Welcome to the North American Subaru Impreza Owners Club Saturday July 26, 2014
Old 07-23-2003, 05:12 PM   #1
KnightWRXRider_
Member#: 30496
2004 STi
Default UTEC for 02 WRX work for 03?
Will a UTEC bought for an 02 WRX work with an 03, is there something I can do to make it work.
KnightWRXRider_ is offline   Reply With Quote
Old 07-23-2003, 06:05 PM   #2
JustDSM
Member#: 17502
To the best of my knowledge only Ver.5 amd Ver.6 UTEC's work w/ '03 models.
JustDSM is offline   Reply With Quote
Old 07-24-2003, 04:11 AM   #3
mick_the_ginge
Citizen Mick
Member#: 27646
2003 Sleeved 2.5
Oil Dry Sump Goodness
An 02 UTEC will work with an 03 but it does not know about the in fuel tank sensor. The wire for this has to be jumpered around the UTEC wiring harness and back into the ECU directly.
People are also going to say that some of the sensors readings are backwards, UTEC seems to handle those fine as well.
mick_the_ginge is offline   Reply With Quote
Old 07-24-2003, 07:54 AM   #4
KnightWRXRider_
Member#: 30496
2004 STi
What specifically do I have to do to do that?
Old 07-24-2003, 08:18 AM   #5
mick_the_ginge
Citizen Mick
Member#: 27646
2003 Sleeved 2.5
I'm out on business so do not have access to my car to remind myself exactly what wire needs to be jumped back over to the ECU. I can have a look at it next week.
You can also just connect it up as is. You will get a none critical CEL. It was this code:
P1446
It's the in-tank pressure sensor. I drove the car for a month before I bothered fixing it.
Maybe you can find someone else who has done this fix quicker than I can get back to my car.
Post this on www.wrxhackers.com as well. TurboXS should also be able to quote on the reversed sensor connections. I did nothing about these and everything works just fine, but just to be sure, check with them.
Old 07-25-2003, 03:24 AM   #6
knertified
Member#: 33244
I figured it was not a really big deal to have a CEL from that temperally.I also posted up on wrxhackers on this today but there server is down so i cant check the post. Hopefully someone at turboxs will reply. Thanks for the info..
knertified is offline   Reply With Quote
Old 07-28-2003, 01:49 AM   #7
knertified
Member#: 33244
help !
Old 08-10-2003, 01:10 PM   #8
ebr0t
Member#: 16930
2003 WRX Sedan
Sonic Yellow
bump, i got the same cel....
ebr0t is offline   Reply With Quote
Old 08-10-2003, 01:31 PM   #9
jnmarshall
Member#: 40500
11 wrx
Virtual
I called utec myself about this. They said ver5a or above will work with an '03 and 6 and above for '04. All versions are backwards compatible.
For each one the guy said you have to jumper a wire to the ecu from the utec harness. If you call them, they will tell you exactly which ones. They are VERY helpfull!
jnmarshall is offline   Reply With Quote
Old 08-10-2003, 01:42 PM   #10
ebr0t
Member#: 16930
2003 WRX Sedan
Sonic Yellow
what is jumping a wire?
Old 08-10-2003, 03:21 PM   #11
jnmarshall
Member#: 40500
11 wrx
Virtual
From what I understood, the needed wires didn't exist in the txs harness, and the signal would not get sent to the ecu. So you have to add the wire (or wires?)
You can't just simply get a newer harness either. txs doesn't offer one, plus the version of utec doesn't know what to do with the signal.
Old 08-10-2003, 03:53 PM   #12
ebr0t
Member#: 16930
2003 WRX Sedan
Sonic Yellow
so theres nothing else ya can do about it? any other differences in the 02 and 03
Will AP v1 for a 02 WRX work on a 03?? kraigt AccessPort 7 03-08-2010 01:20 PM
wtb: stock exhaust manifold for 02 wrx. trade for GtSpecs?? rolzrex Private 'Wanted' Classifieds 3 07-01-2008 11:40 PM
lights for 02 wrx lookig for the bright light capron765 Newbies & FAQs 11 02-12-2007 06:41 PM
Will the bosal Dp for 02-05wrxs work for 06s? uniden43 Factory 2.5L Turbo Powertrain 1 05-12-2006 02:45 PM
can unichip for 02' wrx work for 03' wrx? BlueWRX Engine Management & Tuning 2 11-09-2002 12:00 AM
