Go Back   NASIOC > NASIOC Subaru Models > Forester Forum
Old 02-28-2001, 05:59 PM   #1
RS*R
Member#: 3538
Question Forester suspension questions
  • Can someone tell me if the impreza front and rear strut bars fit the forester? how about an impreza sport rear strut bar?
  • is the FHI v.5 struts compatible w/ Forester specific springs?
  • if i do a plus 2 on my wheels, should the tire size be 205/50/17? (i have 15" L wheels)
thanks,
-ed
RS*R is offline   Reply With Quote
Old 02-28-2001, 06:24 PM   #2
Crashton
Member#: 3808
2005 Forester XT!!!
Crystal Gray Metallic
Post
I thought I read somewhere that the rear bar will fit but not the front because of the cross member. Sorry I can't answer your other questions.
Chuck
Crashton is offline   Reply With Quote
Old 03-01-2001, 08:39 AM   #3
juice
Member#: 1424
1998 Forester
Acadia Green Metallic
Post
Actually, the SPT front strut brace (made for Imprezas) fits perfectly. I have one and it bolts right on, with no clearance issues:
http://thejuiceman.homepage.com/custom.html
I did a Plus One, but cheated a little with wider tires, so the diameter is also slightly wider. The offset took care of that, and I've had no rubbing.
A Plus Two would be 215/55R17, which has an identical diameter. 205/50 would be way off (too small).
I would not combine the v5 struts with the stock springs. Those springs are very tall to begin with, plus they are much softer than STi springs. If you upgrade, I'd do both.
-juice
juice is offline   Reply With Quote
Old 03-02-2001, 10:43 AM   #4
RS*R
Member#: 3538
Thumbs up
thanks for your info guys...
juice- what i meant to say is using the v5 struts along w/ lowering springs made by STi, 5zigen, tein, etc... that is forester specific.
i can see now that tire sizing is a problem.
my options- 225/50/17 nitto (will it rub the suspension?), 215/55/17-none exist?, 215/50/17-performance ones are expensive.
anymore info on the strut bars-will they fit?
-ed
Old 03-03-2001, 03:26 AM   #5
Imprezer
Dynamic Uno
Member#: 1
2011 Impreza WRX STi
Post
I just got my TEIN Medium springs for mt SF5. I will be installing them tommorow. I will post some pics as soon as I am done.
Imprezer is offline   Reply With Quote
Forester XT with WRX suspension question PJMAN2 Brakes, Steering & Suspension 9 11-06-2007 12:12 AM
Lowered Forester Suspension questions Arnie Brakes, Steering & Suspension 15 06-04-2006 08:03 PM
Old (2001) forester suspension Questions 1modh Forester Forum 9 11-30-2003 02:25 AM
Forester Suspensions Question Rapid_Roo Forester Forum 0 07-10-2003 11:26 AM
Forester Specific Suspension question tselway Forester Forum 2 03-15-2002 06:59 AM
