Go Back   NASIOC > NASIOC Archives > NASIOC Archives > STi Forum Archive
Old 07-22-2003, 02:57 PM   #1
JDMTEG98
Member#: 38671
2004 WRX STi
World Rally Blue w/ Gold
Thumbs up Removing the Intake Silencer Benifits and Negatives?
Well here's my deed to the forum. I have some pictures that may help. Basically a very easy removal of two items. There are two screws on the "Y" looking piece and two in side the fender wall for the big jug piece. Took about 30 minutes because one screw in the fender wall (Off the jug) was stubborn and kind of hard to reach. I only took the car out 1/4 mile afterwards but you can here the diverter valve and turbo spooling. Sounds much much better . Could not tell if the turbo was spooling sooner but may be cause of the short ride
My concerns
1) Warranty issues (Which I doubt will be a problem since I can easily reinstall this)
2) Big hole it left open in side wall of the engine bay What are you guys using to seal this hole?
Benefits (From what I read)
1) Turbo Spools faster
2) Is louder and more performance sounding
3) More air is available (Less constrictive)
Negatives
1) Are their any???? ??
JDMTEG98 is offline
Old 07-22-2003, 03:53 PM   #2
CreoWRX
Member#: 19024
2016 F80 M3
Alpine White
If you're talking about the front left hole that's left after removing the cold air feeder, Subaru makes a flat panel that fits into it (used on the Impreza 2.5 I believe). I'll try to get a picture later...
-Mike-
CreoWRX is offline
Old 07-22-2003, 06:20 PM   #3
Mrsir
Member#: 12720
2008 Porsche
Cayman S - Red
http://www.subaruwrxparts.com/per-wrx-drivetrain.html
scroll about half way down the page to find it, only costs $5, but unfortunately it's like $8 to ship
Mrsir is offline
Old 07-22-2003, 07:57 PM   #4
Leonardo
Consigliere
Super Moderator
Member#: 185
2009 Civic EX
Or do as we do here.
we cut a hole on the face of the belly in the silencer that faces the front of the car. Basically the only thing you don't cut out is the mounting point. When installed, this creates a "ram air" effect with the opening of the fog light cover or if it's a tough race/solo events, remove that fog cover for added benefits. Don't worry about water as if you hit a deep puddle, the uper intake takes over and no water will go up.
Tried and tested sine the WRX came out.
Leo
Leonardo is offline
Old 07-23-2003, 10:42 AM   #5
JDMTEG98
Member#: 38671
2004 WRX STi
Wow so how does this fit in their?
The silencer itself is not instheir anymore (i.e. the big jug piece)
JDMTEG98 is offline
Old 07-23-2003, 11:03 AM   #6
JDMTEG98
Member#: 38671
2004 WRX STi
You know what that piece looks just like the hole thats left. See pictures below along with my temporary and very much getto solution
Planing on ordering that black peice
JDMTEG98 is offline
Old 07-23-2003, 11:18 AM   #7
STi-Mulation
Member#: 34722
05 BMX
What did you do to ensure that your airbox is fixed into the hole of the fender wall once you removed the silencer (which makes the airbox loose).
STi-Mulation is offline
Old 07-23-2003, 11:18 AM   #8
wolverine
Member#: 36571
2004 WRX STi
Black & gold
Your last picture was pretty funny Sorry, not to laugh at ya; I have done similar things (tape stuff) with my old GSR. Heh, doesn't the OEM plastic funnel serve a purpose to suck cold air from the front in? If you remove that, then sure, you can get more air, but, it's basically hot air from your engine compartment? Cold air -> good, hot air -> bad. I don't know if I want restrictive cold air, or free-flowing hot air
EDIT:: Ignore my post... I now see that you are sucking air from the fenderwell... My bad!
wolverine is offline
Old 07-23-2003, 11:56 AM   #9
VVVV
Member#: 37205
2004 STI
Is it possible to get the black intake screens that used to be installed on the hood in the 2.5 RS? I would think having the hood air intake would be better (further off the hot tarmac) than a fog light intake.
I also really don't understand why they routed the intake hose under the red manifold piping before reaching the turbo. Routing it between the block and the intake manifold seems like the worst way to design it (short of putting it between the exhaust manifold and the block). Is there a reason they did this (emissions, maybe)?
