hub disk on anything but a full on race car
Old 07-24-2003, 04:27 PM   #7
jinxproof99
Member#: 21497
i am running a clutchmasters stage 4 clutch and flywheel. works for me.
jinxproof99 is offline   Reply With Quote
2005 2.5RS Clutch/Flywheel Options? TheOrteganator Transmission (AT/MT) & Driveline 0 05-09-2010 11:17 PM
basemap for stage 4 wrx clemsonteg Commercial ECU Reflashes 3 10-03-2007 03:44 AM
2006/2007 Clutch/Flywheel options? FromEvoToRS37 Transmission (AT/MT) & Driveline 1 08-30-2007 10:55 PM
What is a good egt for stage 4 wrx in C' 20024door Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 01-29-2005 07:05 PM
New Clutch for stage 4 2mprzya Transmission (AT/MT) & Driveline 3 10-31-2004 05:49 PM
