Welcome to the North American Subaru Impreza Owners Club Tuesday September 2, 2014
Old 07-23-2003, 02:43 PM   #1
rallynutdon
Member#: 24568
1993 Impreza, WRX
drive train, Open class
Default USDM WRX gas tank into 96 Impreza?
Has anyone ever tried to get a USDM WRX gas tank and all it's hoses to work on a 96 car without using the WRX canister and other junk mounted back there under ther trunk? I'm trying but an having problems with the evaporation hose from the filler neck and the vent valve hose, what to do with them. This is on a rally car so smog or emission are not important. Thanks.
rallynutdon is offline   Reply With Quote
Old 11-18-2003, 02:23 PM   #2
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
What ever became of this?
-Jon
Old 11-18-2003, 02:35 PM   #3
rallynutdon
Member#: 24568
1993 Impreza, WRX
I got it to work, but without the canister (really no place for it for rallying unless I had used long hoses and put it in the trunk). If anyone is interest in the specifics of the way I connected all the hoses for their own project, I can diagram it. It was a lot of trial and error.
Old 11-18-2003, 02:45 PM   #4
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
I am very interesting considering I am trying to stuff a newer gastank into my car to get emissions legal. My fuel system currently has the evaporation canistre sitting in the engine bay and that won't work with my EJ205 going in there.
Thanks,
-Jon
Old 11-18-2003, 04:52 PM   #5
dwx
Member#: 8343
2005 2012 Jeep
2013 DGM BRZ
There are a few guys here that have built rally cars out of 95/97/etc. Imprezas with WRX/STI swaps and all the ones I know of use the WRX tank on those cars.
Old 11-18-2003, 07:57 PM   #6
NicEJ25
Member#: 26155
2008 WRX 5dr
Dark Grey
i've been offerend a 02 WRX tank to put on my93 impreza converted into a MY01 RS. this is basicly to get a larger tank, with sensors to stop getting useless CEL. How long does it take, what need to be removed, and how much should I pay for it ?
thanks, Nic
NicEJ25 is offline   Reply With Quote
Old 12-02-2004, 11:17 AM   #7
Keith
Member#: 191
2012 J train
Brown
any update with this one? I'm doing the same thing and had a small issue with filling the tank (gas wouldn't go in! )
Keith is offline   Reply With Quote
Old 12-02-2004, 11:51 AM   #8
rallynutdon
Member#: 24568
1993 Impreza, WRX
I'll have to look at it to give you a diagram of what worked for me. I should be able to do it this weekend.
Old 12-02-2004, 11:55 AM   #9
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
then why didn't you leave the stock 96 tank in?
Old 12-02-2004, 03:34 PM   #10
rallynutdon
Member#: 24568
1993 Impreza, WRX
Tank didn't really matter (put the WRX tank in cause the 96 tank was dented severely from rallying). The WRX feul pump and hoses is what caused the issue. On the WRX the canister is in the rear, on the 96 it's in the front (engine bay). I didn't want the canister in the rear to get torn off in a rally.
Old 12-02-2004, 06:37 PM   #11
AKGC8
Member#: 1305
2000 Impreza
In my old 94 L with 02 WRX swap I was running the WRX tank without the canister(was in a hurry pulling stuff from the parts car and cut some of the hoses for the canister, never got around to getting new ones). I just used one of the fittings from the evap system that allowed me to run the hose from the tank for the evap system back into the large hose coming off the filler tube. Car ran great.
It's kind of a PITA. Nothing to technically difficult, just getting under the car and lugging the gas tanks around. A second set of hands could speed that up.
AKGC8 is offline   Reply With Quote
Old 12-02-2004, 10:36 PM   #12
subbyspeed
Member#: 16274
2001 GM6 2.0L vf30
e30 black/rust
if gas isn't going in, theres a check valve by the tank, usually in the filler neck. that is most likely your problem. I work for toyota and we saw alot of problems with newer celicas with the check valves breaking and causing similar symptoms.
subbyspeed is offline   Reply With Quote
Old 12-21-2004, 10:19 AM   #13
Keith
Member#: 191
2012 J train
Brown
quick question. we can get gas in the car if we take the return line off (from the engine bay).
does that still sound like the same thing?
If that is the case, how hard is it to change the check valve?
06 Sti intake box into 96 impreza outback peteh82 Normally Aspirated Powertrain 1 02-10-2009 02:12 AM
Wiring job for EJ22T swap into 96 Impreza Old School Scooby North West Impreza Club Forum -- NWIC 12 09-26-2008 08:03 PM
02 WRX parts into 96 Impreza? Need BB Brakes, Steering & Suspension 4 07-09-2006 09:52 AM
02-03 usdm wrx cluster fit into usdm 04 wrx? 11rex06 Electrical & Lighting 2 11-21-2004 09:48 PM
WRX gas tank question.... bunot Factory 2.0L Turbo Powertrain 2 12-04-2002 11:04 PM