Has anyone tried installing an intake that routes straight down from the hood into a 90 deg bend into the turbo? I imagine a 90 bend might cause flow problems at the compressor inlet. Or is there an aftermarket insulated air hose that would reduce the intake charge heating from the manifold and block?
VVVV is offline
Old 07-23-2003, 01:04 PM   #10
JDMTEG98
Member#: 38671
2004 WRX STi
Its not loose just checked, its vermuch stable.
JDMTEG98 is offline
Old 07-23-2003, 02:54 PM   #11
zacek
Member#: 19467
04 WRX STi
WR Blue - original owner
he's referring to the gap that you now have between the airbox and the fender, you are still breathing warmer air.
zacek is offline
Old 07-28-2003, 11:44 AM   #12
coolray
Member#: 36618
1984 project justy
wrb
hey guys i am trying to do this mod but what happen is i couldnt get the screw out from picture 3 post by JDMTEG98
if anyone can tell me how to take it out that will be great since it has so little space to reach and i dont wanta mess up the screw
also do i need to cover that hole after the silencer is remove?
coolray is offline
Old 07-28-2003, 01:45 PM   #13
JDMTEG98
Member#: 38671
2004 WRX STi
There is only 4 screws to remove. The one inside the fendorholding the "Jug" piece in is hard to get to. I used my finger to loosen it. Keep tryinging.
I ordered that piece from Subaru Parts. I will snap a pic with it on once I get it
JDMTEG98 is offline
Old 07-28-2003, 01:51 PM   #14
bert_WRX
Member#: 27143
if you have an STi then this will save you tons of time...TAKE OF YOUR FOG LIGHT COVER...i could easily get inside the fender to remove all the bolts
-gilbert
bert_WRX is offline
Old 07-28-2003, 02:30 PM   #15
G-shock
Member#: 36545
This part must be available through your local Subaru dealer, so minus 8 shipping!
...but knowing the dealer they'll likely charge $20 for the part and you still have to pick it up!
G-shock is offline
Old 07-28-2003, 08:13 PM   #16
coolray
Member#: 36618
1984 project justy
wrb
hey gilbert
i dont have the sti i have the plain wrx so the fog light is in the way
i try using my finger but its so hard to unhscrew
coolray is offline
Old 07-28-2003, 08:29 PM   #17
JDMTEG98
Member#: 38671
2004 WRX STi
hummmmmmmm internet good!
JDMTEG98 is offline
Old 07-28-2003, 08:47 PM   #18
pitbul09
Member#: 19471
how about just cutting that snorkel so that u just keep the u part? thats what i did on my wrx. There was a thread about some one making that (u) section
pitbul09 is offline
Old 07-29-2003, 03:14 AM   #19
cann
Member#: 8618
wait i don't get it
so there are 3 pieces
one is the funnel shaped that acts like a cold air intake
second is the one that has an air filter in it
third is the silencer box
so in order to get the silencer box out, u need to take all 3 of them out and put the air filter box back in?
cann is offline
Old 07-29-2003, 03:44 AM   #20
CreoWRX
Member#: 19024
2016 F80 M3
Alpine White
You can remove the snorkel and the resonator box without removing the air box (where the air filter is).
-Mike-
CreoWRX is offline
Old 07-29-2003, 03:53 AM   #21
cann
Member#: 8618
how tho
isn't the resonator box under the filter?
or is it inside the fender?
cann is offline
Old 07-29-2003, 10:53 AM   #22
JDMTEG98
Member#: 38671
2004 WRX STi
Originally posted by cann
how tho
Inside the fendor (i.e. Milk Jug is in the fendor)
JDMTEG98 is offline
Old 07-29-2003, 01:49 PM   #23
cann
Member#: 8618
ahh damn
how to get that out then?
do i have to lift the car and take out the fender plastic?
cann is offline
Old 07-29-2003, 06:07 PM   #24
meridock
Member#: 37868
2010 Corvette Z06
yes
meridock is offline
Old 07-29-2003, 06:09 PM   #25
JDMTEG98
Member#: 38671
2004 WRX STi
ahh damn
Yes, I raised the passenger side of the car and it slide out once the screw was removed
JDMTEG98 is offline
Does removing the intake silencer decrease power? ImTooRexy Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 04-11-2004 04:16 AM
Should we put the ram air scoop back after removing the intake silencer? -=Ice-T=- Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 07-06-2003 02:21 PM
I removed the intake silencer on my WRX Iceberg Slim Newbies & FAQs 12 04-21-2002 12:20 AM
