Old 07-25-2003, 03:47 AM   #26
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Ok, I went to Lowes and Home Depot and the only thing I found even remotely close to that was this rolled up semi-foamy bag of sealant that LOOKED like that but was super-soft and way to flexible for a lip...
Old 07-25-2003, 11:10 AM   #27
satrya
Member#: 5887
2002 GDAA (bugeye)
797 (blaze yellow)
...the only thing I found even remotely close to that was this rolled up semi-foamy bag of sealant that LOOKED like that but was super-soft and way to flexible for a lip...
It may suffice in the sense of reducing the amount of air flow. I know the one I got is somewhat soft too, but the thickness makes up for it. If you push on to it, it will deform, but it won't fold over. Here's how the cross section looks on mine:
satrya is offline   Reply With Quote
Old 07-25-2003, 01:39 PM   #28
satrya
Member#: 5887
2002 GDAA (bugeye)
797 (blaze yellow)
Thumbs up Survived the first incident...
This is by no means a solid proof on the lip's durability, but I thought it may be interesting to post anyway. Just this morning I ran over a small branch on the highway. It wasn't a big branch, but big enough to make a noticeable impact sound when it hit the bumper cover and underbody. It seemed to have hit the right side of the bumper cover and the neoprene lip. Here is a photo I took just this morning. The neoprene lip has no scratch marks, but there are some dirt marks from the branch grazing it. It's not visible on the picture below. A bit of wet towel will remove all the marks made by the branch on the neoprene lip.
You can see leaves (circled) that get caught between the fog trim & the bumper cover, and between the neoprene lip & bumper cover. In retrospect, I would've been worried had it been a fiberglass or carbon fiber lip.
Old 07-25-2003, 03:32 PM   #29
satrya
Member#: 5887
2002 GDAA (bugeye)
797 (blaze yellow)
Default Front page updated
Updated 3rd post with photos of the side, cross section of the neoprene piece, and bottom view.
Old 07-25-2003, 07:43 PM   #30
WRallyBlue02
Member#: 20157
0503 WRX STI & 03Wag
Asp White, Plat Silv Met
Where did you get the fog trim, I have never seen that, it looks very nice!
WRallyBlue02 is offline   Reply With Quote
Old 07-25-2003, 11:19 PM   #31
satrya
Member#: 5887
2002 GDAA (bugeye)
797 (blaze yellow)
Where did you get the fog trim...
Here's how to get a fog trim like that:
http://forums.nasioc.com/forums/show...hreadid=330937
But if you're not into DIY, there's one somewhat similar (conceptwise at least) by Lester. www.nopionline.com carries it, afaik.
Old 07-26-2003, 01:27 AM   #32
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Ya, thats the stuff I found... I thought it was gonna be thicker rubber not foamy stuff
Old 07-26-2003, 02:01 AM   #33
satrya
Member#: 5887
2002 GDAA (bugeye)
797 (blaze yellow)
Afaik, neoprene doesn't get any stiffer than that.
One way to make the shape hold better, is to place a similar or stiffer material behind it. I initially planned on doing that, but after bolting and making the neoprene follow the bumper cover curvature, it had the right amount of stiffness (from the curb-proof perspective). Since you already have the material, perhaps you can try it on and add reinforcement material if needed.
Old 07-26-2003, 11:31 AM   #34
128d
Member#: 7792
2002 Prodrive
widebody Cosworth 2.5 6sp
Anyone have any luck finding that part on the nopi site?
128d is offline   Reply With Quote
Old 07-26-2003, 06:11 PM   #35
satrya
Member#: 5887
2002 GDAA (bugeye)
797 (blaze yellow)
My bad. They used to list that fog trim as well as some other parts. They are listed as Erebuni parts, because afaik, Erebuni imports Lester (of Italy) products to the US. But I recall someone posting a USDM WRX with that fog trim, so, at some point in the past, it used to be available. Perhaps there wasn't enough interest in it.
Well, the DIY isn't that hard
Old 07-29-2003, 10:34 PM   #36
Scaed
Member#: 22338
07 STi LTD #504
Urban Gray Metallic
Default No Luck at Home Depot
I guess I live too far south for neoprene door seals. Did find this at McMaster-Carr. Looks like the same, is it?
Neoprene Garage Door Sealer
Scaed is offline   Reply With Quote
Old 07-29-2003, 11:40 PM   #37
satrya
Member#: 5887
2002 GDAA (bugeye)
797 (blaze yellow)
Default Yes
Prior to locating mine at Home Depot, that one from mcmaster was the one I had in mind. Based on the description, Model 4 (part # 8121A11, 9ft long) is similar or identical to what I got at Home Depot.
Just one note though, as it is neoprene, don't expect fiberglass stiff (although it won't be crack-prone like fiberglass either). So, if you want to stiffen it more, you may need to fill the gap with other material. There must be some foam or rubber strip that is thick enough for reinforcement. I think I recall seeing something that will do the trick at mcmaster. It had a self-adhesive tape too. Good luck. Post some photos afterwards maybe.
