Old 07-23-2003, 03:03 PM   #1
serious
Member#: 22879
Default Info needed on swaping parts to ej20
Hi all, i'm trying to figure out if any parts from the ej25 dohc engine will work on my wrx engine.
What i would like to know is if the following parts can be swapped over. Please list if you're speaking from experience or just speculating. My engine has some damage and there are plenty of 2.5's laying around!
thanks
Cam gears
front timing belt covers
idler pulleys
Water pump
Thermostate
thermostate housing
Brent
serious is offline   Reply With Quote
Old 07-24-2003, 12:34 PM   #2
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
Cam gears i believe so
front timing belt covers yes
idler pulleys yes depends on year of engine
Water pump no use ej22t
Thermostate no use ej22t
thermostate housing no use ej22t
timing belt yes
Old 07-24-2003, 03:34 PM   #3
serious
Member#: 22879
Anyone know for sure what year 2.5 motor(s) would be compatable for my part list?
Thanks
Brent
Old 07-24-2003, 04:10 PM   #4
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
1997-1998 DOHC EJ25 or 2002+ DOHC EJ20 for cam gears, timing belt covers, timing belt, and probably idler pulleys (maybe)
1991-1994 SOHC EJ22-T or 2002+ DOHC EJ20 for waterpump, thermostat, and thermostat housing
-Jon
Old 07-25-2003, 04:41 PM   #5
serious
Member#: 22879
Cool, thanks for the reply.
Brent
Info needed on standard fuel surge boxes on US cars STBnick Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 8 12-16-2011 10:14 PM
Help! Need help moving parts to DPS on Wed May 20th from Silver Spring EGY5 Mid Atlantic Impreza Club -- MAIC 5 05-19-2009 12:23 AM
Need advice on what parts to get. ndubz Newbies & FAQs 18 11-21-2008 01:58 PM
ej25 part to ej20 engine? vw_speedsterke Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 11-03-2004 10:24 AM
WTB Plus Info Needed On Front Diffs Narcisse91 Legacy Forum 0 07-13-2001 05:53 PM
