Old 07-22-2003, 09:37 PM   #1
bryan2.5rs
Member#: 6807
2005 STi
Crystal Gray Met.
Default fuel problem
i have a 2001 rs with wrx turbo, i have a 2.2 short block and a RRFPR, when i am on the highway trying to maintain a speed my AF Ratio gauge goes into stoich to much and i keep throwing a CeL PO130 o2 sensor to lean i checked the fuel trim and the ecu is telling me that the short term is 37 and the long term is -20% it is my understanding that it should be at +7% FYI this was freeze frame data from when i tripped the CEL PO130, any help would be greatly appreciated, THANX Bryan
bryan2.5rs is offline   Reply With Quote
Old 07-24-2003, 10:28 AM   #2
bryan2.5rs
Member#: 6807
2005 STi
Crystal Gray Met.
bump
Old 08-06-2003, 09:52 AM   #3
bryan2.5rs
Member#: 6807
2005 STi
Crystal Gray Met.
bump
Old 08-07-2003, 09:58 AM   #4
ChicksDigWagons
Member#: 20508
1998 Red Wagon
New Turbo Project...
Do you have a fuel pressure gauge? Its interesting that at cruise you're throwing a code like that. I would expect having the ECU in closed loop would just compensate for changes in A/F. Unless the lean burn RS's aren't as receptive to change outside of the expected parameters...
-brad
ChicksDigWagons is offline   Reply With Quote
fuel problem, is it the fuel pump or FPR? Unabomber Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 02-24-2012 05:42 PM
stg 4 fueling problem//fuel pump?? wyowrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 04-28-2004 08:06 PM
Air/Fuel problems TurboXS Stage II HELP!! Justbordn22 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 10-20-2002 11:21 PM
Air/Fuel problems.... TravRex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 10-06-2002 09:23 PM
air/fuel problems atomicapples Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 05-17-2002 08:24 PM
