Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Old 07-23-2003, 03:47 PM   #1
rhdude
Member#: 6637
2009 Acura MDX Sport
Talking Thicker oil, and Spark plug gap makes a huge diffence
Well, I've been running 10w-30 Mobil One Synthetic for as long as I have had the turbo (a little over a year) and have'nt had any problems, but I was talking to a few tuners today and they suggested I try 15w-50 in the summer, it will provide more viscosity, allow less blow by, and reduce engine noise. Well, the car has'nt blown any smoke, the motor runs smoother and more quieter And the 10w-30 that was in there was only about 1000miles old, so it was'nt that dirty... By using 15w-50, am I risking hurting the motor at all?
Also, changed the spark plug gap from .032" to .028", and one of the spark plugs I guess I had forgot to gap before, cause it was around .035"... so I regapped them all, and I've noticed smoother idle, and the engine just runs smoother overall..
I'm not sure what made the bigger difference, the plug gap or the oil, but my motor is finnaly running smooth as butter
rhdude is offline   Reply With Quote
Old 07-23-2003, 05:15 PM   #2
kastle
Frank Army
Member#: 1457
1999 Outback Sport
Steel Blue Mica
FWIW, I run the 15w50 in my RS-T (Mobil-1), and really like that weight and viscosity. It's worked well for me.
kastle is offline   Reply With Quote
Old 07-23-2003, 07:19 PM   #3
ShadowIMg
Member#: 31519
2012 Torque Egg
2001 2.5RS Coupe
Would my assumption that it would be bad to have the heavier oil in during the colder parts of winter be correct?
ShadowIMg is online now   Reply With Quote
Old 07-23-2003, 11:39 PM   #4
kastle
Frank Army
Member#: 1457
1999 Outback Sport
Steel Blue Mica
Cold winters in AZ is like 40 degrees....
Old 07-23-2003, 11:45 PM   #5
ShadowIMg
Member#: 31519
2012 Torque Egg
2001 2.5RS Coupe
Right, but for those people who don't live in the pits of hades... Was just curious about why it would be ill advised to run the heavier oil normally, or is it?
Old 07-24-2003, 09:49 AM   #6
rhdude
Member#: 6637
I would'nt use the 15w-50 in the winter... I'm going to switch it back over to something like 10w-30 for the winter.
when to go thicker oil and colder plugs? jacky599r Built Motor Discussion 25 12-27-2008 09:50 AM
Which Engine Oil and Spark Plugs for the TRACK ??? george3 Motorsports 25 01-10-2008 08:59 AM
changed transmission gear oil and spark plugs SlickRick51586 Service & Maintenance 0 06-04-2007 10:09 PM
Spark Plug Gap and Misfire Codes, Realtionship? JayGold Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 05-15-2003 05:02 PM
What oil, and spark plug/wires should I use? darkmattr Newbies & FAQs 7 07-17-2002 12:18 PM
