Old 07-22-2003, 06:39 PM   #1
jroberts
Member#: 34965
Default Metallic rattle from rear drivers side??
2003 WRX 5spd. When accelerating from a start and sometimes while moving, it sounds as if there is a metal coat hanger banging around inside my rear drivers side door. Any ideas?
jroberts is offline   Reply With Quote
Old 07-24-2003, 07:12 AM   #2
jroberts
Member#: 34965
Anyone?
Old 07-25-2003, 01:57 PM   #3
Zongo
Member#: 30994
2003 WRX Sedan
Midnight Black Pearl
Are absolutely sure of the location (have someone else drive while you scurry around in the back listening)? My guess would possibly be something slightly loose with the seatbelt or babyseat assemblies. Try changing the height on your rear drivers' side seatbelt guide, and see if the sound changes. It worked for me
Zongo is offline   Reply With Quote
Old 07-26-2003, 01:41 PM   #4
Robmat
Member#: 2173
2005 LGT Wagon 5MT
ABP
I have had a rattle in my RS for about two years now. I searched everything and could not figure out where it was coming from. I found several other things that I fixed or tweaked but still have not found the cause for the initial rattle. I just deal with it now
Good luck
Robmat is offline   Reply With Quote
Old 07-28-2003, 01:28 PM   #5
gpd323
Member#: 9878
2002 WRX/GTX
WRX Wagon/Mazda GTX
Default Re: Metallic rattle from rear drivers side??
Take it to the dealer. I had a clunking sound from my drivers door and it was 7 loose bolts inside the door panel. All 4 bolts that hold the window motor to the inside metal door panel were loose and 2 were ready to fall out. The other 3 bolts were associated with the window regulator.
Reason I went ahead and pulled the door panels off myself is some WRX owners were posting about how the loose bolts had damaged the door panel! The torque of the window motor pulled the loose bolts right thru the inside door panel mounting points.
I used loctite on all the bolts. Maybe the sound is loose bolts??
Good luck,
Greg Downing
gpd323 is offline   Reply With Quote
Rattling from rear passenger side door mushumatt Interior & Exterior Modification 2 02-22-2009 05:45 PM
Rattle/Ticking Noise Coming From Rear Driver Side Suspension Impreza2003 Brakes, Steering & Suspension 1 05-15-2005 09:28 AM
Loose metal rattling by front driver side gumby1976 Brakes, Steering & Suspension 5 08-04-2004 12:51 PM
Small rattle from rear passenger side seatbelt? RWagner STi Forum Archive 4 06-10-2003 08:03 PM
Rattle from rear driver side wheel...how do i fix it? CanadianWRB-WRX Brakes, Steering & Suspension 2 05-04-2002 12:07 PM