Old 07-29-2005, 03:12 AM   #38
arco
Member#: 57156
2007 V.8 207 STi
Mercedes Polar White
someone do it on an 04+. i'm thinking about it but i'm curious to see how it would look first. i guess i'm not a confident DIYer. haha.
arco is offline   Reply With Quote
Old 12-16-2005, 01:19 AM   #39
alter.ego
Member#: 82466
Red
any words of wisdom for good hardware to bolt this up?
alter.ego is offline   Reply With Quote
Old 12-16-2005, 01:44 AM   #40
wrx_gtp
Member#: 23831
2006 WRX
SGM
On a cold and lonely night nobody can hear a sad boy cry
....in teh gettooo, ....in teh gettoooooo
Dang, just looking at that I can hear gun shots in the background, come own.
No carbon fiber, how can a brotha keep it real!
Ok, ok... Just kidding its a cool concept in a Macgyver sort of way. Keep on spooling dawg. Yeah, yeah.
wrx_gtp is offline   Reply With Quote
Old 12-16-2005, 02:36 AM   #41
alter.ego
Member#: 82466
Red
as if explaning how a newer driver ie., someone under 24, might possibly want replaceable protection for an often abused curb-finder,
or the fact that there is indeed carbon fiber here on said car would make any difference in my admiration for your ability to hold back sarcasm and be genuinly helpful.
Old 12-16-2005, 04:10 AM   #42
wrx_gtp
Member#: 23831
2006 WRX
SGM
...that's what she said last night.
Oh, and if you're worried about scraping, practice parking. Really, I've seen way too many cars ruined by "young" drivers and their mad skills.
Just like my old WWII pal Lefty would say, "If you're not sure where you're stepping, then .....BAANNNGGG!!!!
First step in tuning: Tune the driver.
Old 12-16-2005, 04:59 AM   #43
spongejosh
Member#: 62783
Midnight Black Pearl
i like this idea and i may do it to my car. seeing as my car actually gets driven in the snow/ice/dirt this seems very practical.
now i can have a lip and rallycross too.
josh
spongejosh is offline   Reply With Quote
Old 12-16-2005, 05:14 AM   #44
garie
Member#: 26607
2002 wrx wagon
looks very nice. The nicest looking DIY lip I've seen. good job!
garie is offline   Reply With Quote
Old 12-24-2005, 02:15 AM   #45
satrya
Member#: 5887
2002 GDAA (bugeye)
797 (blaze yellow)
Thanks for the opinions, whatever they are. I won't go into the debate of whether this DIY looks good etc.
Regarding mounting hardware, it is best to distribute the load by using several fasteners. If you're using nut & bolt, a wide washer helps a lot. A better option would be to fabricate a splitter-like washer that goes all the way on the bottom of the horizontal part of the lip imho.
Old 02-22-2006, 12:19 AM   #46
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
This will be my next exterior mod...
Satrya, any issue in terms of durability of material, etc? I am going to Lowe's tomorrow to look for this material. Any idea what it is called? neoprene door seals?
Old 02-22-2006, 01:06 AM   #47
Handsdown
Member#: 29355
i used Frost King garage door sealant trim, it was fairly cheap and made of medium hardness rubber... a little deeper black in color and a little more substantial.
Handsdown is offline   Reply With Quote
Old 02-22-2006, 01:09 AM   #48
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
Is that FKGDST available at Lowe's? you got any picture available?
Old 02-22-2006, 01:14 AM   #49
JohnnyWas
Member#: 91010
2002 Subaru WRX
OG Blueberry
not a bad idea. might have to try this myself, being such a cheap mod. hell, if i dont like it -- ill just buy a real one haha
JohnnyWas is offline   Reply With Quote
Old 02-22-2006, 01:27 AM   #50
wrx13oy
Member#: 60529
2002 PSM Bugeye stg6
07 Kawasaki ZX6R
i made one too but i used one that was all rubber. its more durable but it tends to crinkle on the the corners of the bumper
wrx13oy is offline   Reply With Quote
Likelihood of cracking/breaking front lip or rear diffuser? purduephigam Interior & Exterior Modification 10 07-24-2008 11:28 AM
*fs new greddy front lip for impreza 99-01 * xblackdeathx Exterior/Styling 17 12-19-2006 08:22 PM
help! cracked greddy front lip aznballa73 Interior & Exterior Modification 2 11-20-2004 02:37 AM
On SALE! Greddy Front Lip for all Impreza WRX / STi optionimports Vendor 'Group Buy' Classifieds 15 09-19-2004 06:23 PM
Any Interest In A Silver Greddy Front Lip For 02+ Imprezas? nickgomez Texas Impreza Club Forum -- TXIC 10 07-09-2003 04:53 PM
