Old 06-11-2001, 07:54 PM   #1
EPD
Guest
Member#:
Question Check engine. Tumble generator valve
2002 WRX. Check engine light came on. Diag with the TGV stuck open. Has anyone experienced problems with this valve being stuck open? What are the problems with this.
Old 06-12-2001, 11:47 AM   #2
Jon [in CT]
Member#: 2992
02 WRX Sedan
Post
When the engine is cold, the tumble generator valves close to allow a leaner A/F mixture. When the engine has warmed to normal operating temperatures, the TGVs open. It appears the only problem caused by stuck-open TGVs is added emissions when you first start the car.
Jon [in CT] is offline   Reply With Quote
P1086 Tumble generator valve #2 ?? GimpWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 35 03-31-2006 05:17 AM
P1088 Passenger Side Tumble Generator Valve Wrxified Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 06-04-2003 07:18 AM
P1088 Passenger Tumble Generator Valve Wrxified Service & Maintenance 0 06-03-2003 07:41 PM
Tumble Generator Valve - when do they swith off? rotorbaru Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 20 10-25-2002 08:11 AM
Tumble Generation Valve Info Imprezer Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 01-21-2002 03:24 AM
