Old 07-22-2003, 09:46 PM   #1
Andursun0013
Member#: 11616
1998 2.35RS-T
2006 Baja 2007 Leg. Wagon
Default venting BOV to atmosphere
Why do people do this, is there any reason behind it or is it just easier to do? I'm kinda clueless as to what this does for the car. And when you vent it back into the intake..should it go before or after the air would pass over the MAF...I'm assuming after so the MAF woudldn't read the air twice
Kyle
Andursun0013 is offline   Reply With Quote
Old 07-23-2003, 12:07 AM   #2
trilap5e
Member#: 19644
2005 WRX STi
ok... here are a couple of reasons - first off the noise. you know what a bov sounds like right? exactly! blowing it back into the intake would dampen this sound. secondly, some systems do recirculate the boost, but if your blowing off the butterfly valve in the TB is closed (why you blew off in the first place) - so it doesn't make much sense to blow it back into the intake. get me?
there are many reasons - these are just some black and white examples. hope this answers your question.
- Ryan
trilap5e is offline   Reply With Quote
Old 07-23-2003, 12:46 AM   #3
Mancini
Member#: 20726
Pretty much 2 reasons to return to the intake I can think of. 1. If you have a MAF the air is already metered like you mentioned. 2. Some BOV's open at vacuum to give better throttle response on tip in (by passes the turbo and air gets directly to the TB). So you'll be sucking in dirty air or unmetered air if you tune around the venting on a MAF equipped car. Otherwise, vent to atmosphere and enjoy the sexy pssst noises
Mancini is offline   Reply With Quote
Old 07-23-2003, 09:29 AM   #4
Andursun0013
Member#: 11616
1998 2.35RS-T
cool, thanks guys
Kyle
Old 07-23-2003, 11:58 AM   #5
BOY
Member#: 232
99 RS-T RIP
02 Forster-S
Other than an overpriced noise maker, an atmospheric BOV serves no useful purpose until you're pushing MAJOR boost. On a MAF equipped car, specifically one that wasn't designed for a turbo, you've already metered the airflow and the ECU is calculating the appropriate amount of fuel... when you vent that air you're pouring too much fuel into the cylinder which can lead to detonation and backfiring into the intake manifold. Another advantage of a diverter valve (recirculating valve, etc) is the airflow is vented back immediately before the compressor which help to keep it spinning and reduces lag.
BOVs, the ultimate rice mod
Old 07-23-2003, 04:58 PM   #6
Midwayman
Member#: 1997
2006 Acura TL 6spd
STMGM6 alumni
An BOV as opposed to a diverter valve
1) Doesnt put hot air back into the intake tract
2) Allows for a somewhat smoother intake path
3) Is simpler to design (Probably the one of the big reasons you see them on aftermarket kits)
4) Louder. (cool or not, your choice)
If you're replacing a Diverter valve with a BOV and it was working fine before yah its kinda pointless. If you're assembling a MAP based turbo kit, why not use one though.
I think the mainadvantage the BOV's Ive seen vs the diverters Ive seen on RST's is that the Diverters Ive seen have been the cheap nonadjustable ones. A little bit of spring adjustment is always a good thing.
Midwayman is offline   Reply With Quote
Old 07-23-2003, 05:12 PM   #7
BOY
Member#: 232
99 RS-T RIP
02 Forster-S
He's running a 98 though, the MAF will
1. Meter the air he's blowing off
2. if the BOV opens at part throttle he'll be running super lean, unmetered air through the BOV into the engine.
If you really want that "hey look at me" sound, get a 50/50 valve that only vents to air at "high" boost (this is adjustable). Either way, until you're pushing BIG boost (20+ psi) its just a party favor.
Old 07-23-2003, 06:51 PM   #8
Andursun0013
Member#: 11616
1998 2.35RS-T
where do you find a divertor...all i ever see for sale are BOV. Although I don't have a turbo at the moment (or the money for one) I am planning on getting one as soon as I sell my bike (anybody want a 2002 Honda CRF450R....) and I'll need to know where to find this at, I would assume my local shop, slowboyracing.com, will be able to get one for me. While I'm on the subject slowboy does awesome work and are starting to carry more and more subaru stuff.
Kyle
THanks again for all the info
Old 07-23-2003, 08:45 PM   #9
Midwayman
Member#: 1997
2006 Acura TL 6spd
STMGM6 alumni
well, just because he's running a 98 doesnt mean its MAF. Most PEMS systems are map based.
Alot of the wrx "BOV"'s are really diverter valves. Usually listed as a non-atmoshperic BOV or some such thing.
Old 07-24-2003, 09:13 AM   #10
BOY
Member#: 232
99 RS-T RIP
02 Forster-S
Default Re: venting BOV to atmosphere
Kyle
'nuff said? Most PEMS systems use a MAP sensor cause its easier to tune but its also much less acurate a metering air flow. All turbo Subarus use MAFs for a reason . Anyhoo, to get back to the topic at hand... OEM's use diverter valves, the 1G DSM and GD WRX are very similar and very very good (until you get to 19-20+ psi). You vent the air back after the MAF but before the compressor. What the valve actually does is vent the pressurized intake charge when the throttle plate shuts. Over time (ignoring the increased lag) a turbo w/o a DV or BOV will slowly be beaten to death by the pressure build up between the closed throttle and the compressor wheel.
Venting Crankcase to atmosphere? KW900 Newbies & FAQs 10 09-13-2009 08:12 PM
bov to atmosphere? jefersun Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 09-20-2003 04:04 PM
BOV to Atmosphere Unsung Boxer Normally Aspirated with bolt-on Forced Induction Powertrain 4 06-10-2003 03:37 AM
Venting wastegate to atmosphere?? wrx2.0 555 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 01-19-2003 09:48 PM
Anyone venting Wastegate to Atmosphere? Eric SS Normally Aspirated with bolt-on Forced Induction Powertrain 22 11-20-2001 05:49 PM
